Question about Sewing Machines
Needle stopped penetrating my fabric
Sewing heavy material, when needle stopped penetrating fabric. Using #16 needle. Heavy duty thread, long stitching #6, tension is fine, bobbin seems to be fine. My needle is sharp, I replaced it a few times. Foot plate and feed seems to be fine. Used a test piece of fabric? Not sure what else to do? The needle seems to go up and down fine without fabric in place, no obstructions?
  • Sewing Machines Master
  • 1,860 Answers
You need to replace the needle again, is the needle the right one for the heavy fabric?
Posted on Dec 11, 2014
  • 323 Answers
SOURCE: forgot how to set stitch
Find your zig zag width control and set it at 0 You will have a straight stitch.
sewman7
Posted on May 22, 2008
SOURCE: EURO PRO 6131 Sewing Machine not maintaining stitch
http://www.sewusa.com/Sewing_Machine_Instruction_Manuals.htm
Posted on Sep 04, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
  • 26 Answers
SOURCE: bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
Posted on Apr 08, 2010
  • 980 Answers
SOURCE: Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Posted on Jun 26, 2010
Is a dressmaker 300z able to sew heavy material like leather
Depends how thick the material is. Most mechanical machines will sew thicker fabrics, however, if the needle is unable to penetrate the fabric, it could damage the machine. Be sure to use a heavier, sharp needle.
Apr 07, 2017 | Sewing Machines
My janome 9000 sewing machine has stopped working 3 times when I sewed over heavy material. What s wrong with machine.
Did you take it for service? If so, the technician should be able to tell you what was wrong and what probably caused it.
If you didn't take it for service, how were you able to get it to sew again? Could be the fabric was too heavy for the needle and caused the needle to bend. It could be knocking your machine out of time. Be sure to use a heavy needle like a #16 or #18 (and for most fabrics try a "sharp" like microtex, top stitch, leather needle) and sew slowly with heavy fabric. Perhaps the fabric is too heavy for your sewing machine. I sew heavy fabric like vinyl, canvas, etc but I use an old metal mechanical machine that I can help along by turning the handwheel when the going gets tough.
All About Needles
Apr 03, 2017 | Janome Sewing Machines
Iam sewing seats. but the threed stared braking at the needle & it want saw.
Most likely, it has to do with incompatibility of the needle, thread, and fabric. The force of the needle penetrating the fabric multiple times is actually causing the thread to (wear &) fray and eventually break. There are needles with larger grooves that tend to protect the thread during stitching. Some may recommend a Top Stitch Needle (Home Machine Needles Superior Threads Why Topstitch? The Topstitch needle is the most common needle type used and recommended by professionals and educators. We recommend the Topstitch for piecing, quilting, embroidery, appliqu?, and construction. These needles are available in four sizes to accommodate all thread types, including metallic threads. The Topstitch needle has a larger eye and deeper groove. It is often referred as the MAGIC NEEDLE. It really does make a difference in your sewing experience.)
Why Use Topstitching Needle
Also, if the thread is a tight fit through the needle eye, it will also tear the thread. Make sure that the thread will slip easily through the eye. Go to a larger needle, instead of 90, try a 100.
Be sure to use a brand-new needle.
All About Needles
The Parts of Sewing Machine Needle
You may also consider changing the type of thread you are using. Go with a stronger thread, ie polyester, rather than cotton. Cotton will shred and break easier.
You will probably need to re-adjust the thread tension. If it is too tight, it will also break the thread. If you are using a heavier weight of thread, you will need to adjust both the upper and bobbin tension to accommodate the heavier thread.
Bobbin Tension How and Why Tension is Adjusted
If you sewing fabric that is sticky, ie vinyl, oilcloth, you should try to use a roller presser foot, a teflon presser foot, or a walking foot to help the fabric move with the feed dogs.
Sewing Heavy Fabric with NON Heavy Duty Sewing Machine SEWING IN GENERAL
Tips
Sewing through many thick layers of fabric Sactin
http://www.kollabora.com/q-a/sewing-denim-and-thick-fabric
14 Fantastic Sewing Tricks and Tips Making the World Cuter
How to Sew Upholstery DoItYourself com
Apr 22, 2016 | Sewing Machines
What size needle do I need for a Pfaff 463-34/01
it all depends on what you are sewing 80/12 is a standard needle for heavy fabrics use a 100/16 needle
Oct 17, 2014 | Sewing Machines
Bobbin thread will not pick up
Apr 08, 2010 | Necchi 3102 Mechanical Sewing Machine
I am sewing upholstry fabric together in a pillow with piping and heavy zipper. Thread will not go through fabric correctly and there are no stitches.
Hi. Unthread and rethread everything, clean out any lint, and oil the machine. This, plus using the right size needle (size 16 or higher) and thread (heavy duty), should do the trick.
Let me know if this solves the problem, ok?
Jan 19, 2010 | Singer 7442 Mechanical Sewing Machine
Sewing machine motor will not run after attempting
Overload Viking:
The machine has a built in overload protector, if your needle can’t penetrate, it may stop the machine from working for a few minutes. Just wait it will reset automatically. Then, try a Sharp needle (denim needle is ideal) and be sure to Never Never reverse sew on heavy fabric, your needle will bend and hit the needle plate, use the FIX button for knotting (it really does work).
Mar 15, 2009 | Husqvarna Designer I
My xl-5700 the needle keeps breaking or the thread keeps getting all bunched up plus I lost my instruction manual can I gat a new one
About the needle problem, Brother's FAQ gives the following response:
Make sure the needle is correctly inserted with the flat side facing the back and pushed up into the machine as far as possible.
The needle could have been damaged or bent. If so replace with a new one.
Make sure the fabric is not pulled excessively when sewing. Let the feed dogs move the fabric. Do not pull the fabric.
The combination of needle size, thread size and fabric is incorrect.
Be sure to use the correct needle and thread size for the fabric you are sewing.(example: Denim-size 16 needle and 40-50 heavy duty thread).
As for the manual, here's the link:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000063/ps21xl55565700ug02en.pdf
Dec 05, 2008 | Brother XL-5700 Mechanical Sewing Machine
Sewing Machines Logo
71 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
