Question about Home
Water is pouring out of pipes where steam should be coming from- ? - Please advise
  • 3,287 Answers
Paige - your question appears in the "Shower hardware" section.
Steam - from a shower head?
Water should be coming from a shower head and steam is in your radiators - not the other way around. Please provide more info on the products or system you're having this trouble
Posted on Dec 10, 2014
My neighbour is complaining about the steam coming from my new boiler is there a extension pipe that can draw it futher away
thee probably a way of attaching a pipe to the outlet and directing it down into a bucket of water or into a drain pipe or sewerage pipe
might be best to get the people who installed the unit to come back and advise on a good solution
Apr 11, 2016 | Coffee Makers & Espresso Machines
Coffee grinded but no coffee coming through
Got water in unit? is it heating water? is there a blocked pipe so no water come through? for last 2 remove coffee handle push button to pour coffee and see if water comes out and if it is steaming hot.watch ,don't touch hot water .
Sep 06, 2014 | DeLonghi Esclusivo Gran Dama EASM6600...
Have a chrysler 300 with a 3.5 litre engine. steam
Sounds like a gasket yes. If the head is aluminum it could be warped, or bock could be cracked. Either way, water in exhaust system is not a good sign. Check the oil. If there are bubbles, foam, or anything but oil, then you know it's mixing someplace.
Sep 14, 2013 | 2001 Chrysler 300M
Water pouring out exhaust pipe on ford taurus
cracked head or blown head gasket
Oct 11, 2012 | 1990 Ford Taurus
Wash temperature problem. Steam pouring out of the
Hi
I guess there is a short circuit problem with the machine, this could be anywhere. Would advise getting an engineer out. Hope this helps
Aug 16, 2011 | Bosch WFK 2401
My WJ528 Steam Cleaner heats up but no steam comes out the pipe, what could be wrong?
Well what it may be is mineral build up in the tank mix about 1/3 white vinegar and 2/3 cold water pour it in the tank let it sit for a little while then plug it in and run the mixer through.
Jun 16, 2011 | Vacuums
Scrunci steamer no steam when the button (for steam) is pressed Vinegar has been used to no avail. Please advise. Thank you
Its most likely this iron is clogged with lime scale as you have already used Vinegar . Buy a lime scale remover liquid , mix it with hot water. And pour it into iron leave for 24 hours then empty , clean iron out to get rid of any lime scale solution. And try it again..
Hope this helps.
Apr 14, 2011 | Scunci 52067 Handheld Steam Vacuum
While using, steam stopped coming out in force at the port levels in the head. Suddenly started high pitch whining, pressed button just above connection site and end flew off with great force pouring...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hi, ive lost my instructions and need to descale my iron. could you please advise me how to do it many thanks jo
CDR, Scale Away, you can buy at the hardware. It will remove the deposits. After you get it descaled you need to use Distilled water that you buy at the grocery store in it. This will avoid it scaling again.
Vinegar and water, Citric Acid crystals, Usual dose 1 teaspoon per 200ml water works
Pour it in just like water and let it steam out, then repeat with water, steaming out over a rag, sheet or something.
Feb 13, 2010 | Irons
Gaggia espresso machine won't percolate
Does the steam outlet give water when coffee swith is engaged. If so when you get a flow going, shut the steam valve and water should eventually pout in the cup. If no water pours thru the steam pipe, it's pump failure or blocked wand. If no water at shower depending on last result same problems. Search web for solution i.e. google "jammed espresso machine"
Aug 30, 2007 | Gaggia Classic Brushed Stainless Steel...
Home Logo
143 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
