Question about Vacuums
I hvent had my goods it says it been delivered
Please can u re send asap
Order No 026-0363033-3377141
Call the shipper...the company you bought if off of. If the package is lost, the shipper may just send you another one?
this happened to me where UPS lost the package. I contacted the shipper and they contacted UPS. They decided the package was lost and the shipper sent another one.
I got the second package they sent me, then about a week later I got the first one too!
Most companies have a dollar amount they won't quibble over say $25 dollars. If the item is under $25 they may just send you another one and if you get both..no big deal.
If the item is over $25 (and I'm making that number up) then they may do a little more research to try and locate the item before they just replace it.
Good Luck!
Nov 29, 2015 | Dry Pro Waterproof Cast Cover - Small Full...
Aquamate and rainbow - I have the soap setting on the handle off and it still delivers soap suds
Please provide more information as in what model you have....check link here if you are unsure to match up pictures....
http://www.rainvac.com/rainbow-vacuum-manuals
RainVac
Jun 28, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Kirby is smoking?
Send it back
It smokes & has no manual
You don't want either situation
It is defective,obviously
May 12, 2014 | Kirby Vacuums
I have a kirby G7D ultamite, I recently replaced the switch, it worked for two weeks then it hasnt turned on since. Also I checked the cord, it has power going to it. Please respond asap thank you.
The switch has probably come lose, have you checked the motor to make sure it is good? Usually the cord will short out right by the motor assembly try to wiggle it while plugged in and see what it does, its most likely the cord I recondition kirbys and never have I had a problem with the actual vacuum only the cord.
Nov 21, 2012 | Vacuums
Can I get a charger for a powerbase screwdriver? I've lost mine. Jacqui
Find out what voltage is required for the charger and any universal charger with a compatible connector will work. Batteries are rated at 1.2 volts, so if the screwdriver has 3 batteries you need a charger that delivers about 4 volts. A good hardware store should be able to supply you with a suitable charger.
Jan 17, 2011 | Vacuums
Will Not start. Fuel Pump working. Computer
Is fuel being delivered? Filter may be clogged. Good Luck.
Dec 07, 2009 | Vacuums
Shampooer
hi
here you go
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Please leave feedback
Thanks
Rob
Feb 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Not working on the carpet
did u clean the filter above the dirt cup?
Sep 16, 2008 | Bissell 6590 CleanView Bagless Upright...
Kirby vacuum upright
there could be shortage in the motor because of the water, you need to send this to repair shop asap
sorry about that
Aug 12, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
94 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
