How to repair the switching-mode power supply of a television?
A; By wearing a wrist band that defends against static recharge b; By wearing a pair of shoes that have isolated soles c; We have to take care of plugging in the electric plug, because the grounding of the network has to get to the chassis of the equipment d; By using an isolation transformer
    Master:
  • 373 Answers
I don't understand your question. What is the problem you are having?
Posted on Dec 11, 2014
Testimonial: "I am trying to answer a test question from elektrotanya.com..."
Manual for tv 237-t12
Try Googling (brand)(237-t12)(manual) without parens.
Jun 22, 2017 | Televison & Video
Philips model 52pfl5704d/f7 no picture and no sound
Could be an open internal fuse or power supply failure
Jun 12, 2017 | Philips Televison & Video
Lg 60pn6500 no picture no sound red stand by light comes on
Hello Virgil Hoppe,
Never ever try to repair these things without a anti-static wrist band...!! (below)... About $6...(very serious).
A tiny spark you might not even feel.. is the PRIMARY REASON every semiconductor box you have EVER looked at says
"No USER serviceable components inside"...
That spark can totally DESTROY almost every SEMICONDUCTOR ever made... Professional
HANDLING will always be done by ESD (electro-
static discharge) trained personnel...
Your POWER BOARD is most likely the problem...
(Red STBY is a really good sign: MOST LIKELY not your
MAIN-BOARD (but still... just an educated guess)).
>> ALWAYS WEAR that anti static wrist strap
>> VERIFY your replacement board number yourself...
> TAKE LOTs of PICTURES (and notes if necessary)
put EVERY wire & fastener EXACTLY BACK...!!
> Force nothing: if a connection does not easily
come apart get a jewelers loupe and a bright light...
Look VERY CLOSELY for a pinch clamp or catch
lever to release...
(don't forget you will need to select a SOURCE
on initial power-up).
You will be proud.
Sears ... shopjimmy.com eBay, even AMAZON HAS
replacement boards... I regularly use eBay...
(but I'm only buying USA circuit boards)
Hope this helps.
LG 60PN6500 Power Supply EAX64880001/6 EAY62812701 #P10092 - #P10092
Shop jimmy (premier supplier (out of stock))
http://www.shopjimmy.com/lg-eay62812701-power-supply-unit.htm
lg-eay62812701-power bd, REPAIR KIT appprox $15
eBay repair & return service (postage included)
approx. $50...
Terrible price... (example only):
Amazon com 60pn6500 power
>> ESD (anti-static protection)
Amazon com Rosewill ESD Anti Static Wrist Strap Components RTK 002 Black...
Carnac the Magnificent
Jun 07, 2017 | LG Televison & Video
Looking for electrical testing meters
"METER" Question
leaves a WHOLE lot open to interpretation...
If you are looking to see battery at the BATTERY itself ...
or even a TAIL LIGHT...
Garden variety METERS might be a SAFE way to go...
(REMEMBERING... the
slightest mistake = air bag DEPLOYMENT (explosion)).
but... (and this is a BIG but)
You CANNOT use ordinary "METERS" on
>> sophisticated electronic / semiconductor equipment...!!
Base line: Only HIGH IMPEDANCE PROBES ...
(LOGICALLY imperceptible) can be safely
( perhaps even effectively )).
OBD (on board diagnostics) have been STANDARIZED
over the past couple of decades to report in INDUSTRY
acceptable DTC (diagnostic trouble codes)...
Behind that... there are the COMPLETELY PROPIETARY
(property)... firmware/software EXPRESSLY owned
(for example VW) with only USER privileges extended...
(right to use) to any/all of their customers.
In the fine print of EVERY RTU I have read in my
extensive careers in STORED PROGRAM CONTROL..
"REVERSE ENGINEERING" has always
(consistently & completely) been FORBIDDEN...
(with Brigades of ATTORNIES to ENFORCE
(or defend... depending on what/who gets damaged)).
So... as to your question about "METERS"... (et al)
Typically those cheap/FREE/promotional digital
meters given away to attract customers to
HARBORFREIGHT (for example)... can be used
to check SUPPLY volts, amperes & ohms...
are completely acceptable...
So LONG AS YOU KNOW EXACTLY WHAT
YOU ARE "METERING"... (in my humble opinion).
And as ALWAYS... Wear your anti-static wrist strap
every-time you handle ANY semiconductors you
care about (ESD - protection: see below).
ELSE
Expect to be purchasing ($$$$$) expensive
electronics... and AIR-BAGS.. Savvy?
Firefold
https://www.firefold.com/tester-digital-clamp-meter
Harborfreight
6 Function Mini Digital Multimeter
Search results for volt meter
ESD ($6 Static Wrist-band)
Jun 07, 2017 | Cars & Trucks
Repair Sony nsx-40gt1 tv, no picture, 2 red blinking lights where normally green. Is the power supply board bad, t-con bad or main board bad. Who sells repair manual?
Hello Eric,
shopjimmy has the circuit boards and gives live support..
Check out the URL below.
Also consider getting an anti-static wrist band... so you don't destroy good semi-conductors with tiny static sparks.
Further information on that is under "ESD"
(Electro-static Discharge)
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 14, 2016 | Sony NSX40GT1 40 Inch Internet TV powered...
Major Static when first turn on
You could try wearing a static arm band. Something like this might help - Belkin Anti-Static Wrist Band with Adjustable Groundingir?t=dc0c7-20&l=as2&o=1&a=b00004z5d1
Nov 26, 2014 | Samsung LN46A530 46 in. LCD HDTV
How to remove exterior card cover so i can install a new card
Dear William,
Best practise: wear an anti-staic wrist-band! Leave machine plugged in to power but make sure that power is switched OFF at wall - (this will ensure that the machine is safely 'earthed'. . Open box cover - there are usually release button(s) to do this. Once computer box is open, connect anti-static wrist-band alligator clip to bare frame. The PCI-card covers are usually attached by one screw/nut: UNDO. Remove slot-cover. Insert new card into PCI-slot. Make sure it is home & replace locking screw. Remove anti-static clip. Close box. Power-up & let Windows find/install new device. I hope that this helps - 'b'ye - Bruce.
Jan 02, 2014 | Gateway DX Computers & Internet
Ok tried password jump on motherboard but if i put the back on the place where they were by the cmos battery the power light quits flickering like a strobe light but it has to be on the password jumper to...
Dear Jeremy,
BEST PRACTICE: ALWAYS WEAR AN ANTI-STATIC WRIST-BAND WHEN FIDDLING IN THE BOX!
The human body can store up to 50,000 volts static electricity which is more than enough to fry components. MAKE SURE YOU ARE EARTHED! (1.): Switch power off at wall. Leave plugs in - (this will ensure that the computer is 'earthed'. (2.):Open box. (3.):Connect anti-static wrist-band alligator clip to bare metal frame of box - a bare screw head will do if you can not see any uncoated metal in the box). The password jumper has 3x sockets in a row. (4.):Move jumper plug to other 2x sockets to reset - (blank) - password. (5.): Remove anti-static clip. (6.): Close box cover. (7.): Power-on at wall. (8.): Reboot. If you want to reset a new Password, repeat above steps & move jumper-plug to other 2 sockets...when you reboot, you will be asked to enter new password. I hope that this helps - 'b'ye - Bruce.
Dec 27, 2013 | Computers & Internet
Power supply needs to be replaced
Hello Matthew Moore,
I would URGE you to use your MODEL NUMBER
to search for your circuit board(s)...
Your OLDER Apr 22, 2012 entry shows a model number
of LG- DU60PY10...
Which resolves to two power boards (pictured below)
3501v00194b and 3501v00195b (both at $19 USD)
LG DU 60PY10 Sub Power Supply Boards 6870VM0496C 6871VPMA59C eBay
I get ALL my circuit boards from eBay
(fully protected ... IF you are prompt)
Do not forget to wear that ESD (anti-static wrist band)
for EVERY semiconductor you care about... (seriously).
I am here daily if you need... comment me back
(take PICTURE BEFORE you get in trouble)
Nov 26, 2017 | Televison & Video
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
