Question about Saws
How do i remove the carbon brushes from my table saw
Have got them exposed at motor but cant shift them
    Sergeant:
  • 206 Answers
They may be burnt and jammed - carefully break them into pieces with a screwdriver (being careful not to damage the brass brush tubes or the copper armature at the end) using compressed air, blow the pieces out and clean the tubes.
Use a flashlight to look down the tubes and inspect the armature as well - if the brushes are burnt into the tubes there may also be damage to the armature.
how do i remove the carbon brushes from my table s - 25316790-wvjv2ek3boqiwefmtj30yfqx-2-0.jpg
Posted on Feb 07, 2015
rowdy45176
  • 2176 Answers
SOURCE: Bosch 4000 table saw won't work
OK sounds like you are handy. You have electric to the brush tubes? (first unplug saw to test) If yes then I would remove the brushes to see if they were making contact with the commutator. Does the blade spin freely? If not you might have a bearing problem. I would again use air after removing the brushes and then reinsert making sure they seat on the armature. If still nothing then if you are comfortable I would pull the motor housing. But before pulling go to Bosch Tools website and downloading a breakdown of your saw. Let me know if I can help
Posted on Jan 15, 2009
  • 62 Answers
SOURCE: Motor not working on Delta table saw: I just got a
Ok, the motor turns, but throws sparks on the brushes. This is normal to an extent for universal motors used on that type of equipment.
Try reassembling the saw, and put a blade on it, then try it. If it runs, try cutting a piece of scrap 1x, both crosscut & rip. If the motor can't hold the load, you may still have to replace it.
Posted on Apr 18, 2009
  • 187 Answers
SOURCE: New or used motor for a Craftsman 10" table saw
You can try Sears but they can be a bit pricey. I use to send out motors for a factory I worked in to a rebuilder who would even do new windings. Check in your area for a rebuilder, As for the replacement being a Sears unit they may have a similar motor in stock. Good luck.
Posted on May 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: Bosch 4000 table saw disassembly
turn the motor housing slightly until you can put a screwdriver between the housing and diaphragm, pull on the one side and push with the driver and it will come apart, I just did one yesterday. To get the armature out of the fan bearing you will need a dead blow hammer to tap on the diaphragm while pulling on the armature. The bearing is held in place with 2 screws, hope this helps.
Posted on Aug 18, 2009
Testimonial: "Hey thanks! It seems they really don't want you to work on the motor on this particular saw. Thanks again for your help. "
  • 384 Answers
SOURCE: key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Posted on Sep 14, 2009
2001 nissan xterra 3.3 motor 4x4 how to remove neutral safety switch do u do it from inside our under it on the outside
Most often switch is accessed from top, remove gear shift console cover carefully and it is in plain site, switches are never exposed to weather and will never be under vehicle in my experience.
Good luck,
FREE-BUSINESSES.com
Oct 22, 2017 | Nissan Cars & Trucks
HOW TO UNLOCK YOUR FORD TAURUS GEAR SHIFT
Search Results
    Ford Focus Questions - the car starts up but i cant get it out ...
    www.cargurus.com > Questions > Ford > Focus
    CarGurusJan 26, 2013 - the car starts up but i cant get it out of park the button on the shifterwont ... point the shift interlock will allow you to shift to neutral and other gears with ...That should expose your shift lock over ride button. .... Used Ford Taurus".
    97 Ford Taurus gear shift stuck in park - Car Talk
    community.cartalk.com/.../97-ford-taurus-gear-shift-stuck-in-park
    Feb 7, 2009 - Over the past week, it has been difficult to get the gear out of park. ... 97Ford Taurus gear shift stuck in park ... LOCK, then remove the key. 2.
    Why Wont My Car Shift Out of Park - Shifter Interlock ...
    ? 3:49
    https://www.youtube.com/watch?v=ZdDsfNrabsM
    Mar 21, 2014 - Uploaded by BleepinJeep
    Only problem is if it fails, you cant get your car out of park. ...Those interlocks seem like they might be a solenoid that slides alock pin out so that you can move the lever freely. .... Someone told me it was possibly the Passing gear cable ? ... Ford TaurusWon't Shift Out Of Park, Brake Lights Don't Work With ...
    Car stuck in Park, shifter won't move. - DoItYourself.com ...
Jan 18, 2016 | Ford Cars & Trucks
We just purchased a 2003 mini cooper. It has 46k on it and it runs and drives well. It has an auto transmission 6-speed that also can be shifted
Because the window always stops in the same place, the motor does too. After a few years iot can start to jam in that position. Simply expose the window motor and give it a sharp tap while operating the switch. If that solves it then try to turn the motor round by a few degrees so that it stops in a slightly different place.
Jun 27, 2011 | 2003 Mini Cooper
What is the trick to removing the leg from a 25 hp johnson 2005, cant find were to disconect the shift linkage
Its either up under the cowl near the bottom of the powerhead, or you might have to put the outboard in gear using the lever to drop the leg an extra inch, which would then expose a shift linkage holding nut in the gap above the leg connecting point.
Oct 18, 2009 | Boating
Cant remove the motor
If you have a front loading machine:
You can try to remove the front of the machine, this will expose the drum and belt, remove the drum and belt and this will expose the drum rollers, motor, and idler arm assembly. Then you can remove the motor.
I hope this helps
Oct 03, 2009 | Roper RES7648E Dryer
My 92 wrangler will shift into 4high but not 4 low.It seems to have some air flow at shift motor. Does this mean I need a shift motor?
yes thats what it sounds like....Cant really be sure. Seems like you know your Jeep go with your first choice.
Oct 03, 2009 | 1992 Jeep Wrangler
Fan on a/c stopped ,bought a relay cant find its location even bought the book.
Relay is under the right hand side of the dash near the blower motor look for the exposed wires
Jul 16, 2009 | 2005 Chevrolet Silverado
Motor not turning drum but heaters working ok
Your belt may be stretched and is slipping on the motor pulley.Belt tension pulley may be sticking. May be a bad lint buildup on the blower wheel.
And yes, finally, maybe a bad motor.
Jul 07, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Saws Logo
62 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
