Question about Tricity Bendix Washing Machines
Tricity Bendix aw1200w washing machine does not always drain water ! What is wrong ? Thank you in anticipation .
Checking for kinks in drain tube and clean filter .
I think something is floating around in the space between the inner and outer drums
like a sock or small plastic bag etc etc etc
so drain the machine
take the back panel off and remove the heating element and shine a torch inside
the blockage may have worked into the drain system pipes and traps
and you may need to totaly disconnect it and
lay it over on its right side {the side opposite the soap drawer}
then examine its outlet from the drum and pipes to the pump
the pump
and its housings and viens
for any wires and hair clips monopoly hotels and 2ds and 3ds platic pens
basically anything that fits into the soap drawer and fits down the intake pipes
that then lives inside the drums
so... taking the heating element out will expose the area you need to check with a torch
also if you shine a bright light thru the open lid of a washer
you can usualy see any implaled wires etc on the outer drum
most are transparrent or opaic
Posted on Dec 10, 2014
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
Why won't my tricity bendix aw1000w drain?
Check the filter and pump for coins, hair grips, screws etc and check the drain hose isn't blocked or kinked
May 09, 2012 | Washing Machines
The water is not draining from the machine
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 11, 2011 | Tricity Bendix WDR1040W Front Load Washer...
I have a tricity bendix dishwasher and it is not draining fully at the end of the cycle? If I run the dishwasher into a bucket the water pours out nice n strong. The waste pipe is not blocked, and I have...
Check the fitting where the dishwasher hose connects to the drain. If it drains when disconnected, it is either kinking the hose when you put it back in, or the drain is plugged at the connection.
Nov 19, 2017 | Tricity Bendix 18 in. DH090 Free-standing...
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Error code tricity bendix aw1200w washing machine
I think this is a problem with the thermister (built in to the heating element assembly).
Feb 21, 2008 | Tricity Bendix AW1200 Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
46 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
