Question about Tristar Vacuums
How do I find the parent company for Tristar Vacuums to get it fixed or replaced per the warranty? the motor shuts off after 5 minutes the first time, then 2 afrer it cools. I need to go to the manu
New filters, cleaning everything per instructions, Blowing out the wands and checking for blockages. HOw do I get in touch with the manufacturer?
  • 3,506 Answers
I would start with the place you bought it and advise you want/need warranty repairs and/or the warranty repair station etc informastion
Posted on Dec 11, 2014
5 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
http://dysonmanuals.llc.nu/
Posted on Oct 16, 2008
rustysheriff
  • 344 Answers
SOURCE: Dyson cleaner keeps cutting out, no blockage found, filter clean.
1. Check the on/off button these can also be troublesome and if you've stood on the cable once or twice you could have a break in the wire and it's shorting, check by turning on and wiggle cable around where it enters machine.
2. Faulty thermocouple, it is held in a white plastic housing screwed with one T15 torx screw to the motor housing. You could replace it but I just shorted mine with some wire and it hasn't failed since and more importantly not caught fire yet!
Posted on May 28, 2009
VacuumRepair
  • 438 Answers
SOURCE: There is no suction from
Hi Doug,
There are several things that this could be. Probably the most common problem that we see when customers come in with this problem is actually a fairly simple problem to fix. Here are just a few things that this could be.
The fist possible problem is a VERY common problem actually.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
If you are getting suction power from the hose, but the vacuum still doesn't pick up on the floors, I think that these solutions should fix your problem. If you just replaced the clutch mechanism, the roller brush should be fine, but turn the vacuum over on it's side and make sure that the roller brush is actually spinning while it's on carpet mode. If none of these problems fixed your Dyson, please use the Clarification Request, or leave another comment here on the Fixya repair page, and I'll be happy to further diagnosis the vacuum cleaner with you.
I hope this was helpful to you. If so, please be sure to rate the repair as helpful by clicking the thumbs up icons in the top of the repair page. This is what keeps Fixya repair professionals like myself continue posting these detailed repair solutions for free, rather then just the premium ones that users pay to have answered. We really do appreciate when someone recognizes the work you've done. Thank you very much,
Chris J.
GoVacuum.com
Posted on Aug 09, 2010
SOURCE: Hoover Sensory 2200W Overheating and Shut-Down
Did you ever get to the bottom of your overheating and shut-down problem? Just got the same problem :(
regards,
Posted on Jun 20, 2011
Tristar vacumm gets hot when using
Replace the motor filter and the exhaust filter if you have one. The cloth bag may also need replaced. Overheating usually meAn something is restricting the airflow.
Nov 06, 2017 | Tristar Vacuums
I just replaced the cord in my Tristar vacuum. Power head spins but motor not running?
Seems you may have wired it to send power to the power head but not the motor.
Jul 12, 2017 | Tristar Vacuums
Compact TriStar motor replacement..difficult?
It is not a difficult task. It is very easy. Take out the damaged motor, and replace it with a new one. What else?
Dec 13, 2016 | Tristar Vacuums
How do you replace the power button on a tristar vaccum
You need to list the actual model number to that vacuum. Then I can give you the correct/specific instructions.
Feb 03, 2015 | Tristar Vacuums
How do I access the motor and replace the brushes on compact tristar vacuum cleaner?
I need the actual model number for that vacuum and then I can give you the correct/specific instructions.
Where to find tristar blender model yd 208 motor
Do a web search and type in Tristar Blender Model yd 208 motor. If you can get the part number from your old one, that'll make the search even easier.
Aug 29, 2014 | Vacuums
I was told that you do not produce the tristar vacuum..Is this true? And if so does that mean my warrenty on my vacuum is void?/
try this site to order tristar parts and accessories.
https://www.tristarvacuumscanada.com/
most warranties are from the brand, and not the place you bought it at. tristar still seems to be in business so your warrenty should be in tact.
Oct 26, 2009 | Vacuums
It runs for a couple of minutes shuts off then restarts 30 seconds later runs a couple of minutes and does this over and over
Most vacuum motors are protected from overheating by a thermal switch that resets after cooling down. Check for blockage in the hose,
power head or a full bag that would block cooling air from cooling the motor.
Tom
Oct 22, 2009 | Tristar Vacuums
Vacuums Logo
81 people viewed this question
Top Tristar Vacuums Experts
Chris Nomland
Chris Nomland
Charles T Nevin
Charles T Nevin
Are you a Tristar Vacuum Expert? Answer questions, earn points and help others
