I have a new Air-Con A13EM4H4G09 that works great in AC. When I switch to heat the fan doesn't work and there is no heat I can tell. The compressor fan turns. Any ideas?
I had a repair technician come out and said he could fix it for $600 but wouldn't tell me what was wrong. He said the compressor was good.
  • 101 Answers
DON'T EVER USE THAT COMPANY, HOW CAN HE GIVE YOU A REPAIR ESTIMATE IF HE DOESN'T KNOW WHAT IT IS. IF IT'S NEW YOU SHOULD CONTACT THE PLACE YOU BOUGHT IT FROM.
Posted on Dec 11, 2014
Hello, my 2003 mitsubishi airtrek, it's same as outlander, has a aircondition problem. when i drive slowly or i am in trafic, ac compressor off and cold air stopps, but tumbler in salon is on. if i drive...
It could actually just be a blower fan. Moving at higher speed the air can be pushed through the fans even if it is not working.. could also be he blend door. that directs the air when you select air con instead of heat. Make sure BOTH radiator fans (if you have 2) are running when the air conditioner is on.
Aug 08, 2014 | Heating & Cooling
Air-con faulty
sounds like an electrical problem check all fuses and ac clutch relay
Jul 20, 2013 | 2005 Mercedes-Benz Sprinter 311CDI
04 Saturn vue compressor turns off when fan is set to 3 or 4
The problem is the blower motor speed control resistor, it is located near the blower motor in the housing. I exchanged mine and it works like a charm now.
May 31, 2012 | 2002 Saturn VUE
Hi, The air con in my 2003 Audi A6 1.9 tdi 130 is blowing warm air the air con rad is fully gassed and all fuses are ok . Thanks in advance for any advice on how to fix
The only other thing then would be if the compressor is turning, engaging, and the cooling fan working properly. You should either be able to see the compressor clutch engage, as the switch is energized, or at least hear it click loudly when the switch is energized. If it is not, then there are sensors for the low pressure/high pressure line to tell the compressor when to function, that also have to be checked.
As the engine runs with the compressor turning, one line should be hot/warm, the othe,r (larger diameter hose) should be cool/cold, if the system is working properly.
If the compressor is turning when you have the A/C turned on, then see if the cooling fan is running as well. It must run to remove the heat and cause the process to function properly.
Mar 27, 2012 | 2003 Audi A6
Jump air compressor ac works replace relays same issue HONDA
the compressor may be low on freopn but, the fan problem is most likely the fan motor as it is the low temp fan and will run more often than both fans...to test see if you can switch the fan plugin to the other fan watch carefully that it does not get too hot as the second fan is a safety fan that works as high temp or when using the A\C
Jul 13, 2010 | 1997 Honda Accord
Air con pump not engauging
Hi:
You should verify that your AC system still has a full charge of refridgerant, and if it does,
The problem is most likely the AC clutch assembly on the front of the compressor.
Since the dash light works, and the fan turns on, there is power to the system, but the compressor won't turn on if the pressure switch says the charge is low, and if you turn the switch, and someone can hear a click of the compressor clutch solenoid, but no air, the clutch assembly is probably the culprit
Nov 06, 2009 | 2000 Honda Civic
Air con compressor not working i need to know
Do not play with this vehicle,if AC not working then take to a dealer or someone who understands jags ,these systems use a lot of complicated sensors and pressure detectors ,and they always leak gas and need rechecking once a year .The pipes go porous,the O ring seals play up and often the thing will just dump the gas out of the compressor for no obvious reason ,except to us that repair them ,its caused by the fan not coming on when the AC is turned on and it builds up too much pressure and ,this is caused when one of the these pressure sensors switches play up
Oct 21, 2009 | 1994 Jaguar XJ6
'96 cadillac deville has no air.cond./heat
Unfortunately for you ( i had the same problem) The A/C compressor HAS to be in working order on these cars or else all heck breaks out with the climate control.
If it's a nice car, get a new compressor installed. If it's borderline- get rid of the car.
I paid 2200 to Cadillac to fix the A/C and climate control only to have the transmission fail in my '93.
I dumped the car soon thereafter....
May 27, 2009 | 1996 Cadillac DeVille
Compressor will not come on. Fan runs great.
I fixed it. I had a dirty connection on the starter relay for the compressor. Thanks again for the help.
May 17, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
