Question about Kenmore Kitchen Ranges
On the kenmore 7423 gas stove which burners have what btus. we want to convert it to LP and have to replace the orafices but don't know which ones go in which burners
Called sears technical , got an untechnical technician.
    Sergeant:
  • 405 Answers
SMALL ARE 8K AND LARGER IS 12K
Posted on Jan 05, 2015
Krazytech
  • 725 Answers
SOURCE: Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Posted on Aug 25, 2007
SOURCE: LP conversion for Thermador 4 burner range top
I have a Thermadore 6 burner gas cooktop PCG366E purchased January 08. I purchased the LP conversion kit, they only make one kit for all models. The instructions included with the kit were written for an older model and have not been updated by Thermador. The gas regulator is located next to gas inlet pipe. You have to get at it from above. Remove the 2 star burners over that side of the cooktop. You will need a 20mm socket to remove the nut at the center of the star burner. Lift it off and disconnect the wire to the ignitor ( You need to push on the spring lock in order to seperate the the connector terminal). Remove the stainless steel pan and then remove the metal pan underneath ( you will need a Torxs bit for this screw or vise grips). You should now see the regulator. At the top of the regulator is a cap with the letters NG visible. Twist this a 1/4 turn ccw, lift up and turn over to expose the letters LP reinsert. The regulator is now ready. You will need to replace the orifice tips at each burner. Use a 7mm socket with an extension. Put a piece of tape in the socket to hold the orifice in place while you insert it. You also need to adjust the valves. You must pull off the knobs and and remove the trim bezel. If you look through the screw hole on the right you will see a screw head (bypass screw). Insert long skinny flat blade screwdriver through the hole and turn the screw CW all the way (about 1/4 to 1/2 turn in my case). My cooktop had two burners with a low simmer feature, This devise is located in front of the bypass screw. It has a hole in it but does not align well with the head of the bypass screw and makes it difficult to turn the scew. Thats it, I hope this info has been helpful. I have not yet connected the propane therefore have not tested the unit but it should work.
Posted on Feb 27, 2008
Fixe_You
  • 1800 Answers
SOURCE: kENMORE GAS STOVE MODEL 790-71105893 electric burner starter(s) gone and oven door seal needs replacing. reasonable to repair perhaps with sears or replace?
of course just replace the sears and everything is gonna be okay!!
hey dont forget rating me!!
PS:but the same ones!!
Posted on Aug 18, 2008
daddy1264
  • 76 Answers
SOURCE: Kenmore gas stove
replace the spark module
Posted on Jan 03, 2009
jumptrout51
  • 3361 Answers
SOURCE: Gas range burner flame too high and too yellow.
Did it work OK in that location before the changes?
Sounds like you used Natural gas parts instead of LP.
Lp orifices have smaller holes than Nat.
Posted on Mar 12, 2009
Kenmore grill 146.23766310
Here is the owner's manual:
http://www.managemylife.com/mmh/lis_pdf/OWNM/1212186L.pdf
In it, it states, "Use grill, as purchased, only with LP (propane) gas and the regulator/valve assembly supplied"
Oct 30, 2013 | Grilling
Tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
HOW TO CONVERT FROM NATURAL GAS T PROPANE
Their are 2 types of ranges. Ones with sealed burners and ones that do not have sealed burners. The sealed burner ranges must have a kit to replace the orifices. The none seal burner models are simply called crank down and flip models. That means you flip the screw on top of the regulator to where it reads LP. and then you tighten down the spuds on the top burners and the oven valve and then you adjust the air shutters.
Note: Some stoves with sealed burners cannot be converted to LP. The model number you posted is not a correct model number.
Nov 19, 2010 | Kenmore 72002 / 72004 Kitchen Range
Turbo STS grill, converting to propane from natual gas, orafices arn't available from Turbo
I would like to convert my Turbo STS grill from propane to natural gas. Where can I find the correct sized orifices?
Jun 17, 2010 | Barbeques Galore Turbo STS 4-Burner with...
DCS 5 burner 30" oven makes loud noises as if starved for fuel
Hi; Is the oven run with LP or NAT gas. Sounds like a regulator problem not letting enough gas through. Also is this a comercial unit. If so when was the last time all burners and pilot orafices were cleaned out. The burner tubes have a air vent cut into the burner at the orafice. Make sure no debris have covered these airways.And lastly how old are the thermocouples and are they secure to the gas valves and have a good pilot flame on them...
alpharome416
Feb 23, 2010 | Ovens
Converting FrigidaireStove Model FGF368GSB From LP To Natural Gas
hi you will need to get in touch with your local appliance parts dealer and buy a Natural gas orafice spud..thats basically all you need change although some manufacturers orafices you either losen or tighten up the orifice...like i say contact a local appliance parts dealer for the part. Hope this helps..please feel free to comment again if you have any other questions or concerns.
Jul 02, 2009 | Kitchen Ranges
Stove Top Burners
was the stove design for LP????
you need to get a convertion kit form the manufature, if you convert the natual to LP gas.
Oct 22, 2008 | Hotpoint RGB745 Gas Kitchen Range
Jdr8895aas
This is the solution to convert from LP back to natural gas that I posted as a comment on this thread:
After much work and little help from Jenn-Air or Whirlpool, I found a satisfactory solution. As many of you may have found out, Whirlpool does not sell the natural gas orifices to the JDR8895AAS separately as they do the LP conversion orifices. Instead, they recommend that you buy all 5 orifice holders that include the individual orifices. This would run about $120-150 depending on where you shop. If you want to take this route, the Whirlpool parts you need are:
1x740079621x740078132x740079611x74007816
Fortunately, because natural gas is denser than LP, the LP orifices can be bored out for a conversion back to natural gas. After a lot of homework I was able to find someone with the natural gas orifices for this stove that let me take them out to measure them. For some crazy reason, Whirlpool does not have this information:
Find a machine shop or a good appliance repair shop that has a wire gauging bit set. The natural gas orifice hole sizes are as follows:
Left front burner (16K BTU): 48Left rear burner (9.2K BTU): 54Center burner (5K BTU): 58Right front burner (12.5K BTU): 52Right rear burnger (5K BTU): 58
It cost me $25 to have these resized after I found the correct hole size.
Finally, to complete the conversion back to natural gas, you must flip the plastic screw-shaped piece by unscrewing the hex nut on the regulator at the back of the stove.
Hope this helps, because it took me a while to figure it out.
Apr 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Low flame
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
