Question about Breville Deep Fryer BDF450
My Breville BDF450 will not turn on (no lights no nothing). Heated oil up prior to cleaning. Cleaned and changed oil now unit will not work at all
Was working perfectly. Wanted to change the oil and clean it so heated up the oil, emptied it, washed it carefully (as I usually do), added fresh oil, turned it on but now the system does not work at all. No lights or anything!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 173 Answers
Did you pour out the oil when it was still at it's hottest temp? I would guess there is a master overheat sensor that tripped off. It will be a little thermodisc with 2 power wires connected to it. Find and replace that thermostat sensor. You can test it for continutiy with a volt meter.
Posted on Dec 11, 2014
Auto fluid was brown so when I drained it, only 2 litres came out, so put back 2 litres of fresh which came up to the hot mark on the dipstick. Fluid now still brown ( but not as dark as before.
Michael, If your vehicle is a normal automatic transmission it will have a torque converter. If you really want to attempt a complete flush, I will post links on how it is done, you will still have to change the filter to ensure a thorough job. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Automatic Transmission FlushDo it Yourself ProceduresNO SPECIAL TOOLS OR...
Automatic Transmission Filter and Flush on Jeep Cherokee
2001 Ford F150 Transmission Service Flush Torque Converter Oil Cooler Pan...
May 18, 2016 | Cars & Trucks
Where should I start on a motorcycle that has been sitting for 20 years?
Hi Nick:
What a great project.
- I'd start with a really thorough clean up.
- You've mentioned the gas. Definitely, drain the tank, hoses, carbs, and clean the carbs. If there's a filter I'd change it.
I wouldn't even try to run it without cleaning the carbs first.
- Replace the battery, oil, and spark plug.
- Engine coolant?
- Tires? I wouldn't worry until I had it running but definitely replace.
Patience & time. You'll have an excellent bike.
Jul 13, 2015 | Honda Motorcycles
Kickstart is stuck
Hi, Anonymous you may have squeaked your top end this is commonly known as "HEAT SEIZE" the piston heats up expands and becomes extremely tight in the cylinder bore and usually occurs mainly on 2 cycle engines right after a fresh top end rebuild, but it can also happen to brand new motorcycles, these are rare instances due to better quality control and education. Overheating failures that cause pistons to seize are many and each one should be carefully diagnosed to prevent future repeat offenders and the usual suspects are:
1. Loose fasteners causing intake or base gaskets to leak or crankshaft seal failure caused by age, overheating, or walking.
2. Improper assembly of reed valve gaskets.
3. Improper oil/fuel premix ratio.
4. Broken, pinched, or cracked fuel line.
5. Carburetor fuel passages clogged or restricted from stale fuel varnish, ethanol sludge, dirt, rust, or fuel level in float bowl too low.
6. Main jet size too small.
7. Air filter improperly installed, missing or not sealing.
8. Faulty or improperly adjusted oil pump and or cable.
9. Failure to bleed oil pump after running oil tank dry, rebuild of pump or replacement
10. Among the causes of lack of cylinder, lubrication is clogging of lubricator by dirt or waste, obstruction in oil pipes/lines, leaky check valves, leaky pump packing, broken oil pipe/line, oil too cold to feed.
11. Wrong type of oil used in premix or oil tank
12. Improper spark plug heat range (too hot) and or gap.
13. Ignition timing retarded, faulty CDI.
14. Excessive engine load, brakes dragging, clutch slipping, transmission lubricant level too low or viscosity to high.
15. Engine coolant level too low, too old, or improper mixture ratio.
16. Engine coolant pump failure, damage, or passages restricted.
17. Radiator clogged, fins damaged, or faulty cap.
18. Failure to follow proper break in procedures.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
dt125 kickstart jammed and possibly more
Yamaha DT125 seized up engine
http://www.motogelnar.cz/manual/YAMAHA/DT125X_RE-05-Service_Manual.pdf
OEM parts for Yamaha
http://www.dt125.cz/download/Owners_Manual-DT125X_RE.pdf
Dec 09, 2013 | 2000 Yamaha DT 125 R
My car turns over but wont start
Do you have plenty of gas? Keep at least 1/2 and above. Also, add some fuel tank water remover...If tank has been low, add 2 bottles of "Heat"...Injector cleaning by adding fuel system cleaner after starting helps in the future. Your Volvo should make the needed adjustments for cold weather...you need to help it with the right additives for performance:) Hope this helps. (Is cranking slow?...also be sure oil change is fresh and correct oil viscosity 5W30...
Jan 22, 2013 | 2005 Volvo XC90 T6
Honda has d4 flashing it was able to be driven but no shifting of gears felt like something was not catching the d4 light was blinking I moved it into d3 same thing the only way I was able to get it h
You have a fault present in the transmission, you need have it scanned/tested to see what the fault code is that is stored in the memory of the control module and diagnose the code and repair what is found to be at fault. this could require a ****** rebuild in this car when the light flashes.
Sep 05, 2012 | 1993 Honda Accord
Unit stopped working
I have the same problem. Cleaned filters, lights were never on to indicate they needed to be cleaned but i cleaned them anyway. Tried resetting lights by holding 10 seconds and nothing.....
Aug 07, 2012 | Honeywell 50250-S True HEPA Air Purifier
My Breville Expresso machine does nothing when I turn dial to make coffee
Sounds like its time to clean it. Run white vinegar and a little water through it.
Apr 18, 2012 | Breville Coffee Makers & Espresso Machines
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Feb 08, 2012 | Konica Minolta Cameras
Breville Deep Fryer BDF450 Logo
229 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
