Question about Samsung Televison & Video
I have the samsung tv LE37A656A1 AND ALL THE PICTURE OF ALL CHANELS ARE WITH NO HELICATE AND CONTRAST AND THE HELICATE AND CONTRAST FROM REMOTE CONTROL IS NOT WORKING
THE BACK LICHT IS OK AND I HAVE ALL THE CABLE DISCONECT AND CONECT AGAIN
  • Samsung Master
  • 5,568 Answers
> HELICATE
Do you mean intensity or brightness?
Posted on Jan 12, 2015
SOURCE: Codes to operate a cable box with TV remote
Try code 038. If that doesn't work try 039.
Posted on Sep 08, 2008
SOURCE: ilo-32hd tv only 1 chanel
dude it just happened to mine it sucks!
Posted on Sep 29, 2008
mistersony
  • 320 Answers
SOURCE: KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Posted on Oct 19, 2008
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
SOURCE: virgin media remote control TV Control Codes Samsung LE37A558
just tried 0079 from another forum and it's worked for me!
Posted on Mar 30, 2010
Front Led Lights but No Clicking, Picture or Sound when I Plug it In.
If the front led is lit, the TV is on standby. Did you place the batteries in the remote correctly?
There might only be one button that turns the TV on/off (usually the red one in the top of the remote)
Did you plugin the picture feed cable correctly (VGA, DVI, Antenna etc.)?
Jul 06, 2014 | Samsung HP-T5054 Widescreen 50 Plasma HDTV...
Screen dim, black has green in it, contrast and brightness = shin
Since you have replaced the Color Wheel, it sounds like you have not adjusted the Index Delay in the service menu. First reset all of the picture settings you have adjusted back to original factory settings. Then on your Samsung TV Remote and with the TV OFF, Press Mute,Power,123. This will turn on the set and put you in the Service menu. Look for the top setting and select or scroll to the OPTION setting and select and look for INDEX DELAY and select that. Once you have the Index Delay selected use the right and left buttons on the remote to adjust for a picture the has no abnormal coloring and while looking at a program adjust for when the blacks look black with no abnormal coloring. Once that is done, turn off the set then turn the set back on. Now the picture should look normal.
Apr 03, 2010 | Samsung Televison & Video
Ch 9 picture froizen.has sound.cannot change
U have cable,some kind of pay tv?Tries unplug the cable box,replug the box for reset or to update new solfware for the box.If u have free air tv,get better antena like out side door antena or a digital antena.Also should change the batteries in ur remote and clean the IR lights both remote and tv make sure no blocking path to signal.
Oct 31, 2009 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
No sound on tv chanel
hi, no sound with tv but have picture, also have lost sky but works on other tv with a tv link, tv make LG Lh3000
Apr 22, 2009 | Logitech Harmony One Advanced Universal...
Picture quality on PT-50LC14
clean out the housing (where the lamp is) the go through your menu and check the tv settings ie...color temp, picture, contrast, ect...try resetting it back to the default and go from there
Nov 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Changing Screen Size on Samsung HP-R4272
you must not have the correct picture settings in the cable box, as although they are not HD they will still be widescreen, so check both tv and box for picture settings.
Oct 14, 2007 | Samsung HP-R4272 42 in. Plasma HDTV
Tv repair of Samsung standard tv
I have an LCD HD samsung tv,whenever I am watching my tv the picture goes out but i can still hear it.and have to turn the tv off and on again to get picture back.
Sep 30, 2007 | Televison & Video
27 inch Orion
the best way to do it is by having some color bars on Tv and then do the setting by eye. it is the best way to go. you have to adjust the brightness, contrast, color and sharpness. good luck
Nov 22, 2006 | Orion STV2763 27" TV
Televison & Video Logo
60 people viewed this question
Henry  Thomas
Henry Thomas
