How do I replace lid switch
Don't know how to get to lid switch
  • Washing Mach... Master
  • 744 Answers
Hello George;
My name is Peter. I am a retired field service appliance technician.
It would be easier if you sent me a model number. Generally the lid switch is white and has a plastic rectangular frame. The switch pops in. With a small screw driver, wedge under the switch frame and lift. There is a clip you can depress under the frame. If you are replacing the switch who cares if you break the clip. There are 2 contact wires on the clip (These are HOT). Disconnect the wires and reconnect them on the new switch. Be careful the wires do not fall in.
If this is not the type of switch that you have send me the model number.
Posted on Dec 11, 2014
My washer does not spin or drain.
If the unit will agitate but not spin or drain I recommend checking the lid switch first. You should be able to hear the lid switch click as you slowly open & close the lid. If you don't hear a distinct click, replace the switch.
Here is the part you need.
Oct 13, 2012 | Kenmore 24032\24036 Top Load Washer
Washer fills up with water but does not start to wash/agitate
if you don't hear the motor running you have a bad lid switch,if you do hear the motor but no agitation you have a broken motor coupling.
most likely you have a broken lid switch,close the lid,then open it around 6 inches,close it and open it a few times,as you do this if you don't hear a clicking sound the switch is bad,part number 8054980 and it's around 25 dollars.
http://www.youtube.com/watch?v=PZAbg9uftos&feature=BFa&list=PL946F2AC904989088
watch this video, when you click on it look down on the left side it will say replacing new style,click on it and it will show you your model.it will show you how to make sure it's the lid switch but if you don't hear any clicking when you open and close the lid the switch is bad,also if the lid is pushed in from putting the laundry basket on top of it open the lid and wack the center of the lid to pop it back up,i've done this before when the lid is dented in and this fixes the problem,the arm that's connected to the lid doesn't hit the switch correctly with the lid dented in but usually the switch is bad and needs to be replaced.
http://www.youtube.com/watch?v=MFsvLiuTniU
watch the first part of this video and it will show you how to open the top console,this is different from your lid switch this is just to get you into the top so you can change the switch.good luck,if you need anymore help let me know and i hope this helps you out
May 19, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care 2 - will fill but no cycle or drain, can hear the timer running
Apr 28, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer stopped dead in mid load.
Check the lid switch. You should hear it click when you open and close the lid. If you don't hear a click, replace the switch.
Oct 18, 2011 | Kenmore 24032\24036 Top Load Washer
It will fill up with water but nothing else
check the lid switch,set the timer on spin,push it in so it will run,get a screw driver or anything that will fit into the hole on the right side,that's the lid switch,the strike on the lid hits it when you close the lid,if the switch is broke it kills the power to the machine,it's a safety so the machine won't run with the lid open,when you push down on the switch you should hear a click and it should spin and drain,if you don't hear a clicking sound the switch is broke,or you can close the lid,lift it up a few inches and close it down,do this a few times,when it closes and opens if you don't hear a clicking sound the switch is bad.part number 3949247 and it's around 45 dollars.http://www.youtube.com/watch?v=MFsvLiuTniU copy and paste,it will show you how to get at the switch.let me know what you find so if someone else has the same problem they will read what you found,thanks
Sep 24, 2011 | Roper RAX4232KQ Top Load Washer
Washer fills with water but then will not cycle through after filling tub
I looked up yur model. It is a fine washer. Your lid switch on this model don't allow for wsh or spin if the the lid is ope. Older models would let the washer wash but not spin. This switch here won't allow for wash or spin. How it works
My page on these
Note: this washer is a newer model and I have yet to come across one. I believe your problem to be the lid switch. It has 3 wires. 2 hot ones and another one attached to the frame. Jump them 2 live wires and see if she runs. If it works get a new switch and party on!
I am TheMobilian.
Let me know what ya find out, I am here to help.
Jul 21, 2011 | Whirlpool LSR5132PQ Top Load Washer
Kenmore model 70 washer will not empty tub with lid closed.
This is a broken lid switch . You can replace the lid switch or if you need to get it working quickly you can bi pass the switch by unplugging the washer, removing the 2 lid latch screws, pulling out the switch cutting the 2 wires and twist them together with a wire nut.
This is assuming you do not have the self locking lid.But I don't think your model has that function.
May 14, 2011 | Kenmore Washing Machines
The tub fills with water for the load size selected, but then the agitator will not work on my Whirlpool. Tried to move agitator by hand, but it is locked up tight. I have already replaced the time, and 3...
send the model number?if it's a top load washer check the lid switch,if the switch is broke it will fill and do nothing,if it's the coupling the motor will run but nothing will move,close the lid and then open it a little and close it a few times,if you don't hear a clicking sound you have a bad lid switch,you can also open the lid,set the timer on spin and with a screw driver push down on the switch on the right side,if it spins the lid switch is bad,it has to work only if you hear it clicking when you push down on it,if it don't click it's bad.let me know what you find.also if the motor is humming you could have something stuck in the pump,pull off the frame,pop the metal clips on the pump and slide it off and start it,if the motor runs you have a bad pump or something stuck in it.
May 13, 2011 | Whirlpool Washing Machines
Whirlpool LSQ8528JQ1 water fills up then stops
Hello, Welcome to FixYa. The scenario you describe is usually associated with a faulty or broke lid switch...but I don't know if you checked that yet or if you know how.
The lid switch failure is definately a common top load washer problem. Here`s how you can repair it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...but it should cover yours)
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know how you make out. If this is something you think is not within' your scope of expertise please call a pro. I think you'll be fine with the tutorial video'
I will try to help in any manner I can of course as well. Good luck.
Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Apr 08, 2011 | Washing Machines
Waher fill run but thats all don,t spin don,t wash dont risen
The most common cause for this problem is a faulty lid switch! this the switch that gets depressed by the tang on the machine lid. If the switch is problematic, or faulty, the washer will only fill and that is it! The timer will not advance or the motor run. The switch can be checked with an ohmmeter, and they are fairly simple to replace. If any further information regarding machine disassembly and switch replacement is needed, feel free to post here again.
Hope this gives you a starting point.
kcomp1863
Jan 19, 2011 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
