Question about Garden
Air, idle & fuel settings for royal chainsaw - Garden
    New Friend:
  • 12 Answers
There should be a high and low jets, which should be marked H and L screw them all the way in. don't tighten to tight it will mess up the end of jet. turn out 1 3/4 turns. Start saw and adjust from there.
Posted on Dec 11, 2014
Could some help me with factory carb settings on this saw
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
Homelite Timberman 45 chainsaw runs fine but will not idle. Ideas?
dirty carb specifically in the idle jet turn it in till it bottoms . do not force more then return to the same place it was set if 3/4 turn in turn out 3/4 see if it works better .
Feb 16, 2015 | Homelite Garden
My chainsaw is idling high
Several reasons for that,
1. Air is getting into saw through leak in manifold
2. Carb idle/rev screw is set too high
3. Carb idle mixture screw is set too weak (uscrew it a tiny bit and check) See my other answer link below for advice on that:
4. Fuel filter in tank is partly blocked reducing fuel flow. They should be changed once a year on a domestic saw, more often on a professional saw.
5. The springs on the clutch are weak allowing it to engage at too low a speed.
Carburetor adjustment for efco 152 chainsaw
Dec 12, 2014 | Garden
My ehco cs300 chainsaw like to know how to get set screws and idle bacjk to factor has nio power and 20 plus pulls to get started wont stay idleing
Just a check Chain saws do not like e- mixed fuels. Only straight octane fuels. Clean air filter as they block really easy
Apr 01, 2013 | Garden
2002 yamaha venture 600 won't idle unless choke is engaged
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Dirt Rider Magazine
My KZ only runs choke fully engaged
https://www.tradebit.com/filedetail.php/278958138-yamaha-600-700-triples-snowmobile-service-repair
OEM parts for Yamaha
Yamaha Owner Manuals
Jan 08, 2013 | 2003 Yamaha Royal Star Venture
2006 royal star venture warms up fine with choke on, dies when I push choke in
Dirt Rider Magazine
engine stalls when turn off choke
http://www.yamahaventure.nl/pdf/servicemanualxvz13tf.pdf
http://www.yamahaventure.nl/pdf/ownersmanualxvz13tf.pdf
Aug 13, 2012 | 2006 Yamaha Royal Star Venture
Yamaha royal star xvz 1300 won't idle without choke
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
11. Faulty fuel pump.
2003 Star 1100 Custom won idle without choke aftermarket exhaust
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
https://www.tradebit.com/filedetail.php/243740175-1996-2001-yamaha-royal-star-xvz13a-service-manual
http://www.starmotorcycles.com/assets/service/manuals/1998/Lit-11626-11-17_320.pdf
Jan 01, 2012 | 1996 Yamaha Royal Star XVZ 1300 A
98-99 Yamaha royal star, air fuel mixture screw settings, thanks
Hi, Rbmotorsport it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
1. The mixture screw may be sealed at the factory with a Welch Plug please review the following video for removal.
https://www.youtube.com/watch?v=wAXcksgvDkM
2. The mixture screw manages a range of 3 complete 360-degree counterclockwise turns from the bottom/closed position.
3. The mixture screw should have a spring and o-ring for tension and sealing integrity.
4. Turn the mixture screw clockwise until it gently bottoms out, this makes the fuel charge very lean and the engine should not idle if it does then the pilot/idle jet is too big and needs to be replaced with the next size smaller.
5. Turn the mixture screw 1 and 1/2 turns counterclockwise to establish a baseline for starting the engine.
6. To fine-tune the idle circuit, adjust the mixture screw 1/4 turn in or out to achieve maximum idle RPM, wait 15 seconds between each adjustment for the idle to settle.
7. Never go past 3 full turns out this will make the fuel charge rich, foul plugs, and produce black smoke out of the exhaust, if the engine RPM keeps increasing past 3 turns the pilot/idle jet is too small and needs to be replaced with the next size larger.
7. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
8. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Royal Star Airbox Modifications
Setting carb fuel mixture screws
Yamaha XVZ13TFL Service Manual
Yamaha Royal Star XVZ13CTV Owner Manual
Nov 02, 2010 | 2005 Yamaha Royal Star Tour Deluxe
How to adjust idle on McCulloch Mac 2214av chainsaw
Look for 3 adjustment screws on the carb. should be three total. 1 screw is for idle adjustment. the other 2 should be close to each other, one is low speed fuel/air mix and the other is high fuel/air mix. Adjust the low fuel/air mix screw until it will idle un-added with the throttle then adjust the idle on the throttle to get a good idle speed. Next adjust the High fuel/air mix until it gets the RPM's you want it to have. It should go from idle to high speed with out hesitation or cough. . Start with 1 1/2 turn out from all the way in. Be sure the filter is clean, You can use starting fluid or old school lighter fluid to aid starting if has been sitting for some time.
Oct 10, 2010 | Garden
Have craftsman 36cc 16inch bar chainsaw will not idle need to know how to set idle screw
If you did nothing to the carburetor adjustments, are using a fresh (1.5 months or less) fuel mix with the same oil/fuel ratio, are operating at the same elevation, and the air filter is clean, there is a reason your saw is acting up.
The idle sdrew is usually separated fron the other 2 and probaly not fitted with an EPA limiter. HTH
Lou
Nov 01, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
