Question about Samsung Refrigerators
I have replaced defrost heater and defrost sensor in fridge but top still not cold and icing up at evaporator samsung srs584dp
    Novelist:
  • 187 Answers
It sound like your system is low on refrigerant. After you make sure the condenser is clean, and if you have a fan on the condensor that is is operating, check the temperature of the smallest refrigerant line coming out of the compressor about 5 or more inches from the compressor. This is the high pressure line and during normal operation should be around 140 degrees when fully charged. It is my experience about 5 percent of the mass produced refrigerators coming into this country is not charged properly and can cause the symptoms you describe. About 1 percent develop leaks and lose refrigerant. If your line is warm to the touch or barely warm to the touch, you will need to have your system leak checked and recharged by a competent refrigeration tech.
Hope this helps.
Posted on Dec 11, 2014
  • 1122 Answers
SOURCE: evaporator coil iceing
if you can put the frig. in defrost this will tell the sensor to turn on and you will see the heater melting the ice,if you can't put it in defrost and the sensor still has ice on it,simply put it in your hand,as your hand warms up you should feel the sensor pop,this pop tells the heater to turn off,if no pop the sensor is bad,if no ice on the sensor put it in a glass of ice,chill it down and do the same hand test,you can also use an omhs meter to check it,all the sensor does is open and close,let me know what you find-mike
Posted on Oct 30, 2008
tborn6
  • 700 Answers
SOURCE: Evaporator coil frosted up on Samsung RS267LABP Refrig side
TAKE AND DISCONNECT THE POWER TO TH UNIT AND ON THE VERY BACK THERE IS A CONTROL BOARD THE IS UNDERNEITH A WHITE PLASTIC COVER THAT YOU WILL HAVE TO REMOVE THEN DISCONNECT AND RECONNECT THE WIRES TO THE CONTROL BOARD AND SEE IF THAT DOESTHE TRICK.
Posted on Mar 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Fridge warm at top cold at bottom
If the fan is no coming on inside the freezer this will need to be fixed soon. Both fans upper and lower must run while compressor runs. Inside the fresh food compartment close the damper on bottom left side next to the paned drawer. If this does not help send more cold air to the top let me know as there could be something else causing the dampers not to open and close properly.
Thanks, Sea Breeze
Posted on May 29, 2009
MNTECH
  • 1543 Answers
SOURCE: I have a GE GSS25WGMD BB Fridge. I have already
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Posted on Jun 09, 2009
  • 5 Answers
SOURCE: samsung fridge rs52530bwp the fridge side will not work
Check the compressor fan and make sure it is working.
Posted on Jun 23, 2009
Possible problem with ice build up and fridge doesnt get cold enough to store food. Freezer works fine.
The noise is due to the ice build up in your evaporator. The evaporator fan blade is rubbing against the ice build up. This can is designed to turn off when you open the door. As far as the defrost problem it can be your defrost bimetal thermostat, the defrost timer/control or your defrost heater.
Nov 07, 2013 | Samsung Refrigerators
Ice build up in fan couling
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Sep 11, 2011 | Samsung RS2630WW Side by Side Refrigerator
Samsung RB215LABP bottom Freezer shows my set temperature of -2 but maintains at -15. If I cycle power it will show the actual temperature for a while (hours). We had a power outage in a storm and it blew...
Since the defrost problem wont just go away here are details about how it works.
DEFROST PROBLEM
Jun 01, 2011 | Refrigerators
Our westinghouse 6ED2FHKXRL 00 fridge/freezer is not cooling. The bottom of both the fridge and freezer are cold but the tops are warm. The freezer has ice at the bottom and water in the ice trays at the...
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer. Is the fan in the freezer working.
Dec 22, 2010 | Westinghouse Refrigerators
My refrigerator is not cold and my freezer is thawing out. the temp reads 37 freezer and 61 refrigerator. I have put them both on super cold and nothing. what could be wrong?
Nov 02, 2010 | Samsung 18.8 Cu. Ft. Bottom-Mount...
THE FREEZER IS ET TO THE DESIRED TEMP AND IS FULL OF ICE. WHAT DO I DO!!!
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
May 18, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
Hello, I have a samsung side by side fridge freezer (SRS597NP) that keeps icing up the fan and coils behind the bottom two draws of the fridge. It ices up that much that the fan hits the ice and makes a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} DEFROST PROBLEM
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Dec 27, 2009 | Refrigerators
Hello, my refrigerator is slowly getting less cold. We just moved in a month ago and in that month the refrigerator has stopped freezing ice and now is just not very cold...Help please?
Dec 12, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Fisher and Paykel N500B fridge freezer. Freezer not freezing
Oct 28, 2009 | Refrigerators
Frig gets cool but not cold, freezer cold, won't freeze
Oct 26, 2009 | Jenn-Air Refrigerators
Refrigerators Logo
73 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
