Question about Kenmore Sewing Machines
Hello ... I have a model 385.19110600... I keep getting code L-9 what might that mean and how do I correct it ??
The bottom thread keeps bunching up and stalls the machine with the #E6. How can I fix?
Suspect the top thread is not seated completely in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Test your machine.
You can also look in the troubleshooting section of the manual for what the E6 code means.
OR, search for:
Make Model E6
Jul 09, 2017 | Sewing Machines
SINGER FUTURA XL-580 Error # 16 what does it mean and about sotution Thanks
Search the internet for:
Make Model error #16
or check the owner's manual Troubleshooting section. Frequently, it will list error codes.
this is from another website:
Singer Futura embroidery If the error code is not in your instruction manual, email singer at talk2us@singerco.com
1 ยท April 9, 2014 at 2:30pm
Heather Jamison
Heather Jamison I figured it out. It means the thread is tangled around the bobbin. Thanks
Nov 29, 2016 | Singer Sewing Machines
My machine will not change programs, will only do a straight stitch?
and we are looking just over your shoulder and know what manufacturer and model it is...
Apr 08, 2015 | Sewing Machines
What is the Singer sewing machine error code E7?
Hello, you didn't say what the model was? But here is a website to see what e7 means and download manual. Error Code E7 Singer 7258 Stylist Support
May 28, 2014 | Singer Sewing Co Machine Model 6199...
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
Janome 9200d overlocker
Aug 18, 2013 | Sewing Machines
Kenmore serger thread keeps breaking
Mar 26, 2013 | Sewing Machines
Bottom tread keeps jamming and getting all knoted up. The display gives me an E6 error code. what can i do
try re-threading your machine. usually when the machine is jammed at the bobbin or when the needle gets stuck to the bobbin thread, it means that there is an error with the thread. make sure that the thread isn't pulled through the wrong side of the needle, wrapped the wrong way around the wheels on the top, and that the bobbin is threaded correctly. if this doesn't work, you may want to contact their hotline.
Sep 23, 2009 | Brother CS-100-T Computerized Sewing...
Sewing Machines Logo
52 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
