Does anyone know how old a whirlpool washing machine with a model number of wtw5700swo would be and what it's capacity is?
  • 3,506 Answers
No but you would likley find this out at an appliance parts and service depot.
Posted on Dec 11, 2014
jsrock516
  • 5911 Answers
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
Posted on Apr 14, 2008
  • 1028 Answers
SOURCE: Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
Posted on Aug 07, 2008
  • 1028 Answers
SOURCE: Lint build-up on clothing after coming out of washing Machine
ck to be sure drain hose is not more than 6-8 inches into standpipe ..standpipe is 30-36 inches to top from floor ..drain hose does not fit too tight in standpipe any of the above conditions may cause water to siphon out during wash or rinse resulting in not enough water in tub to carry lint away during drain
Posted on Sep 05, 2008
  • 16 Answers
SOURCE: LE error
try using a-fresh its should help you out.
Posted on Nov 03, 2008
  • 130 Answers
SOURCE: Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Posted on Feb 16, 2009
What is the rated capacity for a Whirlpool Duet Sport Washing Model WFW8300SW02 Type 831
Capacity = 3.3 Cu Ft
Whirlpoolcorp.com download manual:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WFW8300SW0&siteCd=WHRCOM&userType=Consumer#
The breakdown for Whirlpool Serial Numbers is:
1st Alpha Character = Manufacturing Division Code.
2nd Alpha Character = Year Manufactured (See Tables).
1st and 2nd Digit = Week of Year Manufactured.
3rd though 7th Digit = Order of Manufacturing that Week.
http://www.electrical-forensics.com/MajorAppliances/WhirlpoolDateCodes.html
If this was helpful, please rate post
Sep 13, 2014 | Whirlpool duet Washing Machines
What capacity is a Whirlpool Model ED2FHEXMQ00
it should say where you find model number or put into google that number you put up here on fixya and add the words cubic feet you should get an answer i wated to know the rpm spin ov my washer got it this way just yeterday or a day before
May 20, 2014 | Whirlpool Refrigerators
Whirlpool super capacity plus (commercial quality top loader) does not spin on all settings and does not spin fast enough
sounds like you have a worn out clutch. depending on model it could be an easy fix. would need to know model number to know for sure.
Apr 03, 2013 | Whirlpool Washing Machines
I have an old kenmore washer, on which I cannot find the model number. It needs a new drive belt. The only information that I have is that it is marked as a Kenmore Heavy Duty 80, and inside the door is...
Go to a local Sears or Whirlpool store and tell them you have an old "belt drive" Kenmore washer that needs a new belt. All of these were built by Whirlpool Corporation and I believe used a common belt.
Good luck.
Mar 25, 2011 | Washing Machines
Need APPROXIMATE water consumption on 10 yr old Whirlpool washer
Hello. The older top load washers use up to 60 gallons of water per load. That said, also check your toilets as a leaking toilet can use tens of thousands of gallons per year. Here is a link that explains how to check your toilets and other items for leaks. Regards, Joe
ps - kindly rate my answer as helpful. thanks.
Feb 17, 2010 | Washing Machines
Feb 15, 2009 | Whirlpool Washing Machines
Sep 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag (Super Capacity) Front Load Washer Manual needed
Click on 'washing machines' (below FIXYA) on this page, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is.........& rate me pl.
Apr 26, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
