Question about Tablets & eReaders
How do i get my tablet screento rotate
In had tryed going through the settings and everything it justbisnt turning at all like it should what do . Do?
    New Friend:
    Problem Solver:
  • 4 Answers
What type of tablet? If it's an iPad this is available a few different ways.
If it's an iPad 1 running on iOS5:
1. Check the little toggle switch on the side, depending on your settings this functions as both a mute and a rotation lock. Try changing this.
2. If your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Double click the home button and when the little menu pops up swipe right on it, you should see an option to lock/unlock the rotation.
If you are on a newer iPad
2. f your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Swipe up from the bottom of the screen to access the control panel. The screen lock/unlock option is directly on the control panel.
Posted on Dec 11, 2014
How to get my tablet to start rotating again. It is set to auto rotate but it won't stop working.
This varies by operating system which is why it is a good idea to post the brand, model, and operating system with a query.
For a Samsung Galaxy 10.1:
Type apps is the upper right corner. Then tap Settings from the all tab. Then in the left menu, tap screen. Then, tap auto rotate
For the Inspiron Dell 2-in-1 with Windows 10:
Go to Control Panel> Display>Change Display Settings and then make sure that the "Allow the screen to auto-rotate" is selected. Or try the following: Place the tablet into Pad/Tablet mode.
Click the Start Start menu and select Settings. Click System.
Click Display. Scroll down and toggle Lock rotation of this display to ON.
Or this might help:
Click the Start Start menu and select Settings. Scroll down and toggle Lock rotation of this display to OFF.
Nov 26, 2017 | Tablets & eReaders
I dropped my tablet and now everything is backwards words,screen,everything help
Hello! you might need to calibrate your tablet`s sensor, if that doesn`t work please turn off the auto rotation on your tablet, and then reboot your tablet. if that doesn`t work, please do a factory reset on your tablet by pressing power button + volume down, your tablet will go into recovery mode and look for factory reset.
Jul 29, 2015 | Tablets & eReaders
How do I get my ASUS Android tablet screen to rotate?ASUS AndroidTablet
The settings icon is what you want to use, then display. There is the setting for when the screen rotates (i.e. shaking, turning etc.).
But individual apps may decide that they want to turn this facility on or off.
Mar 01, 2015 | ASUS Tablets & eReaders
I have tried everything I know and my iPad still will not rotate?
It is probably "locked" and you should go to Settings and ensure that the setting "Use slide switch for" is set to Mute and not Lock Rotation.
If it is set to Lock Rotation, you need to use the side switch to off to allow rotation to happen.
Nov 24, 2014 | Apple iPad Tablets & eReaders
My screen on my tablet won't rotate and it's turned on in settings and notifications
Try going to Settings - Display and making sure you have Auto rotate enabled.... also settings - Accessibility might have the option as well, then turn tablet off completely for 1 minute then power on!
Oct 26, 2014 | Samsung 16GB Galaxy Tab Pro 8.4" Tablet...
How do i rotate screen on my tablet?
You should be able to just turn the tablet on its side an the screen would auto rotate but if not go to settings an select screen settings/display an change the setting to auto rotate.
Aug 13, 2014 | Tablets & eReaders
Acer how to setup
You are looking for an option called Rotation or Rotation Lock (varies by Android version and tablet). Once you find it, orient the tablet so it is in landscape mode, then turn off rotation. If you do not have an option on the bar at the top of the tablet (top pull-down you get by sliding down a finger from the top of the screen), then go to Settings, Display, and look for Rotation, Rotation Lock, or Screen Rotation.
Jul 17, 2014 | Acer Iconia A1-810-L888 7.9 inch MediaTek...
Allwinner A20 dual core android tab screen want rotate
Allwinner A20 is a name of a processor, so I'm not sure what tablet are you using.
There is an option to block rotation, for example if you want to read an e-book while laying on your back. Go to settings and try to find an option to unlock rotation.
Also, some tablets have a hardware (physical) switch on the side that locks rotation.
Jan 17, 2014 | Samsung Galaxy Tab Tablet PC
Auto rotate
Sometimes there is a second option called screen lock that keeps the screen from rotating even though you have auto rotate checked. Check thru your setting to see if you can find this.
Jan 10, 2014 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
Tablets & eReaders Logo
178 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
