Question about Mitsubishi WS-48413 48" Rear Projection HDTV-Ready Television
My ws-48413 mitsubishi will not connect to the cable box when i turn it on unless i unplug hdmi and plug in again.
Changed out cable boxes. called tv provider and they thought it was my tv. i had just moved tv to new location
    Habit-Forming:
  • 103 Answers
May be the whole unit needs to be reprogrammed read your manual or obtain one on the internet
Posted on Dec 10, 2014
My tv model magnavox26mf231d/37 shows hdmi is disabled and the hdcp authorization failure.
This could be a problem with the cable box or other set top box and not the TV. It's known to happen with Samsung cable boxes from Cablevision.
First try resetting the TV and set top box by unplugging both. Remove the HDMI cable from the TV and the set top box. Reconnect the HDMI cable. If you are using a Redmere or similar HDMI cable, make sure that the end labeled TV is connected to the TV's HDMI port. (These cables have additional electronics and are not reversible.) Connect the power cord to the set top box and wait 30 seconds to a minute. Then plug in the TV. To ensure the set top box does the correct handshake with the TV, turn on the TV first and set it to the HDMI input. Then turn on the set top box. See if this fixes the issue. (On some cable boxes, this can be a temporary fix. You may need to have the set top box replaced.)
If the above steps don't help, try a different HDMI cable. If that doesn't solve the problem, then the set top box is faulty.
I hope this helps.
Jan 10, 2015 | Televison & Video
I'm back.my mitsubishi ws-48413 tv only has a blue screen when i turn it on. Ive tried several things. I tried turning on the receiver first and waiting 10 seconds and the opposite. I rebooted the tv...
There is a communication error between the source & the TV. When powering up the units, try turning on the receiver first, then turn the TV on, that way there is a signal for the TV to detect at initial start-up.
Dec 12, 2014 | Mitsubishi Televison & Video
I own a WS-48413 Mitsubishi 48" projection TV that has been working great for 7 years. Now all of a sudden there is no sound, only a picture. Tried to trouble shoot with the manual, but no luck. Is...
amlupo,
If the picture is good and you use Comcast as your cable supplier I believe that your Comcast converter box is bad. This is a very common problem and an easy one to fix. Call Comcast and tell them the problem and they should replace the box for free.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 05, 2011 | Mitsubishi WS-48413 48" Rear Projection...
My sound is muffled, since we put an hdmi cable on to fix the terrible picture, now we have a sound problem
This tv isn't known for sound problems. First thing to do is to go to the cable box and push the volume up button on the box if there is one. Next thing to do is to try another device that has a hdmi output like a dvd or game system in place of the cable box. My guess is that this muffled sound is somehow caused by the cable converter box. You can try to reboot the box by unplugging the power for 30 seconds, then plugging it back in. If all else fails, you can call the cable or satellite service and have them change the converter box. Good luck, Russmann.
Mar 24, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have a Mitsubishi projection model WS-48413 that
do you get a click if not check the fuse inside next to the ac cord inside the unit
if you do have a click then your convergance amps let go you will need a tech to replace them qbout 150 dollar job
Nov 19, 2009 | Mitsubishi WS-48413 48" Rear Projection...
Caption
sometimes if you have a cable or satellite box as source.(if your case )then you would have to turn it off in the cable or satellite box.
Jul 10, 2008 | Mitsubishi WS-48413 48" Rear Projection...
HD Picture is Scrambled, but Has Sound
I had the same problem
you have to set up the componant on DTV.
the signal my be hd 1080i and the only connection with componant that can support this is the DTV port.
the other componant connections only support 480,
good luck
Apr 06, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Sony HDZ235 HDMI
use component outputs of that unit to play on tv.Or use component or video output of sony unit and connect to cable box if available and use the source switching on cable box to change sources that way you wont have to unplu HDMI cable..By the way HDMI has a new challenger in the near future called ' DISPLAY PORT' ..
Dec 03, 2007 | Sony HOME THEATER SYSTEM System
Open Questions:
Mitsubishi WS-48413 48" Rear Projection HDTV-Ready Television Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
