I have a LG turbodrum 10.0kg. It stops and shows dE when spinning despite the cover is closed. How can I fix it?
    Problem Solver:
  • 10 Answers
DE means door is not closed properly
Posted on Dec 11, 2014
drsn
  • 42 Answers
SOURCE: I KEEP GETTING A dE
you will need to replace the door sensor, this error will appear until it has been replaced. it is inside the unit and pretty much hard to get to if your not familiar with workin on it. take it to an LG tech or some one whos familiar with it..........
good luck LG's are very sensitive.
drsn777@hotmail.com for more info.
Posted on Dec 15, 2008
SOURCE: Our washing machine is LG Turbodrum i sensor.
My Turbo Drum Isensor is Beeping and shows dE..what is wrong and how do i fix it?
Posted on Nov 14, 2010
  • 6277 Answers
SOURCE: My LG Turbodrum DD WT
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 19, 2011
SOURCE: my LG Turbodrum DD will not drain
Get a new machine. LG washing machines are ****. I have the same model and it has broken down and made horrible noises for years. It finally just stopped working. RIP
  • 6277 Answers
SOURCE: E2 error comes up on
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
John C
Posted on Mar 05, 2011
My LG Turbodrum WF-T7030Tp will not spin.
The LG's typically have a "gearbox" that cannot be fixed if it breaks. You'll have to check with an official dealer. I had a similar problem and in the end it turned out the gearbox would cost more than the whole machine (distribution network fail??).
How old it your machine?
Dec 06, 2014 | LG Washing Machines
Lg Fuzzy Logic 5.5kg Turbo Drum with I-sensor, Model WF-T552TH Washing machine goes through initial fill up, when changing to spin/wash works for 2 seconds, then stops spinning back and forth and shows dE...
There is a small magnet at the front of the lid that triggers the door error, mine was corroded and the lg people wanted $80 for a service fee.. Ha I went to my local hobby shop and got a small earth magnet and some super glue $1.50 later and she's fixed.. tadAaa.
May 11, 2011 | Washing Machines
My LG Machine spin for a while then stop, showing DE on the screen. May i know how to solve this ? Thank you.
'DE' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Apr 28, 2011 | LG Washing Machines
My LG Turbodrum DD will not drain
Feb 11, 2010 | LG Washing Machines
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
