Question about Toys
I HAVE A DEAN MARTIN SING DOLL AND THE MOUTH STOPPED WORKING
HOW CAN I FIX THE DOLLS MOUTH
5 Suggested Answers
SOURCE: two broken gemmy dean martin dolls how can i get them fixed
i looked through my local yellow pages and called a few electronic repair places. i finally found someone willing to take a look at it. sure enough they were able to fix it.i picked one up today and dropped the other off to see how they could do with this one now too.thanks you dolores metacarpa
Posted on Jun 17, 2009
SOURCE: doll will not stop singing
take the batteries out or cut the wires
Posted on Dec 18, 2011
chill930
SOURCE: Gemmy James Brown singing doll-mouth no longer
String Behind Mouth On All 2002 Gem-my Dolls Breaks
Posted on Sep 07, 2012
  • 28 Answers
SOURCE: dean sings his arms and body move but his mouth does not i saw that someone replace d the string is there a diagram to show the workings of the doll
slide tux collar down and find 4 staples in neck, with small flat screwdriver work stales from neck, they are quite long and it takes some time. then with thumb under mouth at chin, gently wiggle and pull owtwards until mouth slides from head, mouth must be removed before head will lift from neck. once head removed, you will see drive motor near top that drives mouth. there should be a smoll nylon string connected to small plastic wheel on end of this motor, most times the adheasive that hold this string in place has let loose and string is still in tact. before reconnecting press activation button and be sure motor is spinning, if so simply reconnect string to plastic end, and reassemble head I used 2 part epoxy (JB Quick) Note if motor is not turning when activated then this too needs repaired
DW Mylin.
Posted on Nov 24, 2012
Need repair manual for doll
Search " doll make repair manual ". .. I can't help any further.
Jun 16, 2015 | Head Toys
Where can I get the motor that runs the Dean Martin singing dolls mouth?
They carry these motors at hobby shops good luck. Kcp
Dec 31, 2014 | Toys
Is anybody willing to sell some of the 2002 gemmy animated dolls Louis Armstrong dean martin ray Charles Rodney Dangerfield or rocky balboa?
I havae Loues and Hank and one more I would be willing to sell bought them new and they have never been out of boz....
Sep 29, 2012 | Gemmy Rocky Balboa Big Head Animated...
Dean sings his arms and body move but his mouth does not i saw that someone replace d the string is there a diagram to show the workings of the doll
DW Mylin.
Sep 28, 2012 | Gemmy Bing Crosby Big Head Doll
I have a Bing Crosby Gemmy Pop Culture Series animated "doll" that sings. He is AMAZING and a family treasure. I don't know why but his mouth stopped moving this Christmas and I am just...
I have had my Bing have the same thing happen. I did repaired it my self . There is a string that works his mouth attached to the motor.You need to remove the head and you are able to repair it.I could fix it for you.john
Jan 05, 2011 | Gemmy Toys
Gemmy Dean Martin Mouth doesn't move. I took the head off by removing the 4 staples and can see the internal parts. There are 3 phillips head screws at the base of the head and 2 holding the plastic post...
Remove the staples to loosen the mechanism from the neck.
Remove the two screws holding the post to the mechanism base with a small Phillips screwdriver. Push the mechanism mouth out as much as you can to reveal the mouth post base. Using a hairdryer, heat up the mouth post glue and pull gently to remove the mouth bottom. Pull the mechanism out. Take off the spring. Replace the string with similar string. I would also recommend buying a new motor on ebay for $3 from China. You can get him singing again.
Feb 16, 2010 | Gemmy Toys
Our Singing Bing Crosby Santa doesn't move his mouth any longer, but his head and microphone still move while he's singing. Can we get his mouth repaired somewhere????
I have had the same trouble. I had to take his head apart and there is a string that is attached to the motor that works his mouth. The string has come unattached and needs fixed. The head is put on with a type of staple around the neck.Take them out and you will see what I mean.
Dec 14, 2009 | Gemmy Bing Crosby Big Head Doll
Two broken gemmy dean martin dolls how can i get them fixed
Jun 10, 2009 | Gemmy Rocky Balboa Big Head Animated...
Toys Logo
104 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
