Question about blackboard.com Computers & Internet
What does the error ID ad9a863a-9cf9-455e-bf86-b76fe0776a9a mean?
My mini engine light comes on with cc id 031 what does it mean
it is emissions related would check for bad fuel cap and/or cracked valve cover
Jan 08, 2018 | Mini Cars & Trucks
How do I recover from an error 401 to activate facebook?
Generally this error message means you need to log on (enter a valid user ID and password) somewhere first. If you have just entered these and then immediately see a 401 error, it means that one or both of your user ID and password were invalid for whatever reason (entered incorrectly, user ID suspended etc.).
So double check your email id and password.
Mar 10, 2015 | BitDefender Antivirus Plus 2015 - 2 Year...
Error code 401
Sounds like you are probably messing up the username and password.
"Generally this error message means you need to log on (enter a valid user ID and password) somewhere first. If you have just entered these and then immediately see a 401 error, it means that one or both of your user ID and password were invalid for whatever reason (entered incorrectly, user ID suspended etc.)."
www checkupdown com status E401 html
Mar 14, 2014 | Facebook Computers & Internet
What does service code sc350 mean?
SC350:
Problem:
ID sensor pattern test error
Description:
One of the following ID sensor output voltages was detected twice consecutively when checking the ID sensor pattern.
1) Vsp ? 2.5V
2) Vsg ? 2.5V
3) Vsp = 0V
4) Vsg = 0V
Possible Problems:
• ID sensor defective
• ID sensor connector defective
• Poor ID sensor connector connection
• I/O board (IOB) defective
• High voltage supply board defective
• ID sensor dirty
• Defect at ID sensor pattern writing area of the drum
** Generally, I've found this problem to almost always be one of the last two items listed above.
Jun 21, 2011 | Gestetner DSm745 Black and White Copier
Error id 0x80040356 remedy id 0x00000000
0x80040356 is a DOS error code meaning that the data supplied is not in the correct format. In other words you have a Registry Error problem.
There are a lot of companies supplying software to cover this error on the web.
It is possible that Windows has detected an "Intruder" and closed the system down into protect mode.
Try starting in Safe Mode first.
Hope that helps.
Dec 11, 2010 | Acer Aspire 3002LCi Notebook
This ID is not yet taken.But using the id from past four years.
please check you id and password very well and make sure they are correct.and if you try it again and error keep coming up,that means it is a technical problem,just be patience and try again or refresh that page.ok
Jul 13, 2010 | Yahoo Mail
What should I do when 401 unauthorized is happened?does it have any relationship with my modem? best Regards
401 error: Generally this error message means you need to log on (enter a valid user ID and password) somewhere first. If you have just entered these and then immediately see a 401 error, it means that one or both of your user ID and password were invalid for whatever reason (entered incorrectly, user ID suspended etc.).
Are you trying to access your modem's gui?
additional info/reading:
http://www.checkupdown.com/status/E401.html
Aug 09, 2009 | ASUS Computers & Internet
What does it mean if I get a response from
If you get a mailer-deamon the it means that the ID to which you have sent is either
not valid or
ID is not taken or
because of some server probelms the mail din't go through.
or the ID has been taken by someone but has ot been in use for ages because of which yahoo blocks the emails to that account until it is reactivated.
Jul 12, 2009 | Yahoo Mail
Xante Cl30 laser printer error
Error 125 is indicating an error detected at MT home position, which means the transfer belt may not be returning to the proper start position. The normal solution to this, if it persists after a restart, is to replace the transfer belt.
Mar 26, 2008 | Xante CL30 HSE Laser Printer
Computers & Internet Logo
60 people viewed this question
Top blackboard.com Computers & Internet Experts
David Payne
David Payne
Are you a blackboard.com Computer and Internet Expert? Answer questions, earn points and help others
