Question about Home
How to fix Remington LM-8 switch assembly
How to fix the switch
I need a replacement on off switch for the Remington BV12200A Electric Blower.
ELECTRIC BLOWER/VAC - Sears
c.sears.com/assets/own/07178001e.pdf
MODELS: BV12200A, BV12200AT. ELECTRIC BLOWER/ ... Replacement Parts. 13. 8. Warranty ... Thank you for purchasing this Remington brand Electric Blower/Vac. We are proud ..... Blower/Vac. The on/off toggle switch has three settings;.
images for replacement on off switch
Nov 04, 2015 | Remington Garden
Trigger assembly is smoking, intermittent starting ? Remington electric chain saw
The switch has either a poor connection to it, or the switch is toast. Good luck on finding a replacement part.
Nov 12, 2010 | Remington Electric Chain Saw
Remington 16 inch chainsaw model 107624.01 . A friend burned out the motor can this be fixed. The saw was like new. Thanks Lou
anything can be fixed,but if your friend burned the motor,and if he is a up and up guy he should replace it.they do not cost that much
Sep 12, 2010 | Remington 16" Electric Chain Saw Assembled...
The switch of the saw is not working 00
You need an AC voltmeter to trace the problem with the switch. It can also be a bad motor brush/spring--these saws are great for killing motor brushes, and there are virtually no replacements available as Remington has ceased saw operations. If it is a bad brush, visit an electrical tool shop to see if they have something that will work from a different brand of tool. Good luck!
Jun 28, 2010 | Remington 16" Electric Chain Saw
The front handle brook, where can I get a replacement one.
Just FYI, owner's manual is here. I didn't see a part number for the front handle. 121364-01 is the part number for the main handle assembly, but I'm not sure that's waht you need.
The distributors for Remington chainsaw parts are Master Distributors. Their website is here, but I suggest you call them at 888-917-2244.
If this answer helped, please vote. Thanks.
Jun 11, 2010 | Remington 8-Inch 18 Volt Cordless Chain...
Need chain oil resevoir for Remington electric
I suspect you did an on line search, we can do no better. Remington has ceased production. Parts availability is limited to what is on hand. It might be advisable to save the money you would expend for parts and put it toward the purchase of a new electric saw.
Poulan has been in business a very long time and offers 8 different models. Some can be found at Lowes. HTH
Lou
Sooner or later you will encounter a part that isn't available for your Remington. Yours may be worth more as parts than as a complete assembly. eBay?
Oct 11, 2009 | Remington Electric Chain Saw
I had to reconnect wires inside my Remington Limb n' Trim 8. It's all back together but I can't seem to get the bar and chain aligned to work smoothly. Is there a diagram showing the parts as they should...
There are a few Remington parts lists here:
http://www.desaparts.com/remington-chainsaw.html
The detail isn't great and pole saws show chainsaw parts lists. If you can't find your model I'd suggest you contact them. There is a home button at the bottom of the page with a 1-800 number. HTH
Lou
If you call them please point out the polesaw glitch.
Oct 04, 2009 | Remington Electric Chain Saw
Need a trigger switch
The part you need is a 077525S. Call Master Parts they have that part available. You can reach them toll free at 800-446-1446 or online at www.masterparts.net. I hope this helps!
Jul 12, 2009 | Remington Electric Pole Saw
After two weeks use of my new Remington R5130, now one of the three heads keeps popping off during almost during every shave. Any suggestions?
My R5130 kept falling apart when I shaved. I really like Remington Shavers (Spectrum Brands) and have had good luck with them until the R5130 model.
Two points.
1.) -THEY SHIPPED ME A NEW HEAD ASSEMBLY (BUT)- The original one I got had poorly formed plastics tabs on the blade retainer (head) I Googled Remington Shavers and used their Consumer Service tab to request a fix. They sent me a new head assembly free of charge and yes it worked much better. However, it eventually the heads started falling off again.
2.) RUBBER BAND FIXED IT - I looked it over again and thought that the range of movement and forces on the assembly pieces was just more than the design could handle so I looked for a way to contain some of the movement. I slipped a single thin (1/16"x1/8") - 2" diameter rubber band around the three head assembly and the problem has been completely eliminated. I can shave normally now. The rubber band nearly disappears under the black head flanges so it doesn't even look bad. The shave is a little firmer now but it still has most of the flexibility of the original design.
This simple fix will be a hard one for Remington (Spectrum Brands) to adopt but you might help spread the word. I am sure they will avoid this problem in the next models.
Jul 08, 2009 | Remington R510 Electric Shaver
Home Logo
480 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
