Question about Ruud UBHC Air Conditioner
How do I get my AC running again? Ruud UBHC AC unit isn't running. Started yesterday or today.
Noticed heat wasn't working this evening. Checked breaker, everything was fine. Thermostat reading correctly. Changed it from Heat to AC, no change, only a quiet click from the thermostat. Set the thermostat control for the fan to On, nothing but a click. Checked outside and the fan outside isn't running. Any ideas or suggestions???
    Master:
  • 571 Answers
Sounds like there is no control voltage. Either the transformer to reduce the voltage from 110 volts to 24 volts is not producing the 24 volts needed for control voltage, or most furnaces have a small 3 or 5 amp fuse mounted on the main control circuit board that may be blown. Other "outside circumstances" may involve a break in the thermostat wire...more than likely the red wire if you are getting nothing to work. I have seen evidence of "critters" that have chewed through the low voltage thermostat wiring that would keep the thermostat from controlling anything. To check this, go to the furnace and jumper the red & green wire to get the fan running just to isolate if it is a thermostat wiring severred. Good Luck.
Posted on Dec 13, 2014
    Master:
  • 495 Answers
Some a/c units have a door switch. If the service door or cover is removed, it will deactivate the unit. Sometimes this switch will not make contact, become temperamental or door is not installed correctly. If it has this feature, you will need to push it in manually or bypass it, or replace it if bad.
Posted on Apr 28, 2015
  • 38 Answers
Check the breakers and the switch at the top of stairs to see if someone shut off by mistake
Posted on Dec 11, 2014
watugot
  • 290 Answers
SOURCE: Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Posted on Nov 20, 2007
ACTECH
  • 80 Answers
SOURCE: is ruud heat pump model upka-042jaz a single or multiple stage pump?
I NEED THE MAKE AND MODEL OF THE T-STAT TO HELP YOU
DID HE CHANGE ANY WIRING?
Posted on Jan 17, 2008
  • 108 Answers
SOURCE: Outside unit clicks while thermostat auxiliary light flashes
Sounds like the compressor starting relay or capacitor is defective. When the compressor could not start, the electric heat came on to satisfy the heat requirement and causing the emergency heat light to come on at the thermostat. This light warns you that electric heaters are energized. And they use a LOT of electricity! Call a different company for service. And do it soon.
Ray
Posted on Nov 16, 2008
  • 37 Answers
SOURCE: fan running constantly in the house
Check t-stat and make sure fan is set to "Auto", that might be why fan is running all the time, or it could be a fan relay that is stuck closed. It sounds like you A/C is over charged or you have a bad high pressure switch, this was a common problem with this manufacture especially in the heat mode.
Posted on Apr 25, 2009
  • 1252 Answers
SOURCE: Ruud Achiever 10 heat pump - outside fan won't shut off
Definately get this checked out. Some thing has shorted just enough to let voltage "Feed back" and keep the fan running. Could be capacitor, wires rubbed through each other, etc. A reset is a safety that is used when there is an overcurrent or over pressure situation. No reset set for this situation.
There is always an outside chance that if you touch the unit while standing on wet ground, you may get shocked. I firmly believe that something is allowing power to the fan in a feedback condition so don't let this go as it may cause damage to other parts.
Good Luck and let me know how you make out on this.
Posted on May 11, 2009
Is a RUUD UBHC-14J11NFH a heat pump?
Ruud UBHC-SERIES is a HEAT PUMP AIR HANDLER
AND FAN COIL UNIT
Compressor and condenser not included
Spec sheet go here
http://yaunco.com/pdfs/rheem/ubhc_specs.pdf
Jul 04, 2014 | Ruud UBHC Air Conditioner
I have a ruud model no. ubhc-17j11nfd and i am having a problem with my heat. when the heat does come on, the thermostat says it is on auxilary heat. i am getting no suction from inside the house but the...
If you haven`t changed your furnace filter do so. If there still isn`t any air flow then the evaporator coil is plugged with dirt and needs cleaned. It is inside your furnace where the pipes from the outside unit connects. As far as the auxilary heat, this is normal when the house temperature drops to far below the thermostat set point and they will turn off when the house is close to temperature and lets the heat pump take over.
Feb 02, 2011 | Ruud UBHC Air Conditioner
Fan on outside heat pump wouldn't spin put in new cap and started working when got off work it wasn't spinning again
I have a ruud gas pack, the blower fan wont come on. If we go out there we can spin it and she will run, but when the time shut off, so does the fan.. and it wont restart
Jan 28, 2010 | Ruud UBHC Air Conditioner
Heat/AC unit will not kick on.
sounds like spark ignition coil bad the little fan combustion fan will run even after a fail ign attempt.
turn off power/restore power the unit will try to fire the part is easilly avail and easy to replace
Jan 18, 2010 | Ruud UBHC Air Conditioner
Ruud UBHC AC System - Provides no Aux Heat
Tried this on my unit today, and observed the same results, but got Aux Heat (with A setting), if the H (blue wire) connected to B terminal, as per instructions for my 6036 Ritetemp. However, in this case, when the set temp is reached, I hear the click, but HVAC still blows aux heat indefinitely.
I also have RUUD UBEA 17J10..., and replaced my old honeywell with 6036, and can't get heat pump working. Both of my units are 14 years old, so I'm thinking to replace them soon.
Jan 06, 2010 | Ruud UBHC Air Conditioner
May 11, 2009 | Ruud UBHC Air Conditioner
Ruud Heat Pump blows room temp on Heat and AC setting
A "Heat-Pump" is also known as a reverse cycle air conditioner, this means on heat the outdoor unit acts like the indoor section and vice versa. So in all probability you need to have it leak checked and recharged.
Apr 27, 2009 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
170 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
