Question about Digital Gadgets 1012345 Sili Keys Roll-Up Silicone Bluetooth Keyboard DGNOVRSBT
Using sili-keys roll-up silicone bluetooth keyboard DGNOVRSBT on AspireOne 722 running ubuntu 14.04LTS. Got keyboard to connect, but seems locked in NumLock mode.
All the function keys, FN + keys, Alt + keys
Bluetooth not detecting
Bluetooth radio is not "Enabled" in Device Manager. Turn it on.
Make sure is is detectable and Paired with the other device.
Jul 04, 2015 | Fujitsu LifeBook LH531 14 inch Notebook...
Zorin / Ubuntu 14.1 numeric keypad not working. keyboard definitely not at fault.zorin
Numeric sometimes doesn't work if "Num Lock" is not deployed. Push it!
Nov 07, 2014 | Computers & Internet
Acer 722 11.1 in netbook to factory settings
i use acer aspireone 722 netbook i dont no what the problem the online watch video is very slow motion ply ane audio correct but video problem only
Mar 08, 2012 | Computers & Internet
I have an Acer AspireOne D255 computer and the keypad only types numbers. Im using the On-screen keyboard. HELP!
Did you turn on your numlock key? try pressing FN + numlock key maybe this what is causing your problem.
Sep 06, 2011 | Acer Aspire 5100 Notebook
My toshiba satellite m45-s355 seems to be coughing up a weird problem.Whenever i press the shift key these characters - "NB~A" props up and the whole system goes awry.I can figure out that it's a...
like other prblem on keyboard it seems your fn key was stuck, it can caused the keyboard was dirty, just open the keyboard then remove all the key on your keyboard then clean it using alcohol wait until dry then set the key again
Jan 14, 2011 | Toshiba Satellite M45-S355 (PSM40U073001)...
Several keys on keyboard not working - Acer AspireOne
If you have warranty they can fix it for you, but if not, you can take the laptop apart, and clean the contacts of the keyboard youself. Which would be the same thing they would do ("they" the warranty people). But is not sure, you can take it to a repair shop for inspection.
Jul 14, 2009 | Acer NSK8458AN Keyboard
Acer AspireOne Keyboard Already Degrading?
check your mouse settings in control panel
and make sure they are correct
maybe they are set to sensitive
otherwise i would recommend setting back to factory settings
make sure ac power is plugged in when doing this.
I have the same pc and i have no problem like that.
let me know if this solved
if the problem persists after setting to factory settings i would return it for exchange.
please rate
Feb 15, 2009 | Acer Aspire One PC Notebook
Bluetooth & Nokia PC Suite
hi, i seems u have installed the B T correctly, now to connect to the internet u need to creat a DUN (Dial Up Networking) there you can provide the ISP dial up No. Username etc...if u can see a Bluetooth icon on the right bottom corner, right click on it, u will have a option for DUN there,once there u will figure it out..let me know..
Jan 09, 2008 | Computers & Internet
Digital Gadgets 1012345 Sili Keys Roll-Up Silicone Bluetooth Keyboard DGNOVRSBT Logo
48 people viewed this question
Top Digital Gadgets 1012345 Computers & Internet Experts
David Payne
David Payne
Are you a Digital Gadgets 1012345 Computer and Internet Expert? Answer questions, earn points and help others
