Question about Yamaha Audio Players & Recorders
No sound from yamaha subwoofer yst-fsw100 using rxv373 a/v receiver
Checked all connections, the subwoofer is new,
  • 238 Answers
SOURCE: Yamaha YST-SW150 Subwoofer
hi, is it a humming noise ??? check if the connector is plugged in properly,check the earthing, if its a three pin mains plug, if its a two pin, then the CPU SMPShave a proper eathing. let me know
Posted on Jan 12, 2008
SOURCE: no sound from yamaha yst-sw105 subwoofer, stand by
The audio amplifier IC for the subwoofer are damaged and need to be replaced
Posted on Jun 12, 2009
walesarumi
  • 6993 Answers
SOURCE: Yamaha YST-SW320 subwoofer won't play sound
I too have amplifier and speakers thatI rent for parties, and sometimes when I connect them they don't work and I battle with them for hours before I find the out that its just a little thing that happened, like speaker wire might have cut inside, or the wire conneted for the CD to Amplifier is bad and son on.
But I will advice that you test your amplifier and woofer, with another equipment independently to be sure if they still working well or not. As this will help you to know what to do next.
May somthing happened to one of them the last time you used it and you did not notice, and it might just need some servicing.
Best wishes
Posted on Nov 13, 2009
Marinmeister
  • 11 Answers
SOURCE: i have a problem with my yamaha subwoofer yst sw
could be a problem with one of the filters inside or a short circuit... your best bet would be to have someone skilled in electronics look at it, and stop using it as you may permanently damage your speaker.
Posted on Jan 15, 2010
SOURCE: need a schematic for a YAMAHA YST-SW315 subwoofer
contact me direct at xxbratfry@live.com do not use the xx.
Gary
Posted on Jan 19, 2010
I obtained a pair of Yamaha YST MS50 speakers with no subwoofer. Can they be adapted to use a different sub, such as the inexpensive Yamaha YST MSW5? The clear problem is in different cabling.
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 03, 2016 | Yamaha YST-MS50 Computer Speakers
Yamaha yst-sw012 power but no sound
The problem is the Ic or transistor use a tester
Jan 14, 2013 | Yamaha YST-SW012 Subwoofer
No sound from my Yamaha YST-SW315 subwoofer. When I run the test speakers don't have sound either. Not sure if its the subwoofer or the Yamaha RX-V450 receiver
Feed it with an RCA cable any other audio device you may have (CD, TV, MP3 player, PC) to prove it can or can not woof. It will respond to any audio, not just LFE or subwoofer audio.
Apr 14, 2011 | Yamaha YST-SW315 Subwoofer
I want to connect my Marantz 1030 amp to a yamaha YST-SW012
use the left input on the sub. It acts as the main input. Hope this helps
Nov 19, 2009 | Car Audio & Video
I recently purchased a yamaha YST-FSW100 subwoofer and plugged connected it to my HTR 6140. Subs woulld not work. How will Iknow which devise is not working?
Turn the sub on, then touch the end of the sub lead when you take it out of the back of the amp..it should buzz to show the sub is ok . If the sub is ok then go through the setup on the Yamaha and tell it there is a sub connected in the speaker setup.
Nov 07, 2009 | Yamaha HTR-6140 Receiver
81 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
