Question about Woods Hardware & Accessories
How do i set the timer on a woods spot light with built-in timer,it only works once
I tried to set it by pushing the button to the hours I wanted .there is a f on the panel when I start
  • Woods Master
  • 5,245 Answers
How do I program a Woods indoor light timer Model 50009 ?
my timer seems to have same buttons, but not same model. first you have to put in the correct day and time.
next you push the prog button it should be for time to start timer first, then it will ask what day or days to you want it to work they will be flashing at the top of the screen if it is like mine you can pock one day, Mom - Fri, Sat & Sun, or all week, when what you want is flashing press set, now the times should start to flash set hour first and if not sure if it has AM and PM use the 24 hour clock say you want it to come on at 5pm that is 1700 hours off at 11pm that is 2300 hours. after pick hour press set, the mins will blink, pick press set, then the sec, press set so now it should be the come on time. press prog again and it should be the time off now press set, pick days same as above set, hours set, min, set sec set. that should be what you need. I always try it on a lamp that I can set on the kitchen table and play till I know the right sequence. set for it to come on now everyday and stay on for 5 minutes if that works than just do the same thing all over again for the times you actually want, saves waiting to see if it is going to work.
Mine has about 4 different programs that can be set on same timer, I have never got that brave, but I would assume it is just the same procedure on prog 2, 3, or 4. good luck hope it helps
Oct 04, 2017 | Woods Hardware & Accessories
Need help programing lllwoods model 50000 indoor 24 hour mechanicl timer 2-c
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
http://waterheatertimer.org/Woods-timers-and-manuals.html#50006
If you have the digital timer, generally you can toggle DST back-and-forth 1 hour by pushing two buttons simultaneously for 3 seconds. And then reverse the setting again by pressing and holding both buttons again.
Open link. Download manual. Look for 'daylight savings time' in manual. Read instructions.
You can unplug timer to make programming changes, since the timer has a carryover feature against power outage.
To restore functionality of a timer that no longer works, press reset button and then reprogram.
The Woods 50000 series are new line of timer introduced just before Christmas 2012.
Woods timers are warranted by Coleman/ Carol Cable/ Canadian tire, and I suspect the timer itself is made by Intermatic.
All these timers have standard 1 year limited warranty against workmanship defects.
I have not seen any complaints about this line of timers here at fixya.
Add comment if you need more help.
Apr 18, 2013 | Woods 2C 24 Hour Indoor Mechanical Timer...
I need instructions on how to program my intermatic timer 1076311. It's a two button timer.
The Intermatic outdoor timer 1076311 is Intermatic model HB65R.
It has two buttons, TIME and MODE and a digital display.
Instructions:
1. Plug in the timer, which self-tests. If error, EE flashes.
If normal, 88 flashes for 3 seconds, then display shows C and you can proceed to set the timer.
2. Push the TIME button to set C (current time) AM hours 1-12 and PM hours 1. to 12. (Example: for 7 AM push the TIME button until the display shows "7" for 7 PM push the TIME button until the display shows "7."
3. Now push and hold down the MODE button until the display shows P for the "ON time."
4. Push the TIME button to set the hour to turn ON, from AM 1 to 12 or PM 1. to 12.(Example: if you want the power on at 7 PM repeatedly push the TIME button till the display reads 7.)
5. Push and hold down the MODE button until the display reads E for "END time" (time you want the power OFF)
6. Push the TIME button repeatedly to set the end time hour from AM 1 to 12 or PM 1. to 12. The time off will display.
7. Press the MODE button to toggle between ON and the current time.
If you unplug the timer you will have to reset the C (current time), P (ON time) and E (END or OFF time).
Dec 20, 2010 | Solar Intermatic Timer 6 Outlet Outdoor
How do I set my woods photoelectric timer? It has one button that when the number 0 appears and when pushed again a double line appears. For every time I push the button numbers 1-9 appear. Do you have...
I think this switch is set to go on at dark, then you can set how many hours after it goes on you want it go off. If you want the device to go on at dark and run for 2 hours, you stop at 2.
Gary
Dec 19, 2010 | Woods Outdoor Photoelectric 24 Hour...
How to program a digital timer
You posted under a photo that looks like Woods 49063 or GE 28441
Link below shows this particular timer with manuals for each:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
If your timer does not show on link above, add a comment with as much description as you have, with button locations and color and purpose of timer.
To program the GE timer:
1) Set current time
Press and hold Time button: and then push hour and MIN button to set current hour and current minute.
2) To program:
Press and hold PROG button for 1 second
Prog 1 ON will display
This is program1 ON
Press hour button and MIN button to set program1 ON hour and minute
Prog 1 OFF will display
This is program1 OFF
Press hour button and MIN to set program1 OFF hour and minute
Prog 2 ON will display
This is program1 ON
Press hour button and MIN to set program1 ON hour and minute
Repeat steps to program up to 6 different ON-OFF programs
When programming is finished, press TIME button to return to current time.
3) Set MODE
Press mode button once and ON displays, this means light is ON
Press mode button again and OFF displays, this means light is OFF
Press mode button once and nothing displays, this means timer programs will run as you set them
Dec 12, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
How to program #49556 te158wta my add: gd659@cgocable.ca
Woods 49556 / TD1300 manual
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
How to program timer.
Plug timer in until rechargeable battery is charged and display shows.
Unplug timer to program
Set current time.
Hold in reset button for two seconds to clear memory
Press and hold TIME button to select 24 hours so there is no problem. Release Time button.
Press and hold SET button.
MO is flashing, and represents MOnday. TU for TUesday. WE TH FI SA SU
Continue holding down SET button, and press ? ? until current day displays.
Release SET button.
Press and hold SET button again, and Hours will flash
Continue holding down SET button, and press ? ? until current hour displays.
Release SET button.
Press and hold SET button again, and Minutes will flash
Continue holding down SET button, and press ? ? until current minute displays.
Release SET button.
Press SET button again and current time and day will display.
Programing overview:
Set up to 20 on-off programs.
You can select individual days, or groups of days, or all days of the week
For example MO-SU is all days of the week
For each ON time, you also must set OFF time.
So program1 ON is set, then program1 OFF is set
Each ON is set for day, hour and minute
Each OFF is set for day, hour and minute (select same days for OFF and that you chose for ON)
For example if you want timer to turn ON all days MO-SU, make sure OFF time is also set for all days MO-SU.
Program the timer:
Set ON
Press arrow? until display shows PROG 1 ON
This is program1 ON.
Press SET button, but do not press and hold set button as you did when setting current time.
The days for program1 ON will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 ON.
Press SET button again, and program1 ON hour will start flashing
Press ? ? to select hour that you want for program1 ON.
Press SET button again, and program1 ON minute will start flashing
Press ? ? to select minute that you want for program1 ON.
program1 ON is set, next you must set program1 OFF
OFF
Press arrow? until display shows PROG 1 OFF
This is program1 OFF.
The days for program1 OFF will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 OFF.
Press SET button again, and program1 OFF hour will start flashing
Press ? ? to select hour that you want for program1 OFF.
Press SET button again, and program1 OFF minute will start flashing
Press ? ? to select minute that you want for program1 OFF.
program1 ON and OFF are set, next you will set program2 ON by repeating steps above.
If you do not want to set more programs, that is fine.
Timer lets you set up to 20 programs.
Finish programming: when program ON-OFFs are set, press TIME button and current time displays.
Last step:
Push manual override button until AUTO is displayed. This will let timer turn lights on and off.
Plug lamp into timer.
Lamp must be turned ON.
Plug timer into wall.
Dec 04, 2010 | Woods Hardware & Accessories
How do I set the Woods N1506 timer?
N1505 timer manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 01, 2010 | Woods Outdoor Lighting Timer
I have a Woods TM1710 outdoor timer and the instructions are not very clear. First, what is the manual overide switch. Second, what are all the on/off positions on the dial for. Third, which part of the...
Woods timers and manuals
Woods TM1710 shows at page bottom, and does not have online manual that I can find
TH1710 is a promotional timer for outdoor use.
TD series and TM series timers are evidently sold at a price point, and not made with same features as more expensive timers.
That being said, TM1710 has a dial that rotates as time passes.
Poor image quality is hard to make out, but dial looks like 12 hour.
If this is true, then time programs repeat each 12 hours.
Set timer and the lights turn on-off during am hours, and then cycle repeats for pm hours.
Kinda silly to make 12-hour outdoor repeat timer since you want outdoor lights ON during pm but not am. But cheap prices sway we shoppers who later discover a saw horse that is supposed to balance on 2 legs.
To set ON-OFF times, there are segments located around outer edge of dial.
Pull segments up or leave them pushed down to set ON-OFF.
Most timers are OFF during hours when segments are pulled up, and ON when segments down, but this timer may be opposite.
Manual override is button or switch that overrides timer functions and turns light ON full time.
Again poor image quality makes it impossible to see manual override, but it looks like manual override is white button to lower right of dial.
If that button is manual override, then it appears to rotate.
Usually you set override one direction to override, and other direction for timer to operate
Nov 27, 2010 | Woods Hardware & Accessories
Clock is set properly. I want to turn on outdoor lights at 5PM everyday. In addition I want to turn off the lights each night at 11PM. Problem - When I go thru the process of turning on the lights it...
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
2) Programming review:
Each program requires ON time to be set, and then OFF time to be set
For example you set Program1 ON 5:00PM for ALL days.
And then you set Program1 OFF 11PM for ALL days.
3) Programming steps:
Press PROG button until Timer 1 ON appears on display
Use Hour button to set 5 PM
Use MIN button to set :00
Default selects ALL days
(If you want other days, press DAY button until display shows correct block of days)
Press PROG button again to save Program1 ON
4) Now for Program1 OFF
5) To set Program1 Off
Press PROG button until Timer 1 OFF shows in display.
Use Hour button to set 11 PM
Press PROG button again to save Program1 OFF
6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time.
If you want to set another program, press PROG button until Timer 2 ON displays
7) After setting programs, press Clock button so current time shows.
8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Nov 10, 2010 | Woods InWall 7 Day Digital Programmable...
Hello, I have model 49556/te158wt and I'm not able to set hour ! could you help me ?
Link above is the Woods 49555 manual
If the timer will not program, then it has gone bad.
Plug timer into wall receptacle
Back-up battery will charge in about 1-2 hours > if battery will not charge, then timer is no good
Some digital timers require back-up battery to be fully charged before display will show
Back up battery allows programming while timer is removed from receptacle
After timer is programmed, plug timer back into receptacle
Timer buttons show below
To set current time:
Depress RST (Reset) button to clear programs
Press-and-hold TIME button to select 12 hour or 24 hour display
Press-and-hold SET button. Mo Monday will flash in display
Push arrow button until current day shows
Press SET button again. Hours will flash
Press arrow buttons until current hour shows (am or pm)
Push SET button again. Minutes will flash.
Press arrow buttons until current minutes show
Programming ON-OFF
Make a schedule so programs don't conflict
You can set up to 20 on-off programs over 7 days
Each program has ON time Day Hours and Minutes
Each program has OFF time Days Hours and Minutes
Press right-arrow > PROG 1 ON flashes
Press SET > choice of day groupings flash
Press arrow button to select days
Press SET > program1 ON times flash
Press arrows to set ON time
Press SET > program1 for Hour
Repeat sequence described above to set MIN
Repeat sequence to set OFF times for program1
Repeat sequence to set Program2 thru Program20
Press TIME button to finish programming
Oct 12, 2010 | Woods 7 Day Digital Heavy Duty Timer...
Hardware & Accessories Logo
51 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
