Question about GE Ovens
How do I fix my GE True temp oven which shows F7 on the display?
GE True Temp Oven, Model number JKP1580A388. Serial number GA6 53032O Starting from off, without touching it, the oven began beeping 22 times and showed Broil on display. It stopped, and repeated this cycle. We pressed clear off, it stopped, only to begin again later. I held in the Clear/Off button for many seconds, this morning. This evening, the display reads F7. I have not tried to turn the oven on yet. Please help.
  • Anonymous Dec 11, 2014
    reading more i see some people had to replace the tactile switches again using deoxite you can cure this look to ebay for deoxite D5 spray it on wait a few mins actuate the switch a few times wait a min or two and spray again should fix the switches totally use a rag or kitchen roll to wrap around to soak up any spray but the can has three settings so use low press the switch in first then spray it let it go
    press in and out each switch as you spray remember to just wipe the connections on the ribbon cables
Https://www.youtube.com/watch?v=Rg7Dp4LBxtA
it seems its the connections ribbons on the control panel is wrong
will give you a clue look down the replys to the video to get more info
some very carefull cleaning is needed inside the front panel rework some connections
i use deoxit 5 and a rag
spray the deoxit to a rag then wipe the connection ribbons
then dowse the plugs with the deoxite
wait a while and re plug then carefully
should cure it
i would add a blob of grease to the sockets once its all running
to avoid further corrossion
hope this helps
Posted on Dec 11, 2014
Where is the serial number on the GE True Temp Oven?
open the oven door and look for a label or a tag with numbers on it .
Apr 06, 2015 | GE Ovens
Ge true temp oven
Sometimes you will have to pull the oven out to get access to the connector for the sensor. It could be jammed in the back or the hole is just too small to pull the connector through the wall.
Feb 15, 2014 | Ovens
GE Profile Wall Oven Model#PT916S error code F7
U have a bad clock or your probe inside of oven is bad.I would replace your probe first .it looks like a rod sticking out inside back upper top .f7 I believe means its not reading up temp and getting to hot
Nov 10, 2011 | Ovens
MODEL NUMBER HR7E SERIAL NUMBER 46-2000-893 DOUBLE DECK OVEN GIVEN A FAULT OF PHE.... WHAT DOES THIS MEAN?
ON START UP WHEN OVEN IS COLD IT WIL DISPLAY PHE TIL IT REACH A CERTIAN TEMP IF IT KEEP ON DISPLAYING PHE REPLACE YOUR TEMP PROBE
Jan 28, 2010 | Hobart HR7E Electric Single Oven
F7 appears on GE double oven JT950SA
f7 is a stuck keypad or overlay all you can do is replace it
Jun 30, 2009 | GE JTP45 Electric Double Oven
GE Oven displaying both F2 and F3 error codes; bad ERC or temp sensor?
F3 is Open oven temperature sensor circuit.
F4 Shorted oven temperature sensor circuit .
F7 Component failure.
To fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Oct 28, 2008 | GE JRP15 Electric Single Oven
GE JTP56 Double Oven
Hello there,
This may be related to the F7 problem even if you are not getting an error message. Go to my web site at the following link:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
Please let me know if this works for you. I have sent my fix to over 1300 folks.
Good Luck,
Powerman
Oct 20, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
127 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
