Question about Hardware & Accessories
How do I set the clock? The included instructions for setting the clock do not work. I can set all the programmed on & off times, days of week, etc., everything except the friggin' clock. The cl
The timer is installed correctly & otherwise working fine, all 4 wires (hot, load, neutral & ground) are present and connected to their respective terminals. Programming was also fairly simple. My only problem is that I am unable to set the current time. (Year, Month, Date, Day, hour & minute). The instructions for setting the clock are clear, but those instructions do not work for setting the clock. The "time" button appears to be no-op. Also the link that someone here is referring folks to is **not** the correct link for the current model of this timer even though the model # is identical. The instructions you are linking folks to apply to an older model (which has the exact same model number) but completely different instructions and the buttons aren't even the same.
  • 5,245 Answers
Give us the model number so we can see what you're talking about. Tell us what link you have tried, and how the instructions seem to be different.
Display showing no-op is sometimes associated with defective timer, bad battery. Resetting timer will clear memories and restore functionality in some cases.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#digital
Attach photo of timer, or description of timer.
Add if this is new timer or if timer worked before, and what load the timer controls
Do you have correct instructions for timer ?... scan the manual into .pdf format. and then post the .pdf manual on your website .... then post link here to assist other folks with same problem.
Gene
Water Heater Timers Save Money
Posted on Dec 12, 2014
Testimonial: "Thanks Gene - I thought I had included the model. It was the UtiliTech #0141224, for which the link provided is not the correct model, as the instructions for this newest version has substantially changed. At any rate, I exchanged it for another identical unit and the replacement works fine, so the original was defective. Thx."
SOURCE: vigoro water timer 196 036 water timer programming
every x days vs every x hrs. (once a day or every 12 hours)
Posted on Jun 29, 2009
SOURCE: I have a Et 70115C
A) 5 terminal ET70115C.
Voltage selector set to 240.
B) BUT you say you have 120Volts from breaker >>> confusing, so I'm proceeding on basis that you meant to say 240V from breaker.
Add a comment at any time.
C) Review timer:
5-terminal ET70115 timer has NO and NC terminals
NC is normally closed >> this terminal has power when timer is OFF
NO is normally open >> this terminals has power when timer turns ON
For water heater, you want NO terminal 4 so water heater turns ON when timer turns ON
D) Wire for 240Volt water heater
Two hot wires from breaker connect to terminals 1 and 2. This powers timer clock.
Jumper wire connects between terminal 2 to terminal 3. This sends power to the switch circuit.
Wires to water heater connect to terminals 1 and 4
E) 5-terminal timer turns off 1 hot wire to 240V water heater.
Turning off 1 hot wire will stop 240V circuit from working; Water heater thermostats also turn off one hot wire.
240V water heater has black and red wire.
Wire from terminal 4 should connect to Black wire on water heater.
Diagram shows two wires on terminal 1
Two wires on terminal 2
One jumper wire on terminal 3
One wire on terminal 4
Zero wires on terminal 5
Posted on Dec 03, 2010
SOURCE: Instructions to set Woods indoor timer 59377
Open following link to identify timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
To set current time, press and hold clock button while pushing hour and minute buttons.
Then release clock button
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 12, 2011
SOURCE: Help!! I have a TRAC
I research and test timers and would enjoy discovering what timer you have.
1) Open following links to identify same-similar timer and download manual:
Add a comment and say which (if any) match your product, and which are similar.
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://waterheatertimer.org/UPM-timers-and-manuals.html
2) Add a comment and include photo of your timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
3) Add a comment and describe each button in sequence, and how buttons are arranged, and if this is plug-in or in-wall timer, direct-wire, or box-type timer, indoor-or-outdoor. Include approx size of timer and if it has 2 or 3 prong outlet, if timer has outlet.
4) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Posted on Mar 23, 2011
SOURCE: just installed a in-wall digital
Woods 59018 single-pole 7-day 7-program timer, color white:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
I test timers and 3-5% arrive defective, and they never work. Some stop working within 1 year, and some last quite a while.
Timers are affected by line interference and polarity issues. So wiring in home has to be correct before timer will operate as expected.
Timer has to be installed correctly with each wire correctly connected.
Press manual override button and see if lights turn on-off. This will indicate if your timer is wired correctly. If lights do not turn on-off with manual override, the open link above for wiring instructions.
To begin programming, reset timer by pushing in the round reset button with toothpick or paper clip.
12:00 am Mon should display.
If the above items are all correct, then defective timer is suspect.
If you try multiple timers, and each timer has same problem, then line interference or bad wiring is suspect, or you are buying from somebody who has a bad batch of timers.
Try wiring same timer at neighbor's house and see if it works there.
Posted on Jul 04, 2011
Ferroli optimax he plus 31c boiler timer instructions
Why does the display appear and i can set timer but then display goes blank and i carnt getthe lcd screen to display anything at all??
Dec 19, 2011 | Heating & Cooling
I WOULD NEED SOMEONE TO TALK ME THROUGH IN PERSON , HOW TO PROGRAM THE TIMER FOR 8AM TURN OFF AND 8PM TURN LIGHT ON EVERY DAY OF THE YEAR - THE SAME TIME ...
If you want someone to talk to you, you will have to pay for phone help.
Here are the simplified instructions.
Press Mode to step thru various options, you only need to get to CLK.
Then set the hour, minute and day of the week first.
If you want the timer to go on & off at the same time for 7 days, you must program 7 times.
Good luck, Gary
Setting the Time of Day
Press MODE to go to the Clock (CLK) settings. The display will flash with 12:00 AM.
Press HOUR+ to stop the flashing.
Press HOUR+ and M+ to set the current time in hours and minutes.
Make sure that AM and PM settings are correct.
Note: The day of the week is shown at the bottom of the display. If you have not programmed the calendar settings,
be sure to also set the current day of the week while programming the current time. To do this, press DAY until the
correct day of the week is shown. The CLOCK settings are now complete.
Press MODE to go to the first PGM screen. See Fig.9
Use DAY, H+ and M+ buttons to set the days, hours and specific times that you would like the timer to turn ON.
(NOTE: Be sure the word ON is displayed when setting the ON time.)
Press NEXT ON/OFF to program an OFF time.
Repeat the same steps for all 7 ON/OFF operations, if required.
Aug 29, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
Problem #1. On model #DT300 the instructions under Set Time of Day # 3 does not change the day. The only place I can get the day/s to change is under the programming. What is wrong with it. I have...
Thank you for very clear question, and timer identification.
1) I don't have repair for defective timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
2) Choose DT300 format
#3 says to press-and-hold CLOCK button until display shows 24H or 12H
Then release CLOCK button.
Next press HOUR button to select either 12H or 24H
This lets you choose am-pm format -or- choose military-time format where 11pm is 23
3) Set current time
Press-and-hold CLOCK button throughout whole current time setting.
Do not release CLOCK button until current time settings are finished.
Next, press HOUR button, and then MINUTE button, and then DAYS button until current hour, minute and day display.
If this step does not work, then timer has gone bad.
Replace with locally available Utilitec 155671 from Lowes or Westek TE06WHB from Target
4) How to set DT300 timer program for full week of operation.
Each program requires you to set program 1 ON time and program 1 OFF time
Be careful to avoid program conflicts and overlaps so timer works as expected.
For program 1 ON time, you press PROGRAM button until 1 and ON display.
Release Program button.
Then select hour, minute and days. In this case you want all days of week, so you keep pressing DAYs button until whole week displays: Mo Tu We Th Fr Sa Su
Then you set program 1 OFF time, you press PROGRAM button again until 1 and OFF display.
If you set ON time for all days of week, and OFF time for Tu Tuesday, then timer will not work correctly.
5) Read manual and add a comment for additional help
Aug 18, 2011 | Hardware & Accessories
The instructions are not very clear on my new UPM ET420C Electronic Outdoor Timer. What I want to do is have the time turn on power everyt morning at 3am, run for 2 hours, and stop at 5am. Could you tell...
Using the right & left arrows, go to CLOCK to set the current time & day.
Press SET
Using arrows, set the day, press SET.
Using arrows, select the hour, press SET.
Select the minute, press SET.
Select the second, press SET.
Using right arrow, press once for program 1.
Press SET.
Select day, press SET.
Select hour, press SET.
Minute, SET.
Repeat this for every day you want this program, five days or seven days,
Programs 1-5 or 1-7.
Gary, good luck, these instructions are difficult.
May 27, 2011 | UPM Programmable Outdoor Timer
Utilitech model 0141224 wall switch timer. used on outdoor lighting to set up to 7 on/off cycles each day. im trying to turn on my porch light in the evening and off in the morning. there are NO...
As luck would have it I'm 60, and learned how to program your 0141224 wall switch timer.
You can see instructions with big print and pictures on following page.
Press CTRL key on keyboard and use scroll wheel on mouse to make web print bigger.
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Add a comment any time.
You have wired your timer correctly and the lights turn on when you push on-off button.
If lights do not turn on, we need to review the wiring.
Your timer looks like photo below.
I'm going to parrot back the manual with some extra words.
To start, press the reset button and clear any programming
Programing overview:
Each program has ON time ... and OFF time
So you set program1 ON and then set program1 OFF
When you set program1 ON, you choose the Day, hour and minute you want program1 to turn ON.
And then you set program1 OFF, and choose Day, hour and minute for program1 to turn OFF.
Your ON-OFF times for program1 should be on same days.
For example program1 ON for all-days-of-the-week, but program1 OFF is for TU Tuesday, then timer will not work.
IN this case, program1 OFF should also be set for all-days-of-the-week.
Let's start.
Setting the clock:
Press and hold CLOCK button
Keep holding CLOCK button and press DAY button until display shows current day (MO TU WE TH FR SA SU)
Press Hour button until current hour with am pm displays
Press MIN button until current minute displays.
Release clock button and current day and time show on display
At no other part of instructions do you press and hold one button while pressing other button.
Setting programs:
Press PROG button until "1" and 'ON' show on display
This is program1 ON
Press DAY button to choose which days for program1 ON.
You can choose: all-days-of-the-week and MO TU WE TH FR SA SU show on display
Choose individual days and MO or TU etc shows in display
Choose weekdays MO TU WED TH FR
Weekends SA SU show in display
Next step
Press HOUR button to select hour for program1 ON
Press MIN to select minute for program1 ON
Now program1 ON is ready, next, you will set program1 OFF
Press PROG button until "1" and 'OFF' shows on display
This is program1 OFF
Press DAY button to choose which days for program1 OFF.
( Remember, you want same days for ON and OFF)
Press HOUR button to select hour for program1 OFF
Press MIN to select minute for program1 OFF
Now program1 ON and OFF are ready, next, you will set program2 ON by repeating same steps above.
You can set up to 7 programs.
If you don't want to set program2, or any more programs, that's fine.
To exit programming and save your program, press CLOCK.
Now current time shows in display.
Final step: set MODE
Press MODE button until AUTO shows in display. You want AUTO for programming to operate lights. That's it, timer is ready.
If you're going on vacation, press MODE button until RDM shows in display, and then timer turns lights on-off at random
Copy and save these instructions to your computer so you have them next year.
Dec 04, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have a HB88RC Intermatic 7 day / 7 event timer. I have followed the "easy set instructions" I have program 1 set to turn on X-mas lights at 4:30 PM and go off at 11:30 PM. For all seven...
Just program it as noted previously and put the timer in Auto. Set the clock to 1 min BEFORE your earliest timer program is set to come on. When the clock hits the correct time, it will turn on. Then set the clock to the correct time and you're golden.
Dec 03, 2010 | Intermatic HB88RC - 7-Day Programmable...
How do i program the timer?
You did not specify UPM outdoor timer model.
1)ET525C has 7 buttons, and is shaped like a computer mouse, and has a photocell
2)DT420 & ET420 are dusk-to-dawn timers with clear plastic cover
3)DT523 is dusk-to-dawn and shaped like apple phone
4) PT555 is box-type with a door and timer has 6 screw terminals
I'm going to shoot-wild and offer programming for the one shaped like a mouse, the ET525c.
Here is manual
Download manual if you have high-speed, so you can see print larger.
Manual has 10 pages so I can't repeat everything. You will have to read along with your copy of manual.
1) Timer has MODE choices: I will help you program specific on-off times.
2) Setting the clock: Press SET > press Up-Down to choose day of the week ... if today's newspaper says Friday, set timer to Friday
3) Press Set again to confirm day of week
4) Press arrows to set hour. If your watch says 10:30 am, click arrow until 10 am shows
5) Press Set to confirm hour
6) Press arrow to set minutes, until minutes match your watch.
7) Press Set again to confirm everything.
Clock is displayed now
Programming timer:
Timer gives you 20 programs
PROG1 PROG2 etc to 20
Each program needs a DAY it will operate
Each program has ON time, and OFF time
PROG1 ON
PROG1 OFF
Select PROG1 using UP key
Manual page 6 has diagram showing how display looks
Press UP until PROG1 ON shows
Notice: PROG shows in upper right corner, and 1 ON displays to the right of time
This means PROG1 ON
Note: sometimes the instructions say press UP, and sometimes they say press UP or Down ... when in doubt, write out the instructions, and it helps you understand.
Now press Set to begin
Press UP and different days will show. MO for Monday, Weekdays, weekends.
Press Set to confirm days you want PROG1 to turn ON
Press UP or DOWN to set hour you want PROG1 to turn ON
Press UP or DOWN to set minutes you want PROG1 to turn ON
Half way done with PROG1, you need to set PROG1 OFF times
Press UP until PROG1 OFF shows
Look at display, and look at figure page 6 manual
To right of time is number 1 with tiny word OFF, in upper right corner of display is PROG
Press Set to start
Press arrows until day shows (default will flash same days you picked for ON times) Tip: keep the same days!!! or timer will reset ON times for some reason.
Press Set to confirm days timer will turn PROG1 OFF
Press UP and DOWN to set hour for PROG1 OFF
Press UP and DOWN to set minutes for PROG1 OFF
To advance to PROG2, PROG3, PROG4-20, press UP key
To end programing mode, press DOWN
If no keys are touched for 1 minute, timer returns to clock mode
Instructions carry on with more options, if problems persist, take aspirin and post again in the morning.
Oct 04, 2010 | UPM Heavy Duty Outdoor Programmable Timer
Where can I download instructions for utilitech timer
UTILITECH - Grounded in Quality
Digital 2-Outlet Timer (TE06WHBL)
Instruction Manual & Warranty
Before using your timer please read the following instructions carefully.
FEATURES
- Up to 8 ON/OFF events per day/56 ON/OFF events per week
- Option to program individual days or 8 different weekday groups
- Minimum switching period one minute
- Summertime/wintertime change over
- Easy to read LCD display
- Random automatic ON/OFF security feature
- Countdown feature
- Manual override button
- Rechargeable battery back-up (if there is no LCD display, plug
timer into a wall receptacle, this will recharge the battery)
SETTING TIME
Press and hold CLOCK key, then press DAY key to select correct day,
HOUR key to select correct hour, and MIN key to select minutes. When
MIN key is released, time will be set with seconds starting from 0.
Either holding down or repeatedly pressing appropriate button can
advance days, hours and minutes.
Do not set ON and OFF for same time.
PROGRAMMING EVENTS
The timer has the capacity for 8 ON/OFF events per day.
Save program capacity by using available blocks of days.
Blocks of days are:
1. M,T,W,Th,F,S,Su
2. Individual days of the week
3. M,T,W,Th,F
4. S,Su
5. M,T,W,Th,F,S
6. M,W,F
7. T,Th,S
8. M,T,W
9. Th,F,S
For each ON time and each OFF time--DAY, HOURS and MIN must
be set. Press PROG key onceto set first ON time--"ON" and number
"1" appear to left of LCD display indicating to enter first ON time.
Press DAY button to choose required day or blocks of days, then set
hour and minutes using HOURS and MIN buttons. After setting required
ON time, press PROG button to validate entry and move onto first
OFF time--"OFF" and number "1" appear to left of LCD display
indicating to enter first OFF time by using DAY, HOURS and MIN
buttons as above. Press PROG button to validate this entry. Repeat
remaining 7 ON/OFF settings as required. After setting required
ON/OFF settings, press CLOCK button to return display to clock. Timer
is now ready to operate. Check programmed settings by pressing
PROG button repeatedly--each setting will appear on screen.
MANUAL OVERRIDE
To choose permanent Manual ON, permanent Manual OFF,
Auto ON or Auto OFF, press Manual button. Each mode will be
displayed on screen. When choosing Auto ON, timer turns ON until
next programmed OFF time. The programmed settings will only work
on Auto mode. When Auto mode OFF is chosen, timer is OFF until
next programmed activity. (Inverted black triangle on LCD points
to either AUTO or MANUAL indicating which is selected)
COUNT DOWN FEATURE
To enter count down feature, press CLOCK and PROG buttons
simultaneously. Using HOURS and MIN buttons, set count down time.
(Maximum selection is 9 hours 59 minutes, minimum is 1 minute.)
Press MANUAL button to start countdown. Output will turn ON until
end of count down. Count down may be paused at any time during
period by pressing MANUAL button. To re-start, press MANUAL button
again. To review time during count down period, press and hold
CLOCK button. Release CLOCK button to return to count down display.
Note: To return to timer mode, press CLOCK and PROG buttons
simultaneously.
RANDOM AUTOMATIC ON/OFF SECURITY FEATURE
With this option selected, timer will switch ON and OFF in a random
pattern at least once in every 8 hours. (This may mean timer will
switch OFF within a set ON period, or vice versa.) Ideal for use with
a light--switching it ON and OFF automatically gives appearance of an
occupied home, but not at exactly the same time every day. To enter
Random mode, press DAY and HOURS buttons simultaneously.
An "R" will appear on display and unit will start random switching.
If no programmed times are set, timer will switch ON or OFF
approximately 1 minute after entering Random mode, then continue
randomly. To turn Random mode OFF, press DAY and HOURS buttons
together again.
SWITCH OVER SUMMERTIME/WINTERTIME ZONE CHANGE
To change from wintertime to summertime, press HOURS and MIN
buttons simultaneously. Clock will be set forward one hour and
"S" will appear on display. Repeat same procedure to return to
wintertime.
Note: if unit is purchased during summer, set clock time for one hour
less than correct time, select Auto mode and press HOUR and MIN
keys simultaneously. The unit will then adjust to correct summertime
and "S" will appear on LCD.
RESET
To reset unit for time and programmed ON/OFF settings,
press RESET button.
IMPORTANT SAFETY PRECAUTIONS and
RATINGS
[Contact the manufacturer; I've already wasted too much time typing
this in:
AmerTac
Saddle River Executive Centre,
One Route 17 South, Saddle River, NJ 07458
800-777-0802
www.amertac.com
Made in China
May 05, 2010 | Kitchen Appliances - Others
Need instruction sheet
Your unit has a lifetime warranty. Go to this website to get the instructions in PDF format:
http://www.hardwareinnovations.com/pdf/SA_210_IB61056_33.pdf GOODLUCK
SA 210 Zip Set Outdoor Digital Timer with 3 Outlets features a Zip-Set One-Step Set-up where you simply enter your area code and the timer is programmed. Your lights will automatically turn on at sunset, and auto-adjust for seasonal time changes. Other features include a random setting for added security, a 7-5-2 setting for full weeks, weekdays, or weekends. Battery back-up (batteries included) to save resetting time in the event of a power failure. It has 2 timed outlets, plus 1 extra untimed outlet for use with other products. It has an easy-to-read, large illuminated digital display, and 15 amp capacity. Lifetime warranty.
Product Description
Zip-Set™ Technology with One-Step™ Set-Up Two Timed Outlets + 1 Untimed Outlet Controls three Products Simultaneously Controls Outdoor Landscape, Security and Holiday Lighting, Pool/Spa Pumps and Engine Block Heaters Optional 4 On / 4 Off Settings Random Settings for Added Security 7-5-2 Feature allows you to set times based on the 7 Day full week, 5 Day work week, or 2 Day weekend Large Illuminated Easy-to-Read LCD Display & Keypad Battery Back-Up (battery included) saves resetting time in the event of a power failure Weatherproof 15 Amps Lifetime Warranty
Dec 22, 2008 | Sylvania Hardware & Accessories
Timer record set
Make sure the clock is set. Since the clock must be set before the timer will work, be sure you have entered an accurate date, day of the week, and time (including AM or PM). And always check the clock after a power outage. Also, check that your videotape does not have the tab removed which protects against further recording.
Mar 08, 2007 | Zenith TVBR1322 13 in. Combo
Hardware & Accessories Logo
566 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
