Question about Drills
My friend gave me a hilti T22, what kind of bits do I need for it?
  • 21 Answers
Is it a TE-22?
If so check out
http://www.bamanufacturing.com/page_ref_6.htm
Looks like TE-22 uses tapered shank bits
a TE-22P uses SDS plus shank bits
I'm not familiar with a T22
Posted on Jan 17, 2015
T22 disk read error
Sounds like the Operating System is corrupt. I would re-format the hard drive and re-install the OS that should solve the problem. If not then the Hard drive needs to be replaced.
Jan 23, 2012 | IBM ThinkPad T22 2647 Notebook
After inserting the bits into a Hilti TE76P, should the bits be able to move in and out about half an inch? The tool works fine, and the bit stays in place, but I noticed it moves like that.
Yes, the bit should have about 1/2" to 1" of free movement in and out when the gun is not running but should not be able to fall out of the gun when pulled on.
Jan 22, 2012 | Hilti Drills
Hi i have hilti drill machine i dont how to open and removed the drill bit,please help me
what you need to do is twist the collar of the chuck to remove bit and reverse the procedure to lock it into place.
Aug 03, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
My hilti te-75 drills but is not hammering or will not go into chisel mode whay coud be the problem with it
Have seen this problem with some 'none' HILTI bits which do not fit correctly into the SDS chuck.
Tends to be with larger drill bits which have a wider shank than the SDS connector, the wider shank hits the end of the drill nose which stops the end of the drill bit contacting with the internal hammer.
Solution is to purchase original bits from Hilti. If you have OEM bits and chisel it will be another problem. Hope this helps.
Feb 07, 2011 | Hilti TE 70 Hammer Drill Performance...
Te76 will run but will not hammer
THE TOOL IS LOW ON OIL. OR POSSILBE SEAL ISSUE, IT TAKES ITS OWN OIL, HAVE TO GET IT FROM HILTI!!! BE PREPARED YOU HAVE TO BUY A GALLON AT A TIME! IT HURTS!!! OR YOU CAN SEND IT TO HILTI AND YES THEY WILL BE MORE THAN HAPPY TO FIX IT FOR YOU OR GIVE YOU CREDIT TOWARD A NEW ONE, THATS HOW THEY WORK!
Aug 13, 2010 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Hilti te5 problems
go to Hilti.com and you can download a breakdown for this tool. Let me know if you need more help with the repair.
Mar 12, 2010 | Hilti Drills
NEED PARTS FOR HILTI TE 17
hi i have a 30 year old hilti te17, yes i know but its great but i need the bit holder ( chuck i think its called, the thing that hold the drill bit in for this hammer drill, otherwise its works perfect, built to lasst these things, but parts are hard to come by in aystralia, anyone help me if you can please
lulu
Mar 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
I am the owner of a TE 905 Hilti Jackhammer, Serial No. 234137, I need to purchase replacement brushes and a 14" long flat chisel bit for the Hilti Jackhammer
Did you contact the place you purchased it from? If you still have the paperwork that came with it might have the replacement part #s in one of the flyers. Google the make and model.
May 14, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Drills Logo
122 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
