How do I delete files? - Audio Players & Recorders
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 49 Answers
Usually you can use the MTP protocol in your player's settings to attach your MP3 player to your PC or laptop via USB and manage the MP3 files on it with Windows Explorer.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
Posted on Dec 10, 2014
    Master:
  • 373 Answers
From an SD card? Remove the card and do it on your computer.
I deleted the files in recycle bin
Yes, it is technically possible to recover any deleted file (Even those removed from the Recycle Bin) by using file recovery software.
Check out the data recovery software called asoftech data recovery from link blow.
http://www.asoftech.com/adr/
Apr 20, 2011 | Computers & Internet
HOW DO i DELETE FILES
Right Click on the file you want to delete and Click on delete.
or
Left click once on the file you want to delete and click on delete key on the Keyboard.
or
to Permanently delete the file Left click once on the file you want to delete and HIT Shift+Delete.
Nov 16, 2010 | Computers & Internet
My nokia 6600 has virus called commWarrior
  • 1
    Click on "Menu," and then "Tools," and then "File Manager."
  • 2
    Select "Browse."
  • 3
    Navigate to the directory "c:system\apps\commwarrior," and delete the following files. To delete a file, highlight the file and click "Options" and then "Delete."
    "c:\system\apps\commwarrior\commwarrior.exe"
    "c:\system\apps\commwarrior\commrec.mdl"
  • 4
    Navigate to the directory "c:\system\updates," and delete the following files. To delete a file, highlight the file and click "Options" and then "Delete."
    "c:\system\updates\commrec.mdl"
    "c:\system\updates\commw.sis"
    "c:\system\updates\commwarrior.exe"
  • 5
    Navigate to the directory "c:\system\recogs," and delete the following files. To delete a file, highlight the file and click "Options" and then "Delete."
    "c:\system\recogs\commrec.mdl"
  • if this was helpful, write me a good review
    nick
    Sep 16, 2010 | Nokia 6600
    When you delete files is it possible to retrieve them later
    Normally, deleted files from the computer can be retrieved later using the Recycle Bin. When you delete something, it doesn't really delete, it marks the file as deleted, but holds onto it until you permenantly delete it. There are a few cases where deleted files can't be retrieved later:
    1. If the file is too large for the Recycle Bin, it will prompt you to permenantly delete the file.
    2. If the file resides on a network device or a different computer, it will NOT go into the Recycle Bin; it will be permenantly deleted unless the remote computer/device is a server which has a "deleted items retention period" configured.
    3. If you delete a file using "Shift + Delete", it will not go to the Recycle Bin; it will be permenantly deleted.
    Hope this helps!
    Mar 03, 2010 | Network Computing Devices (NSH800S/A)...
    It runs really slow and will freeze up. Ran a virus scan and nothing shows up. Ran clean up a defragment and upgraded the memory. nothing works.
    YOU CAN PERFORM A FEW MORE STEPS
    Manually delete cookie files in Internet Explorer 6 1. Exit Internet Explorer 6, and then exit any instances of Windows Explorer. 2. Click Start, click Run, type inetcpl.cpl, and then press ENTER. 3. On the General tab, click Delete Cookies in the Internet Properties dialog box, under Temporary Internet Files. 4. In the Delete Files dialog box, click to select the Delete all offline content check box, and then click OK.
    RUN DISK CLEANUP
    DELETE TEMP FILES
    1. Click on Start and then Run.
    2. In the text box in the Run window, type %Temp% and click OK. A folder full of files and other folders will appear.
    3 All of the folders and files you see in this Temp folder are no longer being used by Windows XP and can safely be deleted.
    4. To remove individual folders or files, hold down your Ctrl key while left-clicking on each item you want delete. Release the Ctrl key when you're finished.
    5. To delete these items, hit your Delete key or choose File and then Delete from the menu.
    6. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens.
    7. To remove everything inside the Temp folder, choose Edit and then Select All from the menu. 8. Now that all of the files and folders are selected, hit your Delete key or choose File and then Delete from the menu.
    9. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens. 10. After all of the files have been deleted
    DELETE PREFETCH
    2. In the text box in the Run window, type “Prefetch” and click OK. A folder full of files and other folders will appear.
    3 All of the folders and files you see in this Prefetch folder , Remove them.
    9. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens. 10. After all of the files have been deleted you can close the window and empty your Recycle Bin, permanently removing the files from your PC.
    Note: If you are unable to clean up the Prefetch files follow these steps to remove the Prefetcher from the registry residual
    Download Revo Uninstaller: http://www.revouninstaller.com/download/revosetup.exe
    AND REMOVE UNWANTED PROGRAMS
    DOWNLOAD CCLEANER CCleaner can be downloaded from http://www.ccleaner.com/ AND RUN IT
    CREATE A NEW USER ACCOUNT
    Jan 31, 2010 | HP Compaq Presario SR1602HM (CPQSR1602HM)...
    Deleting files from HTC Touch Diamond
    go to file explorer and select the files u want to delete and then try to delete them see what happens
    u can contact for more help
    regards
    Feb 28, 2009 | HTC Touch Diamond Smartphone
    I need 2 know how 2 uninstall info from my mp-4001 moV.ox centon
    Do this procedure for "voice" mode to delete voice recordings:
    Delete file (stop submenu) - Delete corresponding files and save files in Music mode, Voice mode or FM mode.
    1. In stop interface (FM without stop interface)
    2. Short press "MODE" to enter stop submenu
    3. Click "NEXT" or "PREV" to choose "single" or "all" files
    4. Short press "MODE" to enter the Delete interface
    5. Click "NEXT" to change "no" into "yes"
    6. Short press MODE to confirm the delete prompt
    "Delete all" will delete all related files stored in the selected folder. For example, if in music mode "Delete all" will delete all the music files, while other recorded files (e.g. voice recordings or FM recordings) will not be deleted.
    Likewise, if "Delete all" is used when in the "Replay" menu, this will delete all recorded files but leave music files intact.
    FM is much simpler – "Delete" or "Delete all" will delete the station(s) saved before.
    -Tha Mp3 Doctor
    Jan 08, 2008 | Centon Electronics MP4-001 MP3 Player
     Grubhead
    Grubhead
