Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Does this TV have a red LED illuminated when in standby? It would be in same location as green LED power on.
I am trying to establish if there is a standby power issue. I have replaced numerous parts and I am starting at the beginning in the troubleshooting manual. My original problem was the three LED green on.
    Sergeant:
  • 269 Answers
FX transmitter
Posted on Dec 10, 2014
  • 273 Answers
Yes it has a red led in standby upon beginning of power up it turns green once all conditions are met in the initialization it un mutes the video and you see a picture .
what problems are you fighting ?
Posted on Dec 11, 2014
Does a RCA D52W20 have a red LED illuminated when the TV is not powered on? This would be the same location as the green LED power on.
Yes it has a stand by light and it is red . once the power on is started it checks the rest of the command lines from micro and starts the initialization process once all are satisfied it un mutes the picture
. however it appears your fighting a one problem and possibly compounding the problems now .
Dec 10, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
50px1d-uc When I try to turn it on, the red power light blinks, I hear a click, then the light turns amber then back to red. Usually I'd hear the click then it would turn green and the tv would work...
I came across this in a manual
-Without CableCARDTM : Illuminates red in
standby mode, Illuminates green when the
TV is turned on.
-Inserting the CableCARDTM : Illuminates
orange in standby mode, Illuminates green
when the TV is turned on....
You might want to check your cable card. It seems to mimic your problem. Try taking the card out and gently clean, with a dry cloth, the contacts/strip. Then take some "canned air" and blow out the card socket from the side to dislodge any accumulated debris.
Oct 13, 2011 | LG 50PX1D 50 in. Plasma Television
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
My tv will not turn on
most plasma tv have two power botton, ha main power which is mostly located at the lower side of the tv, and the sub power/standby power botton located in the top of the tv.. check if there is red, orange and green light on power led indecator. other wise there is problem with you power supply.... you may call qualified technician.
May 27, 2011 | Sony BRAVIA KDL-40V3000 Television
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
Nov 03, 2009 | Samsung HL-S5679W 56" HDTV
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
