Question about Jeep 2004 Grand Cherokee Limited 4WD
All lights are working except headlight. the fog lights, high beam, parker lights and spot lights are fine. fuses are fine but I can't find where the relay is for the head lights, can you help
Bulbs are fine, fuses are fine, there is no power getting to the light bulb
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
Problem may be in headlight switch/wiring. Check and replace as needed.
Relays may be inop, check/replace as needed.
Bulbs may be bad. check.
Posted on Sep 09, 2016
How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
Oct 10, 2016 | Volvo 850 Cars & Trucks
No low beam yet i have parkers & high beam
Many cars have a separate fuses for low beam, high beam, and the parking lights. Check your ow beam fuse.
Mar 05, 2016 | Cars & Trucks
Both high beams & fog light quit working
Check your owners manual for the location of the headlight fuse in the fuse panel. This is the most likely cause for both headlights and fog lights quitting at the same time.
Oct 03, 2014 | 1993 Olds Bravada 4WD Front Wheel Bearing...
Headlights not working on low or high beam
either main fuses under bonnet 60 amp for each side ir the light switch faulty ,also fuse in the interior fuse box but would have to blow around 6 all at same time so check the other first
Mar 01, 2014 | 2003 Renault Clio
Is my 2007 Lincoln Navigator (HID headlights) equipped with HIGH BEAMS? If so - they don't seem to work. Allow me to explain; 1. The headlights come on automatically in low light conditions. 2. The...
First of all are your headlights a double filament type headlight? If yes then I would suspect that a power wire to the high beams is broken or shorted. If your high beams are a separate set of lights from your regulars running lights then either the high beams headlights are missing. or has a broken power wire or shorted or...You could check the fuse box under your dash and under the hood of the car to see if you have a fuse for the high beam lights.
Oct 28, 2013 | Cars & Trucks
High beam indicator comes on with fog lights
Could your Mazda have daytime running lights? If you checked all fuses, did that include the three in the joint box?
There is an auto light-off control module that is central to all functions you describe. It is assumed that you would only turn on the fog lights with headlights on and set for high beam. If you set the headlight switch to LOW, the module closes the headlight relay to turn on the low beams. If you then turn the headlight switch to HIGH, the module turns on the high beams and allows you to turn on the FOG LIGHT switch, closing the fog light relay and turning on the fog lights. Since this sequence is not working, I suggest checking both high beam lamps as both could be burned out. Other possibilities are a defective headlight switch or the module
Oct 01, 2012 | 2005 Mazda 6
Dodge charger fuse box , where the fog lights relay goes ?Thanks
Cavity/ Fuse /Circuits
1/ 20 Amp Yellow/ Left High Beam Headlight
2/ 20 Amp Yellow/ Right High Beam Headlight
3/ 15 Amp Dk. Blue/ Adjustable Pedal
4/ 20 Amp Yellow/ Horn
5/ 25 Amp Clear/ Headlamp Washer - If Equipped
6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
7/ 20 Amp Yellow/ Fog Lamp
8/ 15 Amp Dk. Blue/ Park Lamp
9/ 15 Amp Dk. Blue/ Non ABS Brakes
10/ 5 Amp Orange/ Starter
11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
12/ - -
13/ - -
14/ 25 Amp Clear/ Powertrain Control Module
15/ 20 Amp Yellow/ Injectors, Ignition Coils
16/ 15 Amp Dk. Blue/ Powertrain Control Module
17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
18/ 30 Amp Pink/ Windshield Wiper/Washer
19/ 50 Amp Red/ Radiator Fan
20/ 20 Amp Lt. Blue/ Starter
21/ 50 Amp Red/ ABS Pump Motor
22/ 40 Amp Green/ Radiator Fan High/Low
23/ 50 Amp Red/ High Intensity Lighting
24/ - -
25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
26/ 20 Amp Lt. Blue/ Transmission
27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
if this helps please rate 4 thumbs up.
Jan 21, 2011 | 2007 Dodge Charger SRT8 Sedan
Electrical problem after battery replacement.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
Apr 04, 2009 | 2002 Dodge Intrepid
Jeep 2004 Grand Cherokee Limited 4WD Logo
215 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
David Littlefield
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
