Hi i have a technika lcd 39 c-273 tv and when switched on just says DO NOT POWER OFF SCAN and just keeps continuously scanning, any ideas? thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
It may be looking for a connection to the Internet to do an update download, or maybe a bug fix. Do you nave internet? At least check the manual for updating and what the requirements are. Maybe a bluetooth connection to the tv is being searched for.
Posted on Dec 11, 2014
Shuttle83
  • 1139 Answers
SOURCE: technika lcd 32
Hello hibbie,
I gave this advice on another post, it applies in this case too so here it is:
This is an indication that there may be a problem in the power supply, possibly bad capacitors, and or defective active components. I would suggest first checking to see if there are any blown fuses, and or loose connections. Past this point I would advise that you either take the TV to a TV repair shop or have a TV technician troubleshoot the TV in home to determine the problem it is having.
I hope this helps,
Thank you,
Shuttle83
Posted on Aug 10, 2008
SOURCE: Technika LCD19id - No power to internal fuse
I have a Technika 22 inc hd flatscreen that will not power up. you can here the dvd running if you load a dvd but the television side wont power up.I have tried to find the internal fuse but have had no luck.Anyone help?
Posted on Dec 14, 2008
  • 280 Answers
SOURCE: how to scan for new digital channels small Philips flat screen
From the menu you should see set up the cannel scan should be there.. If all else fails unplug the TV for a few minutes then plug it back in. It should ask if you want to set up the tv, Say yes and follow the steps.
Posted on Jun 16, 2009
  • 144 Answers
SOURCE: Hi, my Goodmans LCD TV
I would look at the power supply, if you follow the mains lead wires it will go straight to the power supply . I would look for swollen capacitors , they will look a bit like small batteries. and the silver top should be flat (not domed) compare these components to each other if any are domed you should spot them easilly. Now what, this is the hard part, they nead replacing, you need to have used a soldering iron to remove these components. I had this fault in a friends tv, The components are quite cheap and availably on the internet but not a job for the novice,
hope this helps
pete
Posted on Nov 09, 2010
  • 152 Answers
SOURCE: I have a Technika 32" LCD TV . when switching it
Check the connections??? Maybe get it replaced or repaired.
Posted on Jun 05, 2011
Technika tv lcd 37-207 wont switch on blue light keeps flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 26, 2014 | Televison & Video
JVC TV LT-42X579 LCD TV 42 in.Does this TV have a Lithium battery for maintaining memory, similar to PC computers?
No. It has no such battery inside. Its memory IC is non-volatile type, and need no back-up electric charge to retain the data, even after it is switched OFF. http://electronicshelponline.blogspot.com/
Sep 18, 2014 | JVC LT-42X579 42 in. LCD TV
Logik tv
I suspect that this is a Tesco TV?
The fact that it scans on switch on make me think that its flash ram is volatile being unable to record the results. I don't know if this is a battery backed memory or nvram which has an old type store.
If this is within the gtee period take it back.
If the menu allows it find factory reset.
It may be that the stored data is corrupt and unable to write over with the new settings.
Some back door resets are accessed by holding a key down and then switching on the television. Another test to try is to unplug the tv for a day as any corruption may be held by standby current.
Aug 22, 2014 | LG 32LD550 32 in. LCD HDTV
Technika lcd 32
Probable power supply failure.
Jan 13, 2014 | Televison & Video
Technika 40inch tv
Turn off the power, it is only trying to scan for channels. It will not damage any hardware to shut it off.
Jul 01, 2013 | Televison & Video
Technika 32-270 LCD TV won't stop scanning
Need help stopping scan on tv, won't turn on and no remote will activate anything on the monitor. Help flat screen tv.sanyo keeps on percenting
Dec 31, 2011 | Televison & Video
Jun 05, 2011 | Televison & Video
I have a brand new technika tv 216/54g. It has freeview built in. I have a brand new indoor digital amplified aerial also technika but I cant get it to pick up any stations. Do I need anything else? please...
You don't necessarily need anything else, but you may not have a strong enough signal to pick up the digital/freeview channels using an indoor aerial. It could also be that the indoor aerial is not correctly aligned.
If the signal strength is lower than approx. 50%, the TV may detect them during the automatic channel scan but it wont store them. When the signal strength for any digital channel is 50% or lower it's more or less unwatchable - the picture would be constantly breaking-up or freezing and the audio drops out continually. Trying to scan for channels using an indoor aerial is rather hit and miss. Numerous attempts may be necessary before you get any channels.
Assuming you have a roof aerial, it is far easier to temporarily connect the TV to a fixed aerial point while you run the automatic channel scan. The TV will store all the channels and you can then move it to it's permanent location and connect the indoor aerial. You can then adjust the indoor aerial with the channels already stored until you find a location for the aerial where you have a good signal.
Doing it this way also eliminates the possibility of a fault with the TV and confirms that you are performing the channel scan correctly. If the TV is connected to a fixed aerial point and you are still unable to receive or store any channels, then it's likely that you are performing the channel scan incorrectly or there is a fault with the TV.
Please try scanning your channels using a known working fixed aerial point. If you are still unable
to receive any channels - or you don't have any fixed aerial points - please post back for further assistance.
Hope this helps.
Regards,
BElectric
Feb 28, 2011 | Televison & Video
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
Technika LCD19id - No power to internal fuseMy LCD 19id-107 tv turned itself off and will not come back on. I have power to the 3 pin power connector at the rear of the tv. However i have no power to the...
Nov 15, 2008 | Televison & Video
Televison & Video Logo
220 people viewed this question
Top Televison & Video Experts
Electro Med Services...
