Question about Kitchen Ranges
How do I take off the Broan 88000-c range hood switch panel to change for a new switch. I tried to slide the panel to the left a bit, only the right end came off a bit, the left end does not and i don't dare to pull it hard and break the panel. Is there any clip inside the panel that I need to take it off first before taking the panel off?
  • 4102 Answers
SOURCE: Replace Broan Model K260A Range Hood Light Switch Slider Assembly
Hi if the new part has no screw holes or place for clip and it is only push in connector ie you dont need to solder the wires to it then it will just pull out use a small screw driver under the edge and gently pry free you cant damage it anymore than it is anyway can you.
Also on the side of the new switch if their is no groove cut into it for a push on clip to hold it in place then it will just pull out and push the new one in.
Posted on Jan 30, 2008
SOURCE: Broan Allure II
The problem is definetly the control board.
Part# R111638=$110.00. I do service calls for broan.
Inventex.com
Posted on Jun 14, 2008
SOURCE: Damper need for Broan Range Hood
I called tech support at Broan and was told they recommend two dampers in cold climates ...one at in the wall cap and one on the unit. They make the damper,
(#BP87-7"), that attaches to the round duct plate that comes with the hood. Strangely the unit does not include a round damper and the seller LOWES did not have it, also checked Home Depot,.
The Tech said they can't get stores to stock it. I checked at a local supplier of all kinds of plumbing, heating, and cooling supplies and they only had basic 7" dampers which, I was told would probably be too heavy, and be manual. I ordered it through Amazon/True Value ($11.56 w/ shipping, shipping more than cost of damper). Tech indicated that the 2nd (unit damper) is optional and may not be needed if in a warm climate. I would suggest that Broan include the $5.00 item in their unit or at least sellers stock it.
Posted on Jun 28, 2008
  • 171 Answers
SOURCE: WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
  • 136 Answers
SOURCE: st george range hood slide
for new parts just click this link
www.repairclinic.com
select the device in this link and then enter proper model number and then enter the required part.it will show up on the screen.you can also order this part.and they will send you.
thanks.
Posted on Oct 13, 2008
Lights on hood fan will not shut off.
It sounds like your switch is getting stuck internally. It most likely needs to be replaced.
Here is a break down of your unit. http://parts.broan-nutone.com/broan/Shop?DSP=30200&PCR=1:1000&IID=QS330AA&imagesequence=
Also, you can order parts directly from Broan, here. http://parts.broan-nutone.com/broan/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=QS330AA
Hope this helps you somewhat, please post back if you need more help.
Mar 07, 2011 | Broan-NuTone Allure III QS330SS Kitchen...
Jan 30, 2008 | Broan-NuTone Broan Range Hood Accessory
My Range Hood (Best by Broan K260A) is just two years old in a new house. WHen I use it, fat & grease drip down from the left and right edges against the wall. Can someone tell the problem?
grease accumulation, remove the fours screws on the lower plate, to remove excess grease. further you can unscrew the bolt that are holding the assembly and unplug the unit. after remove fans with allen key and remove motor , clean and reassemble , make shure to put motor the right back the same way. reassemble the same way , problem should be solve for at least 7 years depending on cooking.
Mar 15, 2010 | Broan-NuTone Broan Range Hood Accessory
42" Allure II Broan Range Hood I put a new bulb to replace
Get two new bulbs and install them. These bulbs are exposed to a lot of heat above the stove and the filaments get brittle. I suspect that the filament on the bulb that still worked broke when you were screwing it out or back in. good luck. please rate my answer. thanks noreen.
Feb 03, 2009 | Broan-NuTone Broan Range Hoods Allure II...
My broan allure turns on by itself
Isn't it suppose to turn on automatically? The broan has a heat sensor!
Jan 08, 2009 | Broan-NuTone Broan Range Hoods Allure II...
We have a steady hum coming from our Allue lll QS236 hood
If it hums when the unit is off:
Its probally one of two transformers. Remove both screws holding bottom metal plate under filters. Locate both transformers, put your hand on each transformer to see if hum stops, if so just pry on it a bit until hum is isolated.
1-transformer back left, and one toward the front with yellow/blue wires coming out.
If it hums with unit on high speeds: its air leaking, it will take fairly long time to find.
Dec 08, 2008 | Broan-NuTone Broan Range Hoods Allure II...
Hi shealy,
Thank you,
Sep 08, 2008 | Broan-NuTone WS330 Kitchen Hood
LIGHT SWITCH NOT WORKING
Its forsure 100% guaranteed to be the control board. Its located right behind where you push the buttons. You must remove the sticker (button pad) to access the three screws retaining the control board to remove it. The new control assembly comes with a new stickers.
Part # R111632
Price: $110.00
1-800-363-0566
p.s i do service calls for Broan-Nutone
Jul 25, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Broan allure fan and light
Check that you have not accidentaly switched the wall socket off in the cupboard above the rangehood. The slide switch could also be faulty.
Oct 30, 2007 | Broan-NuTone AllureĀ® I WS136BC Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
