Question about Hobart Food Mixers
I cannot remove the paddle from my Hobart stand mixer. I was making a very large batch of cookies and when I finished the paddle would not come off. I put the paddle on just before starting the cooki
I have tried warm soapy water, vinegar, rubbing alcohol, castor oil, and hitting it with a rubber mallet. Any other ideas?
  • Hobart Master
  • 1,267 Answers
Get some CRC into the top between shaft and paddle socket and in and around that driving lug on the side. Then grasp the paddle with a hand on either side and rock (turn) it back and forth as forcefully as you can until it starts to come free. Eventually it will start to move and you will be able to remove it. Polish the shaft and scrape out the hole, it is flour that has wafted in there that has tightened it up, it packs & embeds itself into the aluminium paddle.
Posted on Dec 14, 2014
Hobart Mixer D300, When mixing mashed potatoes paddle will only turn in low gear. When product is mashed with milk added it sometimes will turn in 2nd gear, but never in top. When this happens, motor is...
Sounds like the keys in the shifting sleeve may be sheared. The transmission will have to be disassembled and checked for broken parts. Check www.hobartservice.com for your local Hobart office.
Jul 07, 2011 | Hobart D300 Stand Mixer
Hobart A-200 mixer gets hot and weak. Motor housing gets too hot to keep your hand on it. Service tech told me the motors usually don't go out. What other problem could it be?
I'd say you're most likely overloading the mixer. This mixer, and others similar in size, are frequently overloaded by people making pizza dough. If you are making dough, keep in mind the A-200's capacity is 9 lb. of 40% A.R. pizza dough, mixed for 5 minutes maximum. If you need to mix longer, the batch must be cut down even smaller, but I don't even know if you're mixing dough.
Try running the mixer unloaded (i.e. nothing in the bowl) for ten minutes or more and see if it gets hot. If it still gets hot, the motor's start circuit (varies depending upon age of the A-200; Hobart used numerous motors in the A-200 over the years, incorporating different starting circuits) most likely has problems. If it doesn't get hot when operating unloaded, then you're probably overheating the mixer by overloading it.
Dec 20, 2010 | Hobart A200 Stand Mixer
How to adjust bowl height on 20 qu hobart mixer.It is an old A200 1/3 hp Paddle is to high in bowl and will not mix dough on bottom and sides of bowl
you need to remove splash shield, tilt mixer back,with a long screwdriver adj. the set screwclockwise to decrease clearance for beater to bowl clearance,always use b beater when making adj. clearance should be .054" to .115".also make sure there are no deformities in btm of bowl which can cause you problems.dont forget to vote
Dec 12, 2009 | Hobart A200 Stand Mixer
Hobart A-200 3943. Having a problem with torque.
Check your recipe against the capacity chart found here: http://www.primasupply.com/images/hobarta200.pdf
You may be overloading the unit. Hope this helps.
Oct 13, 2009 | Hobart A200 Stand Mixer
Keep getting error code 23 when trying to start mixer
i will try to help, always include ml# with problem description on any hobart pc. of equip. which is located on the info. plate. there are 2 v.f.d.for this mixer ,sr drive being 1st generation, and gen. elec drive 2nd generation, on the sr drive err23 indicates a motor stall condition there are 6 most likely causes for this err. 1st, batch size too large,ck. capacity chart. 2nd,encoder malfunction. 3rd,motor malfunction. 4th,drive malfuction. 5th,1 con coil malfunction. 6th,2 cr malfunction. if this does not help, repost problem and i will ck. to see if i can be of anymore help, please dont forget to vote for me thanks, monomoy
Oct 05, 2009 | Hobart HL600 Legacy Stand Mixer
Which kenwood mixer to buy?
Hi. Congratulations for researching mixers. I wish I had before I bought my Kitchenaid HD Pro. All mixer manufacturers over-rate their products. Goto www.consumeraffairs.com and do a search for each mixer you are considering. Most mixer failures are caused by mixing heavy cookie or bread doughs. Although manufacturers claim that their mixers can easily handle these doughs...They cannot! My Kitchenaid self-destructed after 30 batches of bread dough. "For the way it's made"! Indeed! I solved my problem by buying a Hobart N50 mixer. It's a 5qt. and handles anything I throw into the bowl. I bought mine used, and refurbished it myself. New these units cost $2,035.00 USD.
If this solution has assisted you, please rate it. Good luck! ricardok45.
Mar 15, 2009 | Kenwood KM800 Major Classic Stand Mixer
Dry clumps in pizza dough
Hi. You should consider a few things. They type of hook you use, can greatly affect your end result. If you're making a yeasted dough with a high protein percentage 12-13%, you should be using an "ED" hook, this is a spiral hook that has a sharp turn at the tip. You can find them on eBay for a competitive price. I believe that Hobart also sells them, but for a higher price. They are very good for mixing pizza type doughs, they also do an excellent job kneading the dough.
Have you checked the flour for lumps before it goes into the mixer? Have you tried sifting the flour?
Are you adding all the liquid and flour at once? If so try adding flour in stages to all the liquid. If you find that this solution helps you, please rate it. Good luck! ricardok45
Feb 19, 2009 | Hobart D340-6007 Mixer
Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Nov 09, 2008 | Hobart A200 Stand Mixer
Motor Dead
I had the same problem the first time I tried to make a small batch of bagel dough (very small!) I had to send it back for repair and wait.....sorry that the news is not better.
Apr 01, 2008 | Viking VSM700 Stand Mixer
Food Mixers Logo
74 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
