Question about Sony KDF-E50A10 50 in. LCD HDTV
Now it has 4 red blinking lights on after the tv turns on
  • 5 more comments
  • Anonymous Dec 11, 2014
    clean the fans and heatsinks and reset the error look in the manual all else fails read the instructions !!!!
    https://www.youtube.com/results?search_q...
    sorry you tube can be handy check out and see some other users changing bulbs and service tips please worth a study
    your almost there.....!!!! and dont give up sorry im a prat sometimes
    ok from what i read its detected a fan has failed
    prob clogged up as i say give it a good vaccume or refer to a sony guy
Https://docs.sony.com/release/KDFE42-50A10.pdf
all three lights are on because
1 the lamp needs changed
2 the overheat is running hot because the fans and heatsinks are cloged with dust
3 its shut down because the lamp is old failed and overheating
above is the link to the manual study it and youll see...
clean it out fully
drop the back off demount some pcb and fans etc
and vaccume out carefully and change the bulb
basically a good service needs doing
if your not in the mood and use ebay to get a new bulb cheep {prob one without the holder}
then take it too a tech
if you take it get the cheep bulb option first and have him fit it
safe you getting ripped off for parts cost...
its just the bulb and fan units
so dont panic
the projection screen might need a clean with IPA and the reflector panel cleaned also
depends what the TV setup is not familiar with this model fully
much as a much in this type
all thee lights is common to bulb going meltdown... soon
so change it out and clean all is the rule here
happy crimbo...
anyway
sim
Posted on Dec 11, 2014
Testimonial: "I just replaced the lamp"
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Tv turns on for less than 30 seconds and turns off and red light is blinking
Hi John,
TV going off in thirty seconds and red light blinking means there is something wrong inside your Tv and it should not be working in this condition and hence is the "going off" happening. The automatic protection inside is switching your tv off. Please consult some local TV tech. There is nothing you can do about it yourself.
Good Luck.
May 23, 2015 | LG Televison & Video
Tv wont turn on, just red light blinks
From the owner's manual of that model:
If a red light is blinking on the front of the TV, the set has entered protection mode. If this happens it usually means you simplyneed to reset the TV. Unplug the TV for 60 seconds. Then plug the TV in and try to switch it on. If the light is still blinking red,call the Customer Care Center at 1-800-531-0039
Dec 08, 2011 | Philips 55PL9524 55" Rear Projection...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Red blinking light when tv is turned off
You can't fix it. There is a bad board in this set; either the main board or the power supply board. You'll have to call a professional.
Mar 30, 2009 | LG 37LC7D 37 in. LCD HDTV
Tv turns on but no picture just a red blinking light stays on
Red light blinking means there's a problem in the TV....
What kind of tv is it?
Feb 10, 2009 | Televison & Video
42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Jul 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Sony KDF-E50A10 50 in. LCD HDTV Logo
96 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
