Error code 1007
I try to print and it keeps saying it needs paper or load paper in the in the upper cassette??
  • 778 Answers
Hello, Check to make sure there is no paper stuck in the printer somewhere in the paper path. It could be just a small piece as well. Also, try powering down the printer and cleaning it out with a can of air.
Posted on Dec 11, 2014
Support code 1007
Make sure you selected the correct paper tray (rear or cassette) in 'Printer properties' on 'Maintenance' page. If the correct tray is selected, try adding more paper.
Feb 24, 2015 | Canon PIXMA Wireless White Photo...
My Epson Artisan 7-110 keeps trying to print to cassette 2 (small cassette) even when copying A4. A4 paper is loaded in Cassette 1. Why?
If its not a setting problem, it may not be communicating with your computer properly, try turning it off, wait a little while and turn it back on, if that doesn't work delete your printer off your computer and re install it, Is it the default printer on your computer? some times if you run more than one printer from your computer there's a conflict which can make it behave in weird and wonderful ways.
Sep 22, 2014 | Epson Artisan 710 AllInOne InkJet Printer
I Have an EPSON Stylus TX700W Printer , & am having problems getting it to feed paper. Have tried all the Paper Jam solving problems to no avail. Printer just keeps saying "The Paper Cassette is...
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
Jul 10, 2011 | Office Equipment & Supplies
Paper cassette is not seated correctly. check for paper or objects blocking the cassette path. reinsert the cassette and press Start. keep getting this message. started after printing and installing...
I had this same problem and tried everything (I thought) to fix it. Then I saw the solution at:
http://www.retrevo.com/c/sohohelp/blogs/show/6633/I-just-had-my-espon-artisan-800-replaced-and-the-refurb-keeps-saying-that-the-paper-cassette-is-not-seated-correctly#replyForm
Basically there is a plastic pin that tends to break off and stays in the area where the cassette is loaded. It takes up just enough space to keep the cassette from being pushed in all the way. The solution is to turn the printer off, unplug it, then lift up the printer so the broken pin falls out. Once it comes out, the printer will work fine again.
May 12, 2011 | Epson Artisan 800 All-In-One InkJet...
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
We have a printer (MX870) that keeps giving us an error stating: there is no paper. There is paper in it but we cannot get it to print...it continues to give us the same error
From the service manual about the paper issue this is what it says:
***Rear tray. There is no paper. Load paper and press [OK].
Confirm that the rear tray is selected as the paper source. Set the paper in the rear tray, and press the OK button.
***Cassette. There is no paper. Load paper and press [OK].
Confirm that the cassette is selected as the paper source. Set the paper in the cassette,
Hopefully its just a setting on the printer or the computers printer properties.
Best of luck..
Jul 06, 2010 | Canon PIXMA MX870 Wireless Office...
WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A CANON MF3240 . WHAT DOES THIS MEAN? THANK YOU
I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
Jan 18, 2010 | Canon Office Equipment & Supplies
Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Jul 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
105 people viewed this question
jasbo
jasbo
