Question about Vacuums
How do I change the vacuum cleaner belt on a eureka bagless old v.c.don't have model not sure where it is. Called the Boss around 10???yrs old PLEASE help
  • 3,828 Answers
I know you have to remove the brush and roller to slip the new belt on on any of these type vacuums ..
usually they slide in place and have a bearing or bush each end
there should be a plate with screws underneath the vacuum
then remember which way the belt is twisted for them to work in the right direction ...take pictures as you go for a reference
Posted on Dec 10, 2014
SOURCE: looking for Eureka belt 70646A for a Eureka The Boss upright
I just replaced the belt on my Eureka The Boss Smart Vac (Model 4870D). I purchased a namebrand Eureka R belt from a local vendor. I did my best to follow the instructions printed on the bottom of the machine. I turned on the vacuum cleaner and the belt brush was spinning! I dropped it into vacuuming floor mode and the belt wouldn't spin no matter what level I put it on.
I called the manufacturer (1-800-282-2886) and spoke with a very nice woman on the phone. While I was speaking with her I noticed that a silver screw was lodged within the "brush roll control" yellow selector switch. With some shaking it became dislodged and I was able to put the "brush roll control" into the hard floors setting and turn the "carpet height adjustment" all the way to the right, so that it was facing the word "low." I then followed the instructions for replacing the belt again.. (1) remove base plate (2) remove brush roll (3) place new belt around motor shaft and then around brush roll (4) insert left side of brush roll before right side (5) rotate brush roll to be sure belt is centered (6) replace base plate, making sure to insert under 4 little tabs before securing with screws.
It appears that it is very important that the carpet height and brush control adjustment are set to their highest point possible (hardwood setting) in order to get the brush to roll in a carpet setting.
"R" is the correct belt for the 4870 and should be correct for all other 4800 models.
Thank you for posting your problem to this website. If I hadn't seen that others were having trouble, I would have just given up. I hope this long post helps someone that was in my situation.
Posted on Aug 06, 2008
  • 22 Answers
SOURCE: how to put on a belt on eureka uno bagless vacuum cleaner
Unplug the vacuum.
Turn it over so you have access to the bottom of the unit (you should see the brushroll)
At the base where the "head" attaches to the body there is a small silver button that you must depress to remove it from the body. Press the button in with a screwdriver or unsharpened pencil while pulling the "head" away from the body.
Use a #2 Philips screwdriver to remove all the large screws from the bottom. They are all the same size and type so you can collect them for safekeeping without worrying about which one goes where. There are 2 smaller screws (if I remember correctly) that are for the upright lock that you do not need to remove. They will be on the small plastic piece near where the bottom brush "head" attaches to the vacuum.
Remove the clear plastic clog cover.
Gently pry the gray cover off. This shouldn't be too difficult as the cover goes loose when you remove the screws.
Flip the gray side over and you should see the innards including the brushroll, the motor, wiring, etc. Facing the assembly like you were looking head-on at the vacuum the belt should be on the right.
Pull up the far end (non-belted end) of the brushroll and then the belted end.
The brushroll should now be free and you should check the teeth on the belted end of the brushroll to ensure none are broken.
Remove the old belt from the motor (also toothed) and replace with new belt (a second spare would be handy to keep around and this is a good opportunity to clean up the air path).
Put toothed end of belt into the belt loop and stretch it a bit to get the toothed end back into place. The belt should auto adjust but just in case you may want to manually rotate the brushroll a few times after replacing the far end (non-toothed end)
Repeat the rest of it in reverse order to put it back.
Posted on Feb 03, 2009
nwj2468
  • 76 Answers
SOURCE: My wife's Eureka 5855 Boss Bagless Wide Track stopped running
its probably something in the motor. you may have to replace the motor which could cost around $50.
Posted on Apr 19, 2009
  • 33 Answers
SOURCE: Eureka Boss Model 4703 Type Belt Problem
Eureka U style belt. Found in almost any major store. (Walmart, Kmart,Lowe's....etc ) Part # 61120C if you get a Genuine Eureka brand belt.
Posted on May 10, 2009
  • 33 Answers
SOURCE: download parts and operators manual
This owner's manual is available on the Eureka website. www.eureka.com Type in your model # down in the right corner, search & buy accessories.Click go, then choose either the 402A or 402A-1. It is the same owner manual for either one.
Posted on May 19, 2009
Need belt for Eureka vaccum The Boss model 5848 AV-2. Can you give me a belt number for what i nee. Thanks.
The belt part number for the Eureka 5848 AV-2 vacuum is 61120A.
Should you need part numbers for other pieces of the Eureka 5848 AV-2 vacuum, click on the following site, http://www.vacpartswarehouse.com/Eureka-5848-Lightspeed-Whirlwind-s/1959.htm
Mar 14, 2011 | Eureka 5849A Boss Bagless Upright Cyclonic...
A BELT FOR THE VACCUM CLEANER (EUREKA)
Here's a link to this exact belt for your vacuum cleaner on our website:
http://www.govacuum.com/1555.html
I hope this information helped you! Please be sure to rate this helpful if it did so other Fixya users with this vacuum can easily find this belt.
Thanks,
Chris J.
GoVacuum.com
Mar 30, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
How do I change belt for Eureka Whirlwind Lite "Boss" model 450 A
Remove the 4 screws on the yellow top of the vacuum. The yellow plate will pop up exposing the belt and roller.
Jan 20, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
Apr 15, 2009 | Eureka 5849A Boss Bagless Upright Cyclonic...
I need hepa filter specification for eureka upright mega boss.it is not bagless.
http://www.eureka.com/servlet/FindOwnersGuide
"You will find your model number on a metallic silver-colored rating plate. It’s usually located on the back or bottom of the cleaner. Here is an example of a rating plate: You will find your model number on a metallic silver-colored rating plate. It’s usually located on the back or bottom of the cleaner."
"Not all accessories, supplies, owner's guides or Eureka program details are available online. If you can't find what you're looking for, you can call 1-800-282-2886 for assistance. Our Service Representatives are available Monday through Friday, 8 a.m. to 7:30 p.m. Central Time, and Saturday and Sunday, 10 a.m. to 6:30 p.m. Central Time. Our Service Representatives will need your vacuum's model number, so please have it ready when you call."
Feb 25, 2009 | Eureka Mega Boss 4460DT Vacuum
Download parts and operators manual
Sep 15, 2008 | Eureka Boss Superbroom Bagless VacuumStick...
Eureka the boss upright bagless vacuum. how do i open it to get to the belt area? the brush seems stuck. it wont move
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=801547
Generic problem for all Vacuums
Posted by sweet0nes on July 18, 2008
Eureka the boss upright bagless vacuum. How do I open it to get to the belt area? The brush seems stuck. It won’t move.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 18, 2008 | Vacuums
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Feb 27, 2008 | Eureka Boss SuperLite Bagless Upright...
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
