Question about Dryers
How do I stop dryer from squealing
When I put a load to dry the squealing noise is loud and annoying
  • 2,760 Answers
The squealing noise is most likely a loose drive belt , the drum is powered by a large belt to a motor , the belt and idler pulley are most likeslyin need of replacement
Posted on Dec 11, 2014
  • Dryers Master
  • 3,289 Answers
Hi Martha,
The squealing can be coming from a number of places. It could be the belt, a bearing in the motor or for the drum or tensioner pulley for the belt.
Unfortunately, all these items requires tools and partial disassembling of the machine to make checks or repairs. The squeals - if coming from any of the the bearings - can be an indication of impending failure. This is usually the case for older machines or those that get extensive use / frequently overloaded. Many times, replacing drum bearing isn't worth the cost of repair and motors are swapped out completely rather than replacing bearings - basically, they're designed to last the life of the machine.
A belt can slip on the drive motor sheave, drum or tensioner pulley - this last item is the most likely source of the sound and the least expensive to replace. I'd have a replacement belt and tensioner pulley on hand before starting this work and would replace both while I was "in there" if I were you. You will need to take the front of the machine off, inspect the belt and belt routing though the tensioner, etc. and then remove the belt and drum. Replace the both parts and reassemble.
You should search youtube.com for "belt replacement <brand / model> dryer" for some how to videos. I caution AGAINST attempting to make repairs on GAS or LP fueled dryers that require moving the machine or disconnecting fuel lines.
Dryer makes a loud squealing noise when I try to dry a load of clothes, towels, anything
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 11, 2011 | General Electric G.E. DBXR300EGWS 6.0 Cu....
The dryer is squeking very loud when turned on
Hi
Check white pulley on idler arm. Also check condition of the four glides around door bearing. A dry rear bearing ground strap will cause an annoying squeal also. Lubricate with a high temp grease to stop noise. Have to pull the drum to get at it. Check the rollers if its worn or not.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 01, 2011 | Dryers
Loud noise as the tumbler is drying
Front or rear? Rear is probably center bearing. Fornt is front tub wheel or glide worn out. If noise is in front remove front and inspect.
Jul 19, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Really loud whirring/squealing noise
Yes, It is still safe but very annoying...
The source is probably the guide rollers for the drum or the belt tensioner pulley. To know for sure you will need to pull the dryer apart and turn it by hand slowly and see where the noise is coming from...
Heatman101
Mar 03, 2010 | Whirlpool Dryers
Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
May 21, 2009 | Maytag Dryers
THE DRYER STARTED MAKING A SQUEALING NOISE AND THEN IT STOPPED AND WOULD START AGAIN AND SOMETIMES IT WOULDN'T MAKE A NOISE BUT NOW IT'S SO LOUD THAT YOU CAN'T STAND TO HAVE IT ON.
you may have to take it apart and check two things...
1. the motor on dryers can get pluged with dust and lint and dry out. the motor bearings may simply be dry. it might be too late for the motor, but you could try lubing the motor bearings and at least stop the squeal for a while.
2. remove the drum and lubricate the wheels or bearings that the drum rides on.
lubricate all rollers and belt guides as well.
hope this helps..........jay
Mar 21, 2009 | GE DBSR453EBWW Electric Dryer
Kenmore gas dryer 97273100 was drying, but making a loud noise
You need a belt. Here's a link to a site with a good set of instructions if you want to try repairing it yourself. (You should DIY. You can save a bunch on the service call and the belt is only about $20.)
http://repair2000.com/wpoolbelt.htm
Dec 08, 2008 | Kenmore 72982 Gas Dryer
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Dryer makes a loud noise then stops
If it stops running when hot it may be the motor. The belt or drum rollers would not stop it from running.
Dec 23, 2007 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
100 people viewed this question
Top Dryers Experts
