Question about Canon CanoScan 8800F Flatbed Scanner
Using HP 0957-2269 adapter for K30286, the specs are very similar, wondering if they are compatible
What graphics card is compatable for hp d530
I'm not going to go through a list for you, but I can tell that you don't have many options. The HP Compaq Business Desktop D530 uses a small form factor which means you don't have the same space as normal desktop users inside of your machine for the vast majority of display adapters. You would need at least a medium form factor for that.
The other problem is that your power supply is only 185W and can't supply the the amount of power needed for most desktop class display adapters.
The machine you are using wasn't designed to ever be used for gaming, and it shows. You would need to get a bigger computer case and higher watt (around 400 to 600 watt) power supply to support most desktop display adapters.
Jun 26, 2012 | HP Compaq d530 CMT PC Desktop
Need a driver for Windows 7 64-bit for my Belkin f5u109
No, this product is not compatible with Windows 7 - 64 bit. It is compatible with Vista 32 bit computers. however u have a similar adapter which is compatible with Vista 64 bit, and Windows 7 - 64 bit you can use part F5U257 (USB-to-Serial Adapter).
Aug 13, 2011 | Belkin USB PDA Adapter (F5U109EA) Serial...
Is ithe Motorola WPC1810G compatible with the HP Pavilion F1703
Yes its compatible with it so you should be able to use it on that computer as a wireless network adapter, just make sure you install all the needed software for it......
Dec 02, 2009 | Motorola WPCI810GP 802.11g/b (51803000100)...
HP laptop won't start without a battery
just get a universal adapter for it but make sure in the package it says it is compatible with your lap top it is well worth it usually run about 85 bucks
Oct 28, 2009 | ASUS G1 Notebook
Laptop won't power up without battery, needs 135W adapter
The ASUS power adapter is below spec and it may damage the adapter because the HP is drawing 45 W more power than it can deliver and will cause it to overheat.
The 17" HP requires 18.5 or 19 volts depending upon the model of the HP laptop (check the power requirements on the label on the bottom of the laptop). If the ASUS adapter doesn't deliver this voltage, it most likely won't power up the HP laptop.
Use the power supply/adapter from the other 15" HP. If this HP's adapter has a voltage output of 19 volts and the 17" laptop requires 18.5 volts, don't worry a voltage difference of 0.5 volts, the only problem is whether the power plug will fit into the power socket of the 17" HP laptop.
Oct 28, 2009 | HP Pavilion zd7020US Notebook
Need tip size for viewsonic powere supply
insidecomputer_2070_4186448
Replacement Part Number: 1267-0526
Specs:
  • 40 Watt, 12 Volt AC Adapter
  • 4.8 mm Barrel Connector with Positive inside
  • Condition: New
  • Warranty: 12 Months
  • 100% OEM compatible, Guaranteed to meet or exceed OEM specifications
Compatible Models:
  • Hewlett Packard Jornada 680 Series
  • Hewlett Packard Jornada 720 Series
  • Hewlett Packard Jornada 728 Series
  • HP Jornada 680 Series
  • HP Jornada 720 Series
  • HP Jornada 728 Series
  • Planer LP150-BK
  • Viewsonic VG150
  • Viewsonic VG-150B Model
  • Viewsonic VG151
  • Viewsonic VP140
  • Viewsonic VP150M
Sep 07, 2009 | ViewSonic VG151 15" Flat Panel LCD Monitor
How to install the driver for NetGear USB adapter in linux ?
According to the specs it seems it's only compatible with "Windows"
Mar 15, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Hp 65w adapter compatibility
no it will burn the power supply if half wave rectifier is used in adapter then it may work if you are not technical person then purchase new adapter or convert it from any technician
Nov 19, 2008 | Computers & Internet
I need to buy a new Ac power adapter 0957-2094 for my all in one printer hp psc 1317 can you help
manuf website best choice for compatability, revisit store where bought, possible they have one that will meet specs in their overflow odd box.
Jun 22, 2008 | Office Equipment & Supplies
E-100 generic AC Adapter?
I doubt you can use 300 mA adapter,because Oly C2100 needs 2000 mA at 6,5V. E100RS construction seems to be very similar.
Sep 11, 2005 | Olympus Camedia E-100RS Digital Camera
Canon CanoScan 8800F Flatbed Scanner Logo
81 people viewed this question
old marine
old marine
