Question about One Touch Cell Phones
Check on status of current orders
Nothing, this is my first attempt (today) to access status of One Touch
I have HP Color LaserJet CP1515n Printer wanted to configure on domain base network . Just need to know the IP address of this printer????
Status TheStatusfolder contains links to the following main pages.
  • Device Status. This page indicates product conditions such as a jam or an empty tray. After you correct a problem, clickRefresh statusto update the product status.
  • Supplies Status. View details such as the estimated percent of toner remaining in the print cartridge and the number of pages that have been printed with the current print cartridges. This page also has links for ordering supplies and for finding recycling information.
  • Device Configuration. View a detailed description of the current product configuration, including the amount of memory installed and whether optional trays are installed.
  • Network Summary. View a detailed description of the current network configuration, including the IP address and network status.
  • Print Info Pages. Print the Configuration page and other information pages, such as the Supplies status page.
Dec 13, 2014 | HP Office Equipment & Supplies
Put new battery in now car does nothing....no power going to car at all. not able to jump...no lights...no start...nothing. located relay box and cross-over wire burned out and one red square fuse. how...
Sounds like your Main 30A Fuse Link (i.e. hot at all times) or an in-line fuse may have blown, during cable connection (or due to incorrect jump starting).
First, follow the RED + battery cable from the battery and check if there is an in-line fuse along the cable - replace if blown.
The Main 30A (depending on model) Fuse is situated up in the engine bay fuse box.
These fuses carry a lot of current and hence, are usually secured into the fuse box by either large screws or 8-10mm bolts. Look for the mounting screws/bolts on the side of the blown fuse (you may have to undo another component to gain access to your main fuse).
Make sure the battery is disconnected BEFORE you attempt to replace any fuses.
Good luck..
"Please take a moment to rate this solution with a 'testimonial' and/or 'thumbs up', as this will keep my status active and allow me to continue offering technical support. Thank you."
Aug 04, 2011 | 1992 Subaru Legacy
My HP Pavilion Special Edition Notebook turns on fine and touchpad moves cursor, but nothing will respond when tapped on, including keyboard buttons. Any suggestions would be greatly appreciated. Thank...
HI,
Try going into the control panel (accessed from the start menu) and checking the status of the touch pad and buttons - these can be modified from this panel. You may need to plug in a mouse to be able to navigate in order to do this. A plug and play mouse should work when plugged in although you may need to restart the computer. Hope this helps.
Steve
Jan 24, 2011 | HP Computers & Internet
Please tell me if my order, # 002-7851756-8321810 was shipped to Todd Bussert in Ct. Thank you for your help
For order confirmation, you need to directly log in to your account with Amazon. From there, you can click "Your Account" in the right corner, then "View Open Orders". You will be prompted to log in again with the same information. After this, your current order will be displayed and will be given access to its status and tracking numbers.
Oct 17, 2010 | Amazon Computers & Internet
TEAC DW-28E DVD/CD-ROM not reading TDK DVR+R disk
ON a computer than can read the disk and has CD/DVD burning software installed on it, check the status of the media sessions. If this was writtien as a multi-session disk and the session has not been closed, many older drives will have difficulty reading it.
May 30, 2009 | Panasonic Computers & Internet
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
Insufficent memory to send scanned document
What model? If it has a touch screen do what it says: In "scanner mode" touch the "status" button on the screen..all scans show up with the status.Touch the appropriate scan, and touch "delete" (or cancel)
Mar 30, 2009 | Ricoh Office Equipment & Supplies
I cant get virgin netgear router to connect to my medion laptop, i get to the last part of the installation process when it says attempting to connect to newtork and it comes up move your connections...
Have you accessed and setup your wireless part of the modem?
To access the router settings menu, you will first need to log into the Wireless router following the steps below:
Open Internet Explorer
In the address bar type the following address:
192.168.0.1
You will be prompted to enter a Username and Password to access the interface, please use the following default details:
Username: This can be found on the bottom of the router
Password: This can be found on the bottom of the router
From the list on the left hand side, click on ‘Router Status’.
Within the Router Status section there are two areas you will be able to access:
Show Statistics
Connection Status
The Router Status page gives you a detailed status overview of the connection configured on the Wireless router.
Click ‘Connection Status’ to see more information on the broadband connection.
If you have already configured your broadband, you are able to establish/terminate the connection by clicking Connect/Disconnect.
You can also click ‘Show Statistics’ to show you current connection speed and more information on your Broadband connection.
Clicking on Basic Settings enables you to check all the Internet settings of your Broadband connection. Including the Login name (username) and password, IP address and type of connection.
Clicking on ‘Test’ will perform a standard check of your Internet connection and settings.
ADSL SETTINGS
The ‘ADSL Settings’ section provides you with some more information about your Internet connection. These are:
Multiplexing Method
VPI
VCI
WIRELESS SETTINGS
This section gives you full information regarding the Wireless connection. From here, you can change security settings, the SSID (Name) of the router and the access control list. Options list from:
Name(SSID) virgin broadband (default)
Region Europe(default)
Channel 11(default)
Mode g&b(default)
Enable Wireless Access point
Allow broadcast name
Security options (None, WEP and WPA)
- hope this helps
Jul 03, 2008 | Computers & Internet
Cell Phones Logo
51 people viewed this question
Top One Touch Cell Phones Experts
john smith
Lawrence Oravetz
Are you an One Touch Cell Phone Expert? Answer questions, earn points and help others
