We are trying to set up our security and in the system it is showing a pop up stating DVR disabled/disconnected, this is for a business that was bought out and this system was left...what is required
I HAVE FOUND OUR IP ADDRESS THAT NEEDED TO BE ADDED INTO OUR NETWORK/COMPUTER, BUT I THINK THAT ITS THE BOX ITSELF THAT IS DISCONNECTED, NOT SURE IF OUR NETWORK NEEDS TO BE CONNECTED TO THE BOX IN ORDER FOR US TO HAVE ACCESS TO THE CAMERAS...IF SOMEONE CAN PLEASE GIVE ME AN IDEA I WOULD GREATLY APPRECIATE IT, I HAVE BEEN AT THIS FOR HOURS
  • 36 Answers
The DVR needs to be connected to your network to access.
If it's connected to a router or being accessed remotely, you will have to additionally specify a port number to access it (???.???.???.???:port number). The router needs to be set-up to allow the port number to be used & any firewall software would require to be set-up accordingly
Posted on Dec 11, 2014
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
To factory reset the SDR-B74301
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
CCTV Networking Technical Support
Sep 18, 2017 | Samsung Home Security
Light will blink slowly on the adapter and the DVR but it will not turn on.
Few things you can try use a different wall outlet for power. Disconnect HDD and then try.
Might be a firmware issue you have to update firmware.
IP CameraNVR DVR Surveillance System Best secuirty system HD CVIHD TVIAHD...
Apr 01, 2016 | Q See QS4816-852-1 - 16 Ch H.264 Dvr 8pk...
How can you disable the old business owners remote viewing aps as the business has a new owner, thanks phil
Look for whatever software the old owners used and uninstall it. Or open that software and change the password used for login.
Feb 01, 2016 | Lorex Eco 8-channel Dvr Security System W...
How i can see dvr hd716 in ipad
so far, you cannot view the Panasonic WJ-Series Recorder using other browser than Microsoft Internet Explorer. because it use ActiveX Component to view the Video.
you can acess the Web Base interface of the DVR, just input the IP Address of the DVR, set disable pop up blocker for your browser, then it will show.
in some case, other browser than Internet explorer won't show the web correctly.
Sep 15, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
How do i connect to Panasonic Wj-hd716 from my iphone?
Sep 07, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
My Dish DVR 625 does the "program guide download"
Hello! Dan Busa with Dish Networks customer service department. This sounds like it may be a signal issue, I would make sure the cabling is tight and in good condition. You also want to enable your inactivity standby having it disabled will only make this worse. If everything seems ok you may need a technician.
Dec 16, 2010 | DISH Network DVR-625 DTV Receiver /...
Video not showing over internet
you need to supply more information. there are settings to control this feature but i would need to know information on your system like model number and how you have it hooked to the internet. web monitoring normally uses port 80, so if your hooked to a router you need to open that port to allow it to flow threw to the ip of the machine with the dvr card installed. if your not experienced with setting up networks or changing settings you will have a difficult time but i will try and help.
Dec 23, 2009 | Lorex 4 Channel Business & Home Security...
"HDD REPLACEMENT IS NOT VALID..." error message
Go to http://support.dell.com/support/edocs/systems/latd630/en/AMT/MEBX.htm
You have to disable Intel ME State Control , and you do not get any pop up masages any more.
I hawe that problem with secundary HDD.
Regardes.
Oct 12, 2008 | Pioneer DVR-213LS DVD±R Dual Layer Burner
HP D530
A thing known as BIOS or Basic Input Output System or system BIOS has been configured for security. When after the system starts, you are unable to boot up or go past the password due to a password. Try this:
To delete or disable the Power On password:
Shut down (Power down) the system and disconnect the power cord from the outlet
or the system unit.
Remove the chassis cover.
On the system board, remove the jumper on pins 1 and 2 of header E49 and place
only on pin 2.
Replace the chassis cover and reconnect the power cord.
- OR -
Remove the E49 jumper (green) next to the battery. Make note of whaere jumper was (pin 1-2 or 2-3).
Power on the computer, enter bios (Setup), F10 or F2 (I don't recall if they changed the key)
Disable 'Power On Password'
Switch off PC and replace the jumper.
Jan 10, 2008 | HP Compaq Business d530 Small Form Factor...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
