Question about Kenmore Elite HE5t Washer
My Kenmore Elite HE 5t is showing the F20 code 15-20 seconds into the washing cycle. F20 standing for Water inlet problem. We have cleaned and checked all inlet ports and they are good so what else
Model Number 110.4708*4709*
  • Kenmore Master
  • 744 Answers
Hello Shannon;
My name is Peter. I am a retired field service appliance technician.
Code F20 also stands for pressure switch.
You have a incomplete model number so I am not sure if this is the correct switch.
My Kenmore Elite HE 5t is showing the F20 code 15- - 25316625-e0goqiu2jemxlrpk4czrq0zz-5-0.jpg
Substitution: W10514214 - $48.00
This is just inside the top cover, right hand corner.
The diagram is on the following link. Plug in your model number.
Water Filters Lawn Garden Appliance Parts
Posted on Dec 11, 2014
Kenmore elite h5
Hello there and welcome to fixya
I am very sorry that you are having a troubles with your machine
I know that it can be very frustrating when dealing with error codes so i will do my best to try to help you thru this ok?
ok well first the f20 error code is a no water code meaning that the machine may not be getting any water into the machine or very little and after 6 minutes the error code will be shown on the display .
So what do u need to do is this
f you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Feb 10, 2012 | Kenmore Elite 45986 Front Load Washer
F20 error code
Hi.
F20 means that there is a water inlet problem:
Reasons for error F20:
(Water Inlet Problem-no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
If that does not help inlet valve, pressure switch and control module must be tested. The defective part must be replaced.
Here the tech sheet.
Regards.
Ginko
Aug 20, 2011 | Kenmore HE2 Plus Front Load Washer
My kenmore elite keeps showing f20 near the end of my wash cycle
f20 can be your fill a fill hose problem, flowmeter problem.
But first i want you to check you hoses
turn the water off
take the hoses off the back of the washer
get a bucket
put the hoses in the bucket
turn the water back on...one at a time so that you don't get blasted with water.
Do both hot/cold come out with good pressure?
If yes try
take your lid off the washer between the inlet valve and your dispenser is there a white plastic piece one end going to the valve and one to the dispenser.
IF yes take it off and blow through it.
put back on and see if the code comes back
If yes
Then it is possible you may have a bad pressure switch.
let me know how it goes
if you take the kick panel off by removeing the t15 torx screws you will find the tech sheet to help you
Jan 11, 2010 | Kenmore Elite 45986 Front Load Washer
Our Kenmore HE2 keeps giving f20 error. Water pressure is fine. No kinks in hose. Cleaned out junk in trap behind the bottom panel. Ordered new pressure switch. Works fine on clean washer cycle, but with...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advises to eliminate the easy common sense items first
Dec 02, 2009 | Kenmore Elite 45986 Front Load Washer
Code F20 is appearing on me washing machine
May 27, 2009 | Kenmore HE2 Plus Front Load Washer
Hi
Error F 20 means "No Water Detect" error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.
You'll need to check for the following--
1- Check the Inlet water valve if it is clogged.
2- Make sure water taps are working fine.
3- Check inlet hoses for kinks or clogs.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 26, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite quiet pak 4
its a inlet water supply error code check your cold fill line and fill screens at cold fill valve for block
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
F 11 code
The electronic control board is damaged. It needs to be replaced. I think its Part#8182237. As of this date, it is on back-order. Check your warranty book on this part, it is highly expensive. It may be covered under a 2-5 yr. part only warranty.
Sep 03, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Washer Logo
228 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
