Question about Samsung Office Equipment & Supplies
How do I turn offline mode off on my Samsung M2070 Class printer? I tried going to control panel and right clicking to turn on online mode? My printer says its on wifi mode but computer says the printer is on offline mode??
  • Samsung Master
  • 3,368 Answers
It sounds like your WiFi is not talking to the printer.
Posted on Dec 10, 2014
agnelkj
  • 210 Answers
SOURCE: hp deskjet f340 series keep showing offline
hi,
follow the steps:
>unplug the usb cable from the back of the printer
> go to the printers folder inside the control panel
> right click on the printer icon and then click on delete.
> if the printer icon is deleted and if there are no more printer icons related to your printer, plug the usb cable back to the printer and wait for few minutes while it automatically installs the driver.
NB: if you are unable to delete the printer icon. then right click and click on "pause printing" and then again right click and clear the documents in queue. if it is done then delete it.
if you are unable to clean the documents in queue, then
click on Start-->Run, type "services.msc" and click ok.
Double click on print spoolers and then click on "Stop" and then click on "Start". Restart the computer. then try to delete the printer icon.
Thanks and regards,
Agnel
Posted on Mar 14, 2008
  • 3 Answers
SOURCE: Printer is offline.
hi iam kishan from india do one thing if u have a driver cd of your priner disconnect printer and go to control panel clik on add/remove program remove all driver oand sofftware of your printer and restart ypur pc and after restarting insert cd in install software of your printer do no connect printer untill computer want or connect after finnish i
Posted on Jan 20, 2007
  • 359 Answers
SOURCE: my all in one lexmark
Please provide the model for your printer and related items.
Posted on Sep 08, 2008
  • 32 Answers
SOURCE: After a power outage, my Brother printer,
First off, make sure that you have turned both the printer and the computer off and then turn them on(cycle the power). When you go to the printer in 'printers' be sure that the printer is not light in color, if it is, then it's failed to come back online or it's broken. When you say, 'I have tried going into the control panel and clicking on print offline', I take you to mean 'print online', because you don't want to print offline, you want it online...
The easiest way to solve this is to move the usb plug going into the computer from the printer from one port to another, this will force the computer to re recognize the printer. I see that this printer has network capability. I am assuming, that the printer is connected via USB and not Ethernet. [USB, rectangle the size of your pinky, but narrow, Ethernet looks like a big phone plug]. If you move the plug from one USB slot to another and you don't hear the hardware connect sound(low tone then high tone), then your printer may be broken. It is possible if it is broken that the Ethernet port still works, but using that is beyond this discussion.
Good luck,
Brett
Posted on Mar 12, 2009
mrajesh17
  • 475 Answers
SOURCE: My HP Photosmart C309a series will not print
Instructions
  1. 1
    Check the cables to and from the printer to the computer and make sure that all of the connections are secure. A disconnected cable is often the cause of rendering the printer offline.
  2. 2 Turn the printer off and back on. Sometimes it could be just a glitch in the network. Reset the printer by turning it off and then wait 60 seconds and turn it back on again.
  3. 3 Check the toner or ink cartridge. Most HP printers have the capacity for both color and black ink or toner cartridges. They will normally run on just one of the two; however, when the one installed becomes too low or is installed incorrectly, it will go offline.
  4. 4 Check for torn paper, paper clips, sticky label residue and other items that could be the cause of printer jams. Any of these will stop a printer in its tracks.
  5. 5 Set the printer as your default printer and see if this resets it to online status. From the Start menu, select "Control Panel". Select "Printers and other Hardware". Under "Pick a Task", select "View Installed Printers or Fax Printers". Select the questionable printer that is offline. Select "Printer" from the pull-down menu. Click on "Set Printer as Default".
Posted on Dec 20, 2010
Keeps telling me the printer is offline
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
Update drivers: recommended links
http://windows.microsoft.com/en-US/windows-vista/Update-drivers-recommended-links
Source: Samsung SCX 5635FN Manual
Mar 02, 2014 | Samsung SCX-5635FN All-In-One Laser...
My hp 900 inkjet is offline and doesn't want to feed paper.
The solution for an offline error of a printer is to check the proper connection of the printer.
Two options exist to turn off the offline mode.
If you choose the first option to change the offline state of the printer,
then go to Control Panel and then 'Printer and Faxes' option on the Control Panel.
Double-click on the printer you want to change to online mode from the displayed window.
A pop-up window will open and you need to select 'Uncheck Printer Offline' option from the menu bar.
try this:
http://printers.iyogi.com/hp/hp-printer-offline-error.html
Hope this helps you.
Jun 23, 2011 | HP PSC 1610 All-In-One InkJet Printer
Hp deskje d2360 printer showing offline error
Mar 08, 2011 | HP Deskjet D2360 InkJet Printer
How do i get my samsung ml-2510 printer back online? it is offline for some reason - was working in the past. tx!
Follow the step:
  • Access "Control Panel"
  • Access "Printers and Faxes"
  • Right Click your Printer
  • Select "Use Printer Online"
Mar 01, 2011 | Samsung ML-2510 Laser Printer
When I click on file and then click on print the screen that comes up showing the name of my printer (hp6940 desk jet ) small wording comes up saying error=offline and my printer will not print the message...
-Try to turn off and turn on your printer
-check your connection
win xp
-go to start/setting/control panel/printers and faxes
-right click "hp deskjet 6940" and click on "use printer online"
win 7
-go to windows logo/control panel/devices and printer/right click on the printer driver, click on "see whats printering" click printer and uncheck use printer offline
Sep 04, 2010 | HP Deskjet 6940 InkJet Printer
I have used my printer wirelessly before and not had a problem, now it says my printer is "offline" - how can I get it "online"?
Follow the steps:
1. Make sure that the printer is turned on.
2. Go to Control Panel and click on Printers and Faxes (for XP) or Printers (for Vista).
3. Right-click the printer icon > click "Use printer online".
NOTE: Once you see the option "Use printer online" after right-clicking the printer icon, meaning that the printer is offline. But if you right-click the icon and you see "Use printer offline", meaning that the printer is online.
Nov 03, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Dell printer 1710 n .
In Control Panel - Printers, Right-click the Dell 1710N and remove check for Offline.
Jun 12, 2009 | Dell 1710n Laser Printer
HP deskjet D2300 series printer is showing offline .Power is already given to the printer.
check that the printer is turn on, if on turn it off and on again, secondly check by double clicking the printer icon on your pc start bar i,t will open a pop/dialogue box, click on file and see if the offline is tick if so disable the tick.
May 26, 2009 | HP DeskJet F380 All-In-One Printer
HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer offline
Go to control panel and printers and faxes on your laptop and when you see the printer icon for the printer, right click on it and left click on use printer ONLINE. make sure then that the laptop is communicating with the printer.
Apr 13, 2008 | Brother HL-2070N Laser Printer
1,468 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
