Question about Whirlpool Refrigerators
Whirlpool refrigerator ED5RHEXMT00 makes plenty of ice but is not dispensing any when the door lever is pressed. The water part is fine.
This is a repost of a previous but I can't find a way to add an important detail. I had mentioned before there's no sound when the lever is pressed. Correction: there is a sound that comes from the door. I also emptied the ice tray and put it back in place. The auger is not moving when the lever is pressed. I took tray out again and tried to turn the metal part attached to the freezer and it doesn't turn. Is it supposed to? Please help, I don't mind sticking my hand in to get ice in the summer but it's giving me brain freeze in the winter! :)
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
The ice bin slides down in little tracks and the drive mechanism engages the auger. It sounds like you have frost build-up in the bottom of the little slots that the ice bin rests in. The build-up keeps the drive from engaging the auger. I use a hair dryer to defrost all the accumulation under the bin once it is removed. Remove the bin by tilting out and then lifting up and out at an angle. Also empty the bin of ice cubes and check underneath for ice build up on the bottom of it too.
Posted on Dec 10, 2014
  • Rose Mary Dec 11, 2014
    K. Heading downstairs blowdryer in hand .. will post in a little while.
We have plenty of water and pressure coming to the refrigerator from the house, but when we try the in-door water dispenser, the water comes out at a slow trickle. Ice is not making. We installed a new...
whirlpool has had frozen waterline issues whats temp in refrigerator and freezer make sure refrigerator no colder that 37 degrees and freezer th 6 degrees
Jan 27, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ice maker has stopped making ice. Appears no water is getting into the trays. Water is on and water still dispenses out the door, but not in as heavy a stream as it used to. The sensor seems to be...
By your description it sounds like you have ice in the tray but it is just not coming out when you press the lever, if that is the case it looks like you have a common Whirlpool refrigerator problem, the motor is not spinning the auger. You might have to replace the motor module.
Nov 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Door dispenser will not dispense the ice.
you and many others have this problem . ( tip remove bin and rinse out with warm water dry it well and the door area also then the majic ... spray the dispenser with ( pam ) without the butter . clean and slick . this should help . mm
Jul 02, 2010 | Whirlpool ED2FHEXN Side by Side...
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
The ice maker works fine but we can no longer dispense ice from the door. No sound, nothing. Water dispenser works fine though.
There is a micro switch behind the panel above the dispenser lever. It's the switch that the leaver presses on when you push a glass into it to fill with water. Pop the panel off and you will see the little black switch I'm refering to.
Aug 15, 2009 | Whirlpool GD5SHAX Side by Side...
Ice machine makes ice but doesn't dispense when the lever is pres
I would check for an electric "flap" that opens & closes when ice lever is depressed. My GE has one and it has been fouled before causing the ice to be stuck inside the door. Hope this helps!
Mar 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Side by Side Refigerator won't engage ice dispenser.
Could be that the auger in the ice bucket is obstructed or broken, or the auger motor is bad.
Nov 02, 2017 | Whirlpool GC5SHEXNS Side by Side...
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Refrigerator will not dispense ice.
see http://applianceguru.com/view_topic.php?id=13243&forum_id=1&jump_to=76889
Feb 21, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerators Logo
60 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
