Question about Home
How do I reset my SkyScan Clock - Home
5 Suggested Answers
SOURCE: I have a87900 model skyscan,can;t get it reset after replacing batteries
http://www.skyscaninfo.com/content/
they have instructions online
Posted on Sep 04, 2008
SOURCE: cannot properly reset skyscan atomic clock
press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
thanking you.
Posted on Nov 19, 2008
SOURCE: How do I reset my skyscan 86715 atomic clock?
SkyScan 86715:
>Press "SET" once,
>>press "+" until you see your time zone;
-4 ATL-Atlantic
-5 EST-Eastern
-6 CST-Central
-7 MST-Mountain
-8 PST-Pacific
-9 ALA-Alaska
-10
-11
-12
-6MT-?
>Press "SET" once,
DST ON/Off
>Press "SET" once,
US - duh, huh
F - MER-Mercredi, French
E - MIE-Miércoles, Spanish
>Press "SET" once,
>>press "+", for correct hour
>Press "SET" once,
>>press "+", for correct minute
>Press "SET" once,
Range 00-20; 09 = 2009
>Press "SET" once,
Month
>Press "SET" once,
Day
>Press "SET" once,
Day of the Week
>Press "SET" once,
12 or 24 hour
>Press "SET" once,
Fahrenheit or Celsius
>Press "SET" once again - DONE!!!
The clock should now display "month/day/day of the week/moon phase/Temperature"
NOTE: Moon phase and Seconds will correct on first reception from Coordinated Universal Time (UTC)
Lastly,
Press "+" once,
Temperature changes to seconds
>>Press "+" once,
Temperature returns on right-most panel and
seconds replaces day of the week.
>>Press "+" one last time and you are back to done!!!
Thanks,
peppermyers@yahoo.com
Posted on Apr 22, 2009
  • 31 Answers
SOURCE: I have an "SKYSCAN" atomic clock. seven days ago I replaced batteries. Has not reset as of yet.
http://skyscan.info/content/manuals/25-model-86709.html This is the direct link to the manual.
Posted on Nov 16, 2011
How to reset an atomic clock
Hello
Get into this site. You can select and see the user manual for your SkyScan atomeic clocks here. OK.
http://www.atomicclocksstore.com/manuals
Nov 14, 2011 | SkyScan 86709 Atomic Wall Clock
Hello
Get into this link. You can see the user manual for your Skysacn atomeic clock here. You can adjust your clock according to it manual. OK.
http://www.atomicclocksstore.com/skyscan-atomic-clock-manuals
Nov 11, 2011 | SkyScan 86709 Atomic Wall Clock
I am having trouble setting my skyscan atomic clock i took the battiers out and need to reset the whole clock.The modle number is 88900-8901
taking the batterys out and leaving them out for 60 seconds or more will in effect reset the clock. Put the new batteries in and wait for the skyscan to detect the outside temperature (if this unit has a outside sender). after this show on the screen push the button that corresponds to your time zone. You can now set the clock with the push buttons or take the clock to a wall that faceing? ( you don't say where you are located), the WMV signalyou need to set the clockto is coming from Colorado USA ( if your in the us) so make sure the back of the clock is facing toward colorado. let the clock sit overnight as the best signal will be recieved when its dark and especially in the very early morning, just before sunrise. this should automatically set the clock for you. good luck
Mar 14, 2011 | SkyScan 86709 Atomic Digital Wall Clock
My SioScan clock is two hours behind the actual time. Instructions lost. Can I reset it? How?
I searched on "sioscan" and all I could find was "skyscan".Is this your clock?
If it is, you can copy "skyscan.info/content/quick-ref.html" into your search engine, you will arrive at the skyscan web site instructions.
Mar 11, 2010 | Watches
Skyscan atomic wall clock 87315. Changed battery
Press and hold the set key until time zone appears, then + or - to your zone.
Jan 31, 2010 | SkyScan Audio Players & Recorders
Reset clock
Hi there.
I believe that your clock is automatic. It jumps to the signal from the atomic clock somewhere in your area, every hour.
Could be false signal from somewhere.
Iceman.
Nov 10, 2009 | SkyScan 86709 Atomic Wall Clock
After changing the batteries in my skyscan wall clock and transmitter, the time will not register, and the date is wrong. I've waited 24 hours for it to reset with sattelite, but nothing has happened.
Place the clock near a westerly window, if possible. It should only take a few minutes to reset. These clocks work using signals sent by terrestial radio waves, not satellites.
Nov 02, 2009 | SkyScan 86709 Atomic Wall Clock
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
Cannot properly reset skyscan atomic clock
thanking you.
Nov 19, 2008 | SkyScan 86709 Atomic Wall Clock
Just did this after problem resetting after changing batteries, press setover and again til it displays est, then press+until your time zone is displayed, it will also display dst, press +till on/or off depending on your location, then US will appear, clock will then set itself. Good luck, how frustrating.
Dec 17, 2007 | SkyScan 86742 Digital Atomic Wall Clock
Home Logo
42 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
