Lg front load 3 yrs old stopped mid cycle Door was locked I finally got it opened. Suds everywhere. Now won't lite up or turn on. Checked plugs gfi breaker. Reset doing the above still not doing anything
    Habit-Forming:
  • 104 Answers
I would advise getting a washing machine mechanic from lg or check your filter at the front of the machine other wise the door mechism is damaged
Posted on Dec 10, 2014
  • 1294 Answers
SOURCE: Door lock
Check for loose wires in the door lock; or replace door lock.
Posted on Dec 04, 2007
  • 1294 Answers
SOURCE: control locked
Hold the 'options' and 'select' buttons down at the same time for several seconds, the thing will unlock.
And rate me pl..................
Posted on Jun 14, 2008
SOURCE: Stopped mid-cycle
I have the same problem.  Model: LAT2300AAE Serial: 30220055ZM
Maytag Performa - does anyone have any advise or should I just call the Maytag man?
Posted on Jun 22, 2008
  • 41 Answers
SOURCE: My Whirlpool Duet Front Load Washer stopped mid
I just repaired a Duet Sport WFW8300SW00 today that was flashing the "add a garment" LED. It was the Motor Control Board on the bottom, with a cold solder on rectifier GR1. Just resoldered it and voila!
Posted on Jan 13, 2010
mkh5094
  • 145 Answers
SOURCE: LG Washer trips dedicated breaker
That to me seems like an electrical problem. Every now and again you can get a bad GFCI receptacle that will constantly keep tripping. I would also see that the GFCI is properly sized for the circuit. It needs to be a 20 AMP circuit (just dedicated to the washer) and a 20AMP GFCI receptacle. The way to tell is the 1 of the three prongs of the 20AMP GFCI will be in the shape of a "T" while a 15 AMP will have 2 straight prongs and the ground prong. Hope this ws helpful, don't go spilling any money into your washer without getting that fixed first, because it doesn't seem like a washer problem.
Posted on Apr 30, 2010
How do I open the door to my front loading maytag neptune? It was in mid cycle, made a horrible sound and stopped running. Has all my clothes in it and I can't open the door.
Please check this link for tips to open the door that is jammed.
Make sure to drain the water by opening the drain valve manually.
Click on : Door lock
Feb 07, 2013 | Washing Machines
The water starts to come through then just stops and then alarms go off
see this causes and fix it. God bless you
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Oct 05, 2012 | LG WFT1071TP Top Load Washer
WATER IN WONT DRAIN OUT
The water inlet Solenoid is open. Check the Solenoid. Give gentle tap it may re seat again. Finally replace if it is not settling!
Apr 05, 2010 | LG WM-1832C Front Load Washer
LG Washer front loader stopped mid wash and is lock can't open door
unplug/plug unit. drain water via hose behind lower left panel on front.
Jun 03, 2009 | LG WM-0532HW Front Load Washer
Duet Sport stopped in mid cycle
Read the Manuel and see if they offer an over ride, first.
Since you already tried rebooting the machine, I won't suggest that!
If no go you will need service at this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jun 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door lock
Dec 02, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Mar 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
