Question about Garden
How do I check the transmission fluid level in a Cox Kingcat ride on mower What grade do I use to top it up
Transmission is a transaxle hydrostatic Tuff Torq model K46
  • 1,169 Answers
Depends if your has an external expansion or not. Normally you do don't need to check these transaxles as they are considered sealed units but if you wish to do so the following is the two documents from Tuff Torq on how do it.
K46 OIL 1
CAO46 External
Posted on Dec 11, 2014
Craftsman Hydrostatic Transmission Fluid Change on a Craftsman tractor Model Number 917.289720 What kind of fluid do I use to change the Hydrostatic Transmission Fluid?
Best to Call Sears on this, we have never been asked this question and have no for sure answer. If I must guess I would say Dexron 6
Sep 28, 2016 | Craftsman Garden
Craftsman riding lawnmower, model #917 259012 hydrostat stopped working
Check belts. Check transmission fluid level if possible. Check linkage between shifter and transmission. Check belt tensioners under unit above deck.
Jun 15, 2014 | Peg Perego My First Craftsman Tractor...
There is a grinding noise when i make a sudden stop or go in reverse.its a hydrostatic transmission
ck and clean off the cooling fan on top of transaxle sometimes grass and leaves get up there and make funny noises also you can ck oil level in transaxle for proper fill level
Nov 11, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Husqvarna 24hp VTwin Hydrostatic 48' cut riding lawn mower will not move either direction.
I would check the drive belt going to rear end if not that I would check fluid level in transmission.
Aug 04, 2013 | Husqvarna 24HP VTwin Hydrostatic 54" Cut...
Transmission fluid low, hydrostatic transmission will not run in high position, where do i fill fluid
Quoted from your Owners Manual. . . . .
TRANSAXLE PUMP FLUID
The transaxle was sealed at the factory and fluid maintenance is not required for the life of the transaxle. Should the transaxle ever leak or require servicing, contact your nearest authorized service center/department.
Oct 29, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Checking fluid level
most units of this size & quality have a factory sealed transmission. to check or change oil, the transmission would have to be removed.
Sep 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hydrostatic drive squeels and stops pulling when hot
I had a similar thing go wrong. Even though the hydrostatic drives are designed so that the fluid doesn't need to be changed, If it is a hydrostatic transaxle check to see if it is leaking,if it is then there really is no repair to transaxle. If it isn't leaking then It sounds like the oil in transaxle is worn.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 Allen wrench fitting on top. You will need to purchase suction bulb and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion
Aug 13, 2009 | Mtd Garden
Husqvarna, GTH2454T Hydrostatic power loss.
It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 alllen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
Jun 29, 2009 | Husqvarna Garden
How do I check fluid level on YTH150 Hydrostatic Transaxle?
My Husqvarna hyrdrostatic transmission is sealed, and yours may very well be also. That means no changing the fluid.
May 13, 2009 | Husqvarna Garden
Change hydrostatic transmission oil
we have tractors and, yes any of those drain bolts will work (for best results do both) then after its drained, put the drain bolts back in and top up the level
Oct 27, 2008 | Husqvarna Garden
Garden Logo
239 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
