Question about FACTORY AC PARTS Hot Surface Ignitor Direct Replacement For Rheem Ruud Weatherking Oem Part 62-22669-92
Looking for a hot surface ignitor part number. York propane furnace model P2UDD20P13301C. I do not have the old ignitor.
  • 3,506 Answers
Go to a local heating and air conditioning wholesale parts supply and sales point and they should be able to get you an OEM or an aftermarket part OR go to a rheem rudd distributor or supply and service point
Posted on Dec 11, 2014
Need a ignitor part number for York propane furnace model # p2udd20p13301c
Found it on repairclinic website:
Manufacturer Number S1-47320937001
Dec 09, 2014 | York Tools & Hardware - Others
Need a ignitor for York propane furnace model #P2UDD20P1331C
Get model and serial # go to act parts. Dealer
Dec 09, 2014 | Heating & Cooling
"RUUD Achiever 90 Plus" Propane
Hello bikejocky,
MOST LIKELY you have a "hot surface" element
with a tiny crack in it...
About 25 years ago... I put one of my poor abused
fingers on the element to see if it was at all warm...
In so doing I touched the spot where the crack was...
and it did INDEED have a full 120 volt, 60 cycle AC
current waiting for my FINGER to complete the
circuit... (not a recommended procedure)
My 25 year old RHEEM... finally kicked it.
I keep spares... and bought 2 more when I used
the last
Since these parts are pretty cheap... I get spares
62 22868 93 Rheem 62 22868 93 Hot Surface Ignitor
Take a look... There are two basic configurations
The WISEST APPROACH is to use a "meter"
to verify the "line current" is present (not finger)
and check the "SURFACE" for continuity.
Once you copy the number DIRECTLY from
YOUR OWN part... look it up... internet... eBay
and AMAZON (like Robert Shaw #41-408).
http://www.ebay.com/itm/ROBERTSHAW-41-408-Hot-surface-ignitor-NORTON-271N-/121727955205?hash=item1c578d3105:m:mJR3I8e9mTI60A-dtmvdVrw
>> It is the plug & mount that is important...!!
(consider that spare you always wanted
(If you get it... you will probably never need it)).
The cycling limit & fan
(never touched a RUUD... (so... I presume)) is to clear accumulated GAS FUMES to avoid any explosive
situations.
I do know RHEEM... (ERGO... I have every confidence)
((RHEEM & RUUD, in my opinion, are design twins)).
Carnac the Magnificent
May 10, 2017 | Ruud UBHC Air Conditioner
Intertherm gas furnace
It appears your furnace is a downflow furnace. The sensor will be located near the bottom of the furnace. When you first turn it on, you should see a red glow.....this is the hot surface ignitor. Normally, the Hot Surface Ignitor is located on one end of the burners and the Flame Sensor is located on the oppoosite end of the Burners.
For more detailed information, click HERE.
Apr 15, 2010 | Heating & Cooling
I have had to replace the hot surface ignitor every year (its 4 years old and I have replaced the hot surface ignitor 3 times) on my furnace--is this a problem with all these furnaces or did I get a lemon?
I would check the grounding from the circuit board to cabinet, the ground coming in to the power of the furnace as well as the ground lug in your panel box. These furnaces are polarity specific and the wrong polarity or a loose ground will effect the longevity of the ignitor. Always buy a spare.
Jan 18, 2010 | Goodman GMS80903BNA Heater
Coleman furnace wont fire
Check inside the door panel next to the wiring schematic, you should find the diagnostic codes. Look up 7 blinks. This should narrow down the problem. ( It sounds like a bad hot surface ignitor).
Good luck.....
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Ignition failure. Relatively new furnace - under 5 years old.
You can replace a hot surface ignitor if you are careful not to touch the silicon surface. The oil from your hand may cause the ignitor to fail. make sure to turn off electric supply before attempting. You will probably need an OEM (from a coleman dealer) ignitor.
Usually best to bring the old one with you to make sure you get the right one with the right wire terminals. Or you can wire nut a new one to the old terminals. Could also be a dirty flame sense rod.
Hope this helps.
Matt
Dec 28, 2008 | Coleman Propane Forced Air Heater...
Furnace will not come on but thermostat is showing information
turn off power to furnace and open the front panel and see if you can see burners and gas valve and Hot surface ignitor.
If you can. turn furnace on and watch to see if the ignitor glows.
Let me know what you find. If it doesn't glow you probably have a faulty Hot surface ignitor.
If I had make and model number I should be able to find the part
Nov 16, 2008 | Honeywell Electronic Programmable...
FACTORY AC PARTS Hot Surface Ignitor Direct Replacement For Rheem Ruud Weatherking Oem Part 62-22669-92 Logo
Top FACTORY AC PARTS Dryers Experts
Are you a FACTORY AC PARTS Dryer Expert? Answer questions, earn points and help others
