Question about Music
I bought a GNX3 from pawn shop, but it doesn't seem to register any input signal coming in to the unit
Guitar and cords are good, but no signal is getting in. tried to plug CD payer into aux in (jam-along feature) but no signal getting in there either
  • Music Master
  • 3,506 Answers
The unit is likley defective and you will need someone to diagnose and fix it, someone who does electronics repair and diagnosis
Posted on Dec 11, 2014
Digitech gnx3 makes cracking noise and the clip indicator comes on when it does
Hi Chris,
This is a discontinued product for the work station. Digitech does have a firmware update on their website. Have you tried that? Other then that, usually a bad guitar cord, dirty input jack or faulty input jack caused the cracking sound. These units sit on the floor where dirt and dust collect. Try spraying the input jack with a good quality conduct cleaner. (Radio Shack?) Make sure your guitar jack is also clean and then "exercise" the input by plugging the cord in and out several times. I am assuming this may help since it is the most simple approach. Otherwise, it may be a component issue and that cannot be addressed via email.
Mar 02, 2017 | The Music
you will have to have the system checked out and as it came from a pawn shop it likely is not functional as it is/was
Dec 10, 2014 | Music
Static at louder volumes
All you need to confirm is to remove the connection to the guitar, remove the jack and cord to the guitar and now check if the noise is prevalent at higher volume, when the volume control is turned up. If so the fault is with the cord , the jack or the gutiar pick up insulation or internal connection or shielding.
Cross check with a seperate cord or another amplifier to confirm the case.
If the noise is from within the amplifier then it is possible there is fault in the preamplifier, fault with shielding of the inputs or the preamp, broken groung connection.
Compliments of the Season.
Dec 24, 2011 | Roland Ac60 Acoustic Chorus Guitar...
When I plug in my guitar to the Fender Frontman 64R Amp and I just barely move the cord, it make this really loud screeching type noise. It's not an old amp; I got it about five months ago. I can't...
Yes, there are several possibilities. First thing is to disconnect your guitar and then plug in the cord to the amp. Expect a bit of hum. If it screeches, then problem is not feedback via the guitar. If it doesn't MAYBE your guitar is "hearing the amp" which the guitar is then a microphone and can feedback. Moving the cable generates electrical noise which can trigger the feedback to start.
If you get the screech without the guitar connected, then TRY a new guitar cable. Make sure it is an INSTRUMENT cable... I have seen some try to use speaker cables or junky 1/4 inch cables intended for home stereo... these will NOT work and can cause the feedback. The next possibility is a broken jack on the amp. This would require repair. The common cause of this is to fail to run the cord through the handle of the amp... one trip on the cord or step on it pulling the plug sideways in the amp and the jack is broken and it is a trip to the shop as well. While on the subject ALWAYS run the cord at the guitar end either through the strap or your belt loop. Cords left dangling keep rotating and soon wear out the plug and also the jack in the guitar and then that has to go to the shop.
May 16, 2011 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Just bought it and the light won't come on. I've tried it with a battery and a wall plug in, the thing won't play, I don't get it. What do I do? And the cords were in the right slots and everything, the...
If you just bought it, exercise your warranty. Don't risk voiding the warranty. Make sure you have the guitar input cable plugged in as this turns on the battery or power to the unit.
Apr 13, 2011 | Washburn LSEBOD Blues Overdrive Pedal
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
How do i plug my eletric guitar into an amp
Connect a 1/4" instrument cable from the guitar's 1/4" jack to the amp's 1/4" input.
Oct 02, 2009 | Dean Guitars Dean Ml79 Electric Guitar
Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Jan 22, 2009 | Epiphone Les Paul Studio Electric Guitar
Music Logo
29 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
